Rick@Livernois
Old 02-05-2011, 09:17 PM   #1
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
HELP!!! I just installed ARH Headers...
So I just installed the ARH headers those things sound awesome with CORSA Exhaust, but my check engine light came on , then the airbag light came on, then the traction control light came on and said it needed to be serviced.
ALso I cant drive tap shift anymore, WTF???? Anybody have this happen to them?
I had a SHIT EATIING GRIN THOUGH!!! CORA and ARH!!!!
650HP 725TQ 2010 CAMARO SS STOCK 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 02-05-2011, 09:18 PM   #2
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
My only thought is that you unplugged an important pigtail somewhere, check the codes.
bigsquirrel is offline   Reply With Quote
Old 02-05-2011, 09:22 PM   #3
AdamCzap
AdamCzap's Avatar
Drives: '10 TT SS / '07 Escalade
The CEL is probably just an o2 sensor code.
L99 Hellion Twin Turbo @ 7lbs 545rwhp, 560rwtq
Noweeds.net diverters
Pfadt solid subframe mounts, diff bushings, sways, trailing arms
Walsh Motor Sports tune
11.63 1/4 @ 123.5mph 1.87 60' on stock rubber
www.adamczap.com
AdamCzap is offline   Reply With Quote
Old 02-05-2011, 09:25 PM   #4
barnesql
Drives: 95' Z28, 2010 2ss RS
Hmm....not sure why the airbag light came on, but all of the other codes are normal. I know some options, such as remote start, will not work when the check engine light is on. This may just be another example of that.
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback
Off road x-pipe
Kooks LT Headers
barnesql is offline   Reply With Quote
Old 02-05-2011, 09:48 PM   #5
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
CEL is on since your rear O2 sensors are reading the same as the front sensors and it is telling your computer your cats are not working.
Did the traction control light come on first time you cranked it up or was it after driving it? Possibly a code from exceeding the torque which is stock set at around 300 lbs.
Typically after installing LT's you should have your car tuned to correct these issues. You can have the rear O2's turned off and the torque table doubled.
Airbags is totally different situation all together and runs on a different system entirely.
Good luck
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 02-05-2011, 10:04 PM   #6
Slowhawk
Drives: 1999 Trans Am
More than likely the steering wheel was turned when the steering rod was disconnected. Probly off by one turn.
Slowhawk is offline   Reply With Quote
Old 02-05-2011, 10:15 PM   #7
1985airborne
One Slow Automatic
@ 2010 SS RS the traction control light and CEL and air bad service light all came on at once...
Old 02-05-2011, 10:18 PM   #8
1985airborne
One Slow Automatic
@ Slowhawk Ill sheck the stering wheel out...I had to move to stering wheel shaft up when I in stalled the headers but Im postive I put the stering wheel shaft column back in place...
Old 02-05-2011, 10:58 PM   #9
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
Yeah, if you turned the wheel while it was disconnected, you could have broke the clock spring...which would cause the non O2 related codes.
www.marylandspeed.com * 443-730-9428 * Great Prices and Experienced Service!
MarylandSpeed is offline   Reply With Quote
Old 02-05-2011, 11:15 PM   #10
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
probably broke the steering angle sensor and airbag spiral cable which is the only things i can think of that would cause all those lights. it could get expensive to fix.
greenmachinedriver is offline   Reply With Quote
Old 02-06-2011, 01:07 AM   #11
Josh@ARH
Drives: 2013 Corvette GS
As far as the CEL goes you're most likely throwing P0420 and P0430. Those are cat efficiency codes which just need to be tuned out.
Josh@ARH is offline   Reply With Quote
Old 02-06-2011, 11:31 AM   #12
2010 SS RS
2010 SS RS's Avatar
And all this happened right away...first turn of the key? Normally the CEL from the 02 sensors take a while of driving before they set off the codes for the bad cats. If they came on right away..I would check to make sure that the sensors are plugged all the way in...and no broken wires. Same with the torque code setting off the traction control. Did you run the car off the ground or dyno it? If rear wheels spin without the fronts then it will set off the traction control service lights. Wow the steering wheel issue sounds like that could be a real pain in the a$$.
Old 02-07-2011, 08:07 AM   #13
1985airborne
One Slow Automatic
@ 2010 SS RS it took about an hour for all this to occur. First it was the CEL and Traction control then airbag service light came on after the car was turned off for about 20 minutes...
Old 02-07-2011, 08:22 AM   #14
CFD
Drives: 2SS/RS L99 BLACK
Not sure but all the above mentioned possibilities explain the cels but what about tapshift not working, perhaps a brocken wire or something unplugged.
CFD is offline   Reply With Quote
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 603 12-03-2016 12:03 AM
American Racing Headers (ARH) New Full Exhaust System (Updated) KILLER74Z28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 08-08-2011 12:02 PM
2 inch headers help/tips for either kooks or arh pRodigy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 11-08-2010 11:01 AM
JBA shorty headers installed, engine light on Acebeforejack Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 06-27-2010 11:41 PM
ARH Long-Tubes Installed on LS3 with Factory Mufflers ZZcamaro Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 73 08-31-2009 10:57 PM
