Old 02-06-2011, 03:05 PM   #1
miltp
Jim Pappas
miltp's Avatar
Drives: Rally Yellow 2SS/RS,Auto,G/X
Battery Charging: Need Help
I just recieved my Battery Tender Charger and I am not shure how to co9nnect it.First I need to know it is a Positive or Negative ground system and where to I hook it up, in trunk or engine bay and where to connect it. Any help would be great,
miltp is offline   Reply With Quote
Old 02-06-2011, 03:11 PM   #2
Goliath
Goliath's Avatar
Drives: 2010 Camaro 1SS L99 A6
Page 9-84 shows you how to recharge the battery and its connector locations. Good luck.
The Most Interesting Man in the World - On Muscle Cars
"I don't always drive muscle car, but when I do, I prefer the Camaro. "
Goliath is offline   Reply With Quote
Old 02-06-2011, 03:13 PM   #3
Russell James
Russell James's Avatar
Drives: Camaros
Negative ground. Easiest is the same two locations as for jump starting. The owner's manual should have a underhood pic of where to jump start it. Red + terminal in front of the brake booster. Neg post is mounted to the inside of the driver's side front fender, right by the air cleaner housing.
Or you could go right to the battery. Or mount the pigtail harness directly to the battery... several ways of doing it. As long as you are + to + and negative to ground, it will work.
Old 02-06-2011, 03:48 PM   #4
miltp
Jim Pappas
miltp's Avatar
Thankyou you guys for your help,it is most appreciated.
Whats the cold Cranking Amps on a 2010 Camaro's battery ? Jekyll-N-Hyde 5th Gen Camaro SS LS LT General Discussions 2 01-09-2011 08:59 PM
Smartest Battery Charger in the World!!! southerncarparts Miscellaneous Items 10 02-15-2010 07:08 PM
Smartest Battery Charger in the World!!! southerncarparts Audio / Visual / Electronics/ Gauges / Nav 0 12-04-2009 08:35 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 02:03 PM
