Old 02-07-2011, 10:43 AM   #1
NVMYSS
NVMYSS's Avatar
Drives: 2010 Camaro SS
Exclamation ARH Headers and Borla Atak
Has anyone run this setup without a tune? How does the car run?
Currently I have the Vararam V2 intake and will be adding the ARH 1 7/8" LT's with the Borla ATAK axleback. I was worried about tuning the car and warranty issues. I was also worried that without a tune the car would throw a code and not run right.
NVMYSS is offline   Reply With Quote
Old 02-07-2011, 10:46 AM   #2
SSilver5gen
SSilver5gen's Avatar
The car only throws the o2 sensor code. it will run perfectly fine, its just throwing the code because its flowing more air through the exhaist at the location of the sensors.Everything else on the car wll run perfectly fine
SSilver5gen is offline   Reply With Quote
Old 02-07-2011, 11:05 AM   #3
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Everyone says they don't want to mess with they're warranty but want to install aftermarket Performance parts.
Please Think about this for a minute.
Installing any aftermarket performance parts has the Same Risk of denying warranty coverage as a Tune does.
People who frequent this site are looking to personalize they're cars, and this is what this Hobby it is all about.
Pretty Much any aftermarket performance parts will require custom tuning for the car to run optimal and prevent codes.
We are all after Optimizing the Performance of our Cars.
This is why I run the Tune Program I run, buy your parts from me get tunes for those parts for free.
Optimal Performance right out of the box!
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 02-07-2011, 11:12 AM   #4
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
I would imagine ARH (catless) and ATAK is going to be loud as all holy hell...
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 02-07-2011, 11:16 AM   #5
NVMYSS
NVMYSS's Avatar
I have the hi flow cats, but am having the 02 sensors tuned out so I can run no cats later on if I want to.
But as far as the warranty goes, if I do have a problem they would have to prove that the headers and exhaust were the culprit correct?
Old 02-07-2011, 11:20 AM   #6
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro 1ss/rs
itll def through a code with out a tune but it will run fine
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance.
lakersftbl69 is offline   Reply With Quote
Old 02-07-2011, 11:24 AM   #7
NVMYSS
NVMYSS's Avatar
So the car won't run too lean/rich and won't run in "Limp" mode?
Old 02-07-2011, 12:00 PM   #8
brantley847
v It bites.
It depends on your service manager...
Where I have my work done they put it pretty simply..anything I add onto they were fine with as long as it was bolt on and I understand any damage or failure to those products would have to be covered by the supplier, not GM obviously.
But....If I tuned anything, my powertrain was gone. Now, you might get lucky and get around this or have a real muscle head service manager who may work with you. However, any major work (I believe) the shop has to contact GM for processing a warranty claim and they will check for any previous tunes. I don't want to mislead you...but it seems that is the point many C5 members get tied up.
I am still teaching myself this whole process, but I imagine it would be pretty easy for them to ARTICULATE that the tune could have added stress and potentially caused the failure...that is all the need as "proof". It seems based on the people I have talked to in service, that if he is doing his job and has GM as his best interest a tune would tie you up. Not 100%, but that is where they will press the issue of transmission failure based on your modifications...not the header itself. I don't think there is a likelihood that headers would cause the failure themselves and a good manager knows that..
2011 2SS/RS
Old 02-07-2011, 12:03 PM   #9
jeffa55
Drives: 2010 1SS/RS Camaro 6M Cyber Grey
I have the complete ARH 1 7/8's exhaust and I have not tuned the car. It seems to run perfectly fine (I have had it on since June). The car has thrown a 'check engine light' a couple of times but it has gone out both times within a couple of days... no check engine light for a long time now. In reading the forums, it sounds like I may be in the minority with no engine light. One thing that I did was to put four brand new sensors into the new exhaust (rather than pull the old ones out).
jeffa55 is offline   Reply With Quote
Old 02-07-2011, 12:11 PM   #10
JANNETTYRACING
Basically the Light goes on a few times then gives up warning you but the Codes are Still there in Memory.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 02-07-2011, 12:26 PM   #11
NVMYSS
NVMYSS's Avatar
Ted.
So without a tune , how much HP/TQ am I losing at the wheels without a tune?
Old 02-07-2011, 12:33 PM   #12
JANNETTYRACING
HP/TQ is the least of what the tune does for you, about 5-10
What you get with a tune.
Maximum efficiency,
No annoying check engine lite or codes
Torque management elimination
Skip shift elimination
Rev limiter raised
Speed limiter raised
Fans ramped in earlier in temp range
Maf Curve adjusted for your current CAI.
Timing optimized for your mods.
Etc.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 02-07-2011, 01:13 PM   #13
NVMYSS
NVMYSS's Avatar
I guess what I'm asking, can running without a tune hurt the car at all?
Old 02-07-2011, 01:15 PM   #14
JANNETTYRACING
As long as you don't mind the Check engine lite your good to go, and you won't pass emissions either.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
What's the best type of headers to get with the Borla atak NoynuR Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 11-18-2010 01:22 PM
Borla Atak + Catless headers, is too LOUD! BossCitySS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 09-22-2010 11:43 AM
Borla ATAK catback w/ARH Headers sound clips!!! TornadoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-19-2010 10:10 AM
Which LT headers with the Borla Atak catback? GuidosCamaroSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 06-30-2010 09:36 AM
Which LT headers with the Borla Atak catback? GuidosCamaroSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 06-15-2010 03:09 AM
