BeckyD@RodgersChevrolet
Old 02-10-2011, 09:44 PM   #15
Sneeks20
Drives: your woman wild...
Originally Posted by blackbee View Post
Injen looks good also and cleans up the engine area, at least compared to the airaid. Wish I would have ditched the airaid sooner, there is a power difference you can feel and the car sounds much better now, to the point it really doesnt need the MRTv2 I was goung to get to replace the magnaflows
Nice, glad you were able to get the new injen so quick.
Sneeks20 is offline   Reply With Quote
Old 02-10-2011, 10:11 PM   #16
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Ordered it I think last tuesday and had it last thursday and installed thursday night. Get that mrtv1 on and we'll meet up and compare notes
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/427 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 02-11-2011, 01:57 PM   #17
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Originally Posted by DarkneSS View Post
Straight up truth The quality is what these cars deserve! Ordering mine soon =]
Glad to hear it, Thanks!! Make sure to become a friend of our facebook page as well for contests with prizes and product updates!!
Sales @ CAI Inc is offline   Reply With Quote
Old 02-11-2011, 02:05 PM   #18
woodstock
woodstock's Avatar
Drives: 2012 Corvette Grand Sport
I use the Blackwing on my C-5
woodstock is offline   Reply With Quote
Old 02-14-2011, 12:09 AM   #19
unobadazzdosSSRS
unobadazzdosSSRS's Avatar
Drives: 2 SS/RS
Originally Posted by Bill @ CAI Inc View Post
I just wanted to point out a few key features of our system so that you will understand the method behind our madness so to speak. Here are just a few of the things we do to create a system that will maximize performance:
-Ceramic coat our intake tubes inside and out (the ceramic coating keeps the heat outside of the tube keeping intake air colder)
-Insulate our Air boxes (Again, keep hot engine air out of the system to keep intake air as cool as possible)
-We have designed and engineered our own filter to maximize airflow (its a lifetime oiled filter which you can clean and recharge)
-The box is all aluminum and TIG welded by hand, everything is top of the line materials.
I hope this helps!!
That's great information to know !
But before I buy one of your CAI's I do have a couple of questions about your Intake Tube and Air Box :
Can you polish the Intake Tube to a shiny gloss finish or would that strip the Ceramic Coating off the Tube ?
If you can polish the Intake Tube what product do you recommend using and can you also use that same product for the Air Box too ?
Thanks - no pun intended - for your intake on this !
unobadazzdosSSRS is offline   Reply With Quote
Old 02-14-2011, 01:00 AM   #20
TRC-SS
690RWHP-641TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Ted from Jannetty Racing did a Air intake dyno test on a bunch of intakes and by his test CAI was found to be the best performing intake...i know when i get my car this spring i will be ordering that intake...If you use the search option you will find that thread,,,,a ton of good info on all the aftermarket in takes!!
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 02-14-2011, 04:23 AM   #21
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Depends on how you define "best performing"... you seem to define it as the one with the most PEAK HP. Yes, the CAI had a very slight advantage in PEAK HP, by 0.4 HP, the Injen actually had a larger advantage in Average HP by 4.3 HP. Same thing with Torque. To me that gives more usable gains, make the Injen the better performing kit... you simply can't just look at peak number... you want to consider the whole area under the curves...
scrming is offline   Reply With Quote
Old 02-14-2011, 01:47 PM   #22
Sales @ CAI Inc
What you said is true, but one thing to keep in mind here is that the Avg. hp in Teds test was derived from combining all of the RPM ranges. You typically stay in the 4k and above range for WOT. Our system may be less in the Avg hp rating but is better at higher rpms, which is where you are going to be at when wanting to use the additional hp our system is creating. So to sum up, you are going to feel the added hp where you really want to. Hope this helps out.
Old 02-14-2011, 01:48 PM   #23
Sales @ CAI Inc
It is a high luster finish but if you took some aluminum polish to it you could make it even shinier. Thanks!
Old 02-14-2011, 09:58 PM   #24
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: Black 2SS/RS 14; Jeep 5.7 GC 15
I took the Black CAI, very easy to install.
It looks, sounds, and performs good.
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 02-15-2011, 09:57 PM   #25
unobadazzdosSSRS
Drives: 2 SS/RS
Would something like Mothers aluminum polish do the trick on the intake tube as well as the air box ?
Old 02-17-2011, 11:32 AM   #26
Sales @ CAI Inc
Looks like it would do the trick!! By the way, THE NEW WEBSITE IS UP!!!! Be sure to check out the video on the Homepage as well as on the Testimonials Page!!!! Enjoy!!! www.coldairinductions.com
Old 02-17-2011, 12:52 PM   #27
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Just out of curiosity, does this only use an oiled filter, or can a dry one used?
E.T. is offline   Reply With Quote
Old 02-17-2011, 07:41 PM   #28
WVCamaro10
WVCamaro10's Avatar
Drives: 2010 Camaro 1Lt RS Victory Red
the new website looks great... i just got my air intake today from cai and it looks great but i have not got it installed yet.
WVCamaro10 is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 07:50 PM
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! AutoAgenda V8 Bolt-Ons & Tunes 438 11-23-2013 10:49 PM
Cold Air Inductions TVS2300 Version Installation Issue DNA Forced Induction - V8 3 10-27-2010 01:15 PM
Cold Air Inductions WVCamaro10 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 10-18-2010 05:37 PM
RAM AIR MYTH OR TRUTH JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 06-18-2010 11:41 PM
