Emblempros
Old 02-05-2011, 09:51 PM   #1
6bloodychunks
6bloodychunks's Avatar
Drives: 2011 2SS/RS SGM
Question best technique for applying vinyl to a circular domed surface
just like the title says,
i am applying vinyl to my fog lights ,
and since they are domed
i was wondering what the best technique would be to install the vinyl.....
from the center out towards the edges ,or start at an edge and go across???
any help is MUCH appreciated!!
---2011 synergy green 2SS/RS---
09/27/2010 - (3800)
10/01/2010 - (4200)
10/09/2010 - (4800) Vehicle on final destination route
10/19/2010 - (5000) delivered to dealer
11/19/2010 - (6000) delivered to customer
6bloodychunks is offline   Reply With Quote
Old 02-05-2011, 10:06 PM   #2
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: SW 11' 2SS/RS LS3 Vert, Blk/Blk
Nver done a domed surface, but id recommend center out, with a heat source to conform it to the rounded shape... good luck!
Drago77 is offline   Reply With Quote
Old 02-05-2011, 10:13 PM   #3
6bloodychunks
thats how i was going to do it,
but thought i should check on here first because there may be a better way than mine to do it so it dont wrinkle.
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 02-05-2011, 10:19 PM   #4
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
Might I suggest "prestreching" first. with heat. It always seems to work for me. Then heat again when applying using a semi hard squeegy or paddle to work out bubble as you go.
KEEP RT is offline   Reply With Quote
Old 02-05-2011, 11:54 PM   #5
mulehead7
stubborn as a ...
mulehead7's Avatar
Drives: '94 Trans Am
I bought some Headlight Armor for my fog light lens. Heated them up with the wife's blow dryer. Started in the center and worked outward in all directions. Same for the headlights. Easy!
mulehead7 is offline   Reply With Quote
Old 02-06-2011, 03:21 AM   #6
6bloodychunks
cool, so it looks like center out using a hardryer
09/27/2010 - (3800)
10/01/2010 - (4200)
Old 02-07-2011, 10:06 PM   #7
HeadlightArmor
HeadlightArmor's Avatar
Drives: Company Car
If you are using our yes, that is the way to do it The small ones are done dry, the ones on the Camaro are more medium and can be done dry or with a little bit of water. The install tutorial for a typical small fog light protection kit is on the site here.
Hope that helps.
HeadlightArmor is offline   Reply With Quote
Whats the proper method for dust removal Strokedhog Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 35 12-01-2010 09:40 PM
