| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
Farewell 2010 1LT/RS...
Switching to non-staggered setup improves cornering?
I finally ditched my P-zeros after 25k+ miles. I pulled off the stock 20x8" front wheels and put stock 20"x9" wheels all the way around with 275/40R20 Hankook Ventus ST RHO6 tires.
I've only put about 75 miles on this setup so far but almost immediately noticed a change in how my Camaro handles corners now. There are a few freeway interchanges that I travel on daily at the posted speed (60mph) instead of the curve warning speed (35mph). With the staggered (20x8/20x9 stock) setup I always felt like I was fighting with the steering wheel through constant corrections to keep things pointed in the right direction. With the 20x9 all around configuration, the car feels very well planted with no steering input correction needed. ![]() Even for typical street road turns, the car feels very well situated and lighter on its feet when compared to stock. I know there are valid reasons for having a staggered setup, better traction to the drive wheels for one, but I didn't expect such a noticeable handling change just by ditching the stock staggered setup. Anyone else switched to a non-staggered setup seeing this with your Camaro?
#1: 2010 1LT/RS Victory Red M6 - July 2009-Oct 2011 (SOLD). ![]() #2: 2011 2SS/RS Synergy Green A6 - Oct 2011..... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2011 Camaro SS Join Date: Oct 2008
It has nothing to do with you going non-staggered. The improved handling was due to the wider front tires alone. Wider tires help decrease understeer, or push. They also stiffen up the steering a bit more than narrow front tires.
Best handling combo is going with max width tires front and rear. More tire width, more traction, pure and simple.
#3 | |
![]() Drives: 2010 Camaro SS Join Date: Mar 2010
Sold 2010 IBM 2SS RS / LG G6X3 Cam / 1 7/8" Kooks headers / Hi-Flo Cats / ADM Cold air / Magnaflow 3" exhaust / UD Pulley / Sam Miller Tune / SAE 481RWHP 441RWTQ / Eibach Pro-kit / Eibach front and rear sway bars / Elite Catch Can / DRL Harness and AAC Plasma bulbs
#4 | |
#5 | ||
I used to be Dragoneye...
He claimed that in some cases, you'd want a skinnier-than-max width tire because the psi resulting from the tire-patch and the weight of the vehicle may no longer be high enough to optimally stick...basically he was saying there is such thing as "too wide" and it'd be like sticking clown shoes on the car...you loose traction because the friction forces between the tire and the ground become less thanks to a larger patch. Like I said...I never really bought into it. But the physics behind it made for an interesting conversation. Quote:
To best eliminate it, you should take a comprehensive approach including the tires/wheels and suspension. What changing the fronts did was give you more grip and so they slipped less as you turned, resulting in a reduction of understeer. If you stick wide tires out back, the rear end of the car will stick even MORE than the fronts...and its likely the understeer will return (if reduced) because of the suspension setup. BUT...because you're wider than stock both front and rear...you'll have to put more stress on the tires (turn harder) to reach that breaking point. |
#6 |
Yes, it is a complex series of track tests to find the perfect combo for each vehicle. Some cars are designed with too much oversteer, so the narrower front tires tone it back down. Some cars are weight balanced front to rear a little better, or have different damping on the shocks, etc... to induce the handling aspects of the car. There are a lot of variables. Changing tire width is just a simple fix.
If you go with wider rear tires, you give up a little ability to use throttle oversteer, unless you add more power to overcome the added rear traction. Some guys prefer using the narrower rear tire to be able to throttle steer a RWD car when they get into trouble. Nothing like having extra hp on tap to re-direct the vehicle (aka slide the ass out) to fix any understeer. haha Even more important than tire width, is tire compound. Softer tires will stick on a track better, it will make it feel like a different car. But, softer tires also wear out faster if you aren't good at following an efficient line through the curves. It is better to master road course work on a street radial, to learn the fast lines. Once you can master the speed through the turns, then step up to a race compound to push it even harder.
#7 |
Ok. So here's another related question then....
If I put different width tires/wheels front and rear, is it better for handling to have the inner edge or the outer edge of the same side tires line up? I'd assume it's the outside edge but I've been known to be wrong a few times in my life.
#8 |
![]() ![]() Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
You added grip to the front and took away grip from the rear. This decreases the understeer built in from the factory and has made the care feel more neutral. There are other ways to do this with alignment/suspension/air pressure while maintaing the stagger that will maximize handling. Its usually best to maximize tire width and change other items to decrease understeer.
When ordering online please reference "Camaro5" at checkout. This helps to support the forum. |
#9 |
Nothing to do with front to rear edges lining up. If you visit a lot of racetracks, you'll find that they just prefer to use the widest tires that fit the car, without any rubbing or steering clearance issues. The wider track does help though, front and rear. Also, most cars have a wider front track than rear, just by design.
#10 | |
#11 | |
![]() Drives: 2010 LT1 VR CAMARO #14568 Join Date: Aug 2008
Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?"
![]() HOTROD...flowmaster exhaust, color matched antenna and drip rails, barton shifter, 4 pack gauges, leather armrest, color matched spoiler, and emblem delete, 20x9 chrome wheels ![]() |
#12 |
Defending the Nation...
Drives: 2LT/RS, 6SPD, IOM, Blk Int Join Date: Dec 2009
You may also notice with wider front tires that the car may wander a bit because of increased bumpsteer.
TEAM LLT !!!"SURSUM AB ORDINE" ![]() |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
So....I was thinking of putting a set of rears up front mostly to be able to rotate the tires.
I'm reading mixed messages in this thread. Sounds like some are saying...yes, go with the wider fronts....others saying you might have issues. I'm not looking for better steering at a road course. I'm mostly looking to be able to rotate and extend the life of my tires. Plus, I would imagine it looks pretty damn good that way as well. Do you not recommend going with wider fronts? Is keeping the staggered wheels a better option? OP: Any chance you could post up some pics of what your fronts look like now. I"m curious on how much more they stick out than the OEM fronts.
Build Journal ![]() |
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
Yeah, I'll get around to it...
#15 | |
xbox360 tag
Drives: 2010 inferno orange 2SS Join Date: Apr 2010
#16 | ||
Will see what I can do when I get home this evening.
#17 |
Been running the factory 20x9 rear wheels and Pirelli P Zero 275/40/20 on all 4 corners of my car for some time. It does decrease under steer, makes the steering effort ever so slightly heavier and IMHO does look better. With a proper alignment ( not off the line factory ) the car should not exhibit any wandering it didn't already have with the 20x8 and 245/45/20 OEM front setup. The only real downside is the SS 20x9 wheels with 275/40/20 tires are heavier than the OEM 20x8 with 245/45/20 tires so you end up increasing the rotational mass on the front of the car.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, Hawk HPS Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9 & 20x11 DS3 wheels with Pirelli Pzero 275/40/20 & 305/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, GM SS Fender & LS3 Emblems.
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Truck Join Date: Apr 2010
He might have a point. |
#19 | |
WOW! I so need to install some lowering springs on my Camaro.![]() ![]() ![]() ![]() For comparison, here's a shot with the stock 20x8 fronts...
#20 |
Nice!
I think I'm going to go down the same route. Now you just need to lower yours with some drop springs.
#21 |
BTW: did you have yours aligned again with the wider tires?
#22 |
Dances With Mustangs
I'm running the same size wheels all the way around and the performance is great. I have 3-piece forged rims in 19" with a tire size of 275/40-19. They're 1.5" wider than the stock fronts and .5" wider than the stock rears. They're 5 lbs lighter than the stock fronts and 10 lbs lighter than the stock rears. Well worth it.
http://www.camaro5.com/forums/showthread.php?t=45165
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#23 |
Not yet. The car still tracks straight as can be but I should probably have it checked anyhow.
#24 |
![]() Drives: 2SS Join Date: Sep 2010
For those thinking about 9"/275's all the way around..... I Have that setup on mine, an it feels great!
FYI... Be sure to keep one of your 8"/245's and use it as a spare. it will make a great emergency wheel/tire and spare! |
#25 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
Exotic cars have better suspension parts than the Camaro. Also, they are most likely lighter, and have a lower center of gravity. And the weight is mostly in the center. All of these factors give those exotic cars an edge. In any case, if you just want less understeer, wider front tires can help control that.
| Thread Tools | |
| Non staggered setup for autocross/road course | flht99b | Wheels and Tires Talk Sponsored by The Tire Rack | 1 | 09-03-2010 07:13 AM |
| Setup Crisis - Purchasing one of these tomorrow | gmag21 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 09-07-2009 02:00 PM |
