Old 02-07-2011, 03:03 PM   #1
kook
kook's Avatar
Drives: 2010 2SS Yellow
How much boost with E-Force 3" pulley?
Does anyone know roughly how much boost the 3" pulley makes with the E-Force supercharger?
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
Magnaflow Street Cat-Back
DOD Delete
Forgestar F-14's and Pedders XA + PKG
Custom grind cam from Cincy Speed
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Cincy Speed Build and Tune 540rwhp
kook is offline   Reply With Quote
Old 02-07-2011, 03:27 PM   #2
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I was told this by stillen:
- LS3 TVS stock pulley 3.5" = ~7.5psi 599fwhp 547fwtq
- L99 TVS stock pulley 3.875" = ~5.5psi 554fwhp 515fwtq
- 3.25" TVS pulley = ~9.5psi (will require belt change)
- 3.00" TVS pulley = ~11psi (recommended for forged internals)
- 2.75" TVS pulley ~13-14psi (recommended for forged internals
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 02-07-2011, 05:45 PM   #3
old motorhead
Drives: Maggie blown LS3 vette
3" pulley on a front drive TVS might be 10 to 12psi or it might be +14psi. Just depends on how the rest of the motor is set up. Need to know a little more on what's involved mod wise.
old motorhead is offline   Reply With Quote
Old 02-07-2011, 05:55 PM   #4
kook
kook's Avatar
Will have a cam and currently has 1 7/8 lts. I want to keep the boost to a minimum. Like 8-9 at most. L99-Ls3 conversion if that matters.
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
DOD Delete
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Old 02-07-2011, 06:22 PM   #5
old motorhead
I'm running a front drive Maggie TVS with mild blower cam, Ported 243 heads (similar flow as stock LS3 heads), LT headers, 3" duals, no cats, and 3.1" pulley. I'm seeing 12psi. Based on that, I'd bet your LS3/L99 would see well over 8 to 9psi with the 3" pulley. If you're looking for 8 to 9psi, you might want to go a step bigger than the 3.0".
Old 02-07-2011, 07:16 PM   #6
JM10
Se habla espaņol
JM10's Avatar
Im using the 3.25" and seeing around 8-9psi at WOT
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 02-07-2011, 09:28 PM   #7
05gofast
05gofast's Avatar
Drives: Something Fast
Depends on setup - cam, exhaust, heads, etc.
I have personally seen 3.25 pulley, cai & full exhaust get 8.5-9psi on hit & rise up to 11 by redline. 3.0 pulley on same set up peak at 13psi
05gofast is offline   Reply With Quote
Old 02-08-2011, 07:54 AM   #8
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Strongly suggest fuel delivery upgrades on anything smaller than 3.25 pully. JRE dual fuel rail upgrade and BAPon 3.25 pulley and LPE or ADM dual fuel pump 3.0. Also get inside and get internals done or you will be soon enough!
Rings, pistons, gaskets, bolts will all prove to be weak points.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 02-08-2011, 09:06 AM   #9
kook
kook's Avatar
Dual pump, JRE upgrade, injectors are all being done. I want the boost 8-9 psi max.
Edelbrock E-Force
Stainless Works Lts
Roto Fab CAI
DOD Delete
ADM dual fuel pump
ADM AF/Boost gauges
FTI 3200 convertor
Hurst shifter
Old 02-08-2011, 11:11 AM   #10
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Yea..what he said.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 02-11-2011, 12:02 AM   #11
Jenny1
Banned
Drives: Honda
E-Force 3"pulley will system Supercharger system to between 9.5 -10 PSI on car.
Jenny1 is offline   Reply With Quote
Old 08-16-2013, 10:12 AM   #12
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
I am trying to decide which size pulley to go down too 3.0 or 3.25. I have a LS3 with modified heads, cam, injectors and exhaust but have not touched my bottom end. Have you rebuilt your bottom end or is it stock.? Current psi is 6.5 with stock edelbrock pulley.
"Z28 = first time I bought a new car just to strip parts for my current ride. GM needs to re-think restricted parts. "
macwest is offline   Reply With Quote
Old 08-16-2013, 03:06 PM   #13
epstein
Drives: SS/RS
Send a message via AIM to epstein
Just my opinion.... But I wouldnt go smaller than 3.25 on stock bottom end
You can see from my sig I did all the fuel upgrades before I went to a smaller pulley...
during the dyno run as was stated...9.5 psi....and when the rpms approached the limiter...was just shy of 12 psi.....
My next step is forged internals on stock displacement. Along with a JRE Cam Package and a 3" pulley.
epstein is offline   Reply With Quote
Old 08-16-2013, 11:12 PM   #14
macwest
I appreciate the advice. On your change to a 3.25 pulley did you need to change your belt? it would seem on a ls3 the std pulley is 3.5 so a upgrade to 3.25 may not need it but knowing ahead of time would be great.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Smaller blower pulley or bigger crank pulley? B-rad Forced Induction - V8 14 11-14-2010 01:09 AM
Former task force head bullish on GM, Chrysler ShnOmac General Automotive + Other Cars Discussion 0 10-21-2009 09:06 PM
Took the SS to the track 126.67mph on boost only! Icon Autosports Forced Induction - V8 5 09-27-2009 12:15 PM
