| Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: 2011 Camaro LT V6 Manual Join Date: Dec 2010
MRT Exhaust v2.0 burning my bodykit
Few days ago I just installed the MRT v2.0 exhaust..
dammm I loved the sound !! so deep and sexy and everything. but im getting this one problem... the exit of my MRT v2.0 is touching the upper part of the Camaro's body part... where the hole of the exhaust is located... and since the exhaust gets hot, day by day, it is slowly burning the body part where it touches.... ![]() hmm.... did anyone have that problem?? how should i fix this?? unscrew the exhuast, aim more downwards and screw it again?? THank you guys. |
Tampa Gulf Coast Family
Drives: LT1 RS red jewel white stripes Join Date: Jul 2009
Never had an issue with mine. Just make sure they are centered.
SoCal Family Member
Depending on how you installed them (welded or clamped) I would remove then re-install and see if that works. Also, when I installed mine I could make little minor adjustments with the black rubber insets where the hangars went. I would try and see if those could be readjusted before taking out the whole system.
كمارو صفرا ^_^
Drives: '10 Camaro LS - M6 Join Date: Mar 2010
Sorry to hear that but ..
having FUN now
Make sure you are centered and sticking out past the rear diffuser.
#6 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Also when you go to re-tighten the clamp: 1) Position clamp to the edge of MRT exhaust, clamp should extend approximately 1/8 inch past end of axle back tube. 2) Make sure you hold the tip in place when you are tightening the clamp |
#7 |
Going places
Drives: 2011 2LT/RS Victory Red Join Date: Oct 2010
This is exactly what I wanted to discuss. I have ordered the GM ground effects kit and the MRT v2 exhaust for ground effects. This is a special part for cars with ground effects. Anyone else have the exact set up I've ordered?
http://www.camaro5.com/forums/group.php?groupid=240 "just stay with traffic, you'll be fine". = famous last words |
#8 |
![]() Drives: 2011 Camaro 1LT RS M6 MRT V2 Join Date: Aug 2010
I had the same problem with my driver's side tip. The passenger side was perfect. I had to loosen the clamp, twist the whole thing to get it centered then tightened the heck out of the clamp. Make sure the clamp is an 1/8" past the new pipe, this is very important. An extra person would also help to hold it in place when you tighten the clamp.
Mine hasn't moved since. |
| Thread Tools | |
| Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 2067 | Today 11:45 AM |
| MRT Exhaust Tips? | Dimitry@FairwayChevrolet | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 8 | 09-21-2010 04:02 PM |
| Wtb: mrt exhaust for v6 | nyycamarogirl | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 0 | 08-25-2010 03:41 PM |
| MRT v1.0 vs. v2.0 | JChen | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 8 | 03-07-2010 09:39 PM |
| MRT EXHAUST | CamaroBAMF28 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 88 | 12-23-2009 11:15 PM |
