JUICEDMOTORSPORTS
Old 02-07-2011, 10:29 PM   #1
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Thumbs up How to Install HIDs in Your Halogen Housings
Read the entire thread before beginning on your project.
I want to start by thanking Xenith Xenons for the 6000K GEN kit and Betro02 for assisting me with my install in Spanish.
The first and most important step in this process is to get a Camaro. I'm not going to tell you how to do that, but I will tell you this. Your dealer is an idiot.
Now, you need some tools. I just found my favorite Mexican, Betro02. He helped me a lot by providing the tools and experience he learned from installing HIDs in his truck. He also pointed me in the direction of the best nachos I've ever eaten before we got started.
Here is what comes in the Xenith Xenons GEN kit for H13 bulbs.
You will get 2 ballasts. They look like this.
You will get 1 control module. This is it.
The box will also contain 2 lights in harnesses that match your stock H13 bulbs.
Let's begin. Start by popping your hood. In order to do this, unlock your car door and open it. Do you need pictures?
Pop your hood by pulling this.
Pop it like it's hot!
Speaking of things that are hot, you need to unplug your battery. It's in your trunk under your spare tire if you have one like me.
Unscrew this.
Remove your spare if you have one.
That's your battery cover. Take it off.
This is important. Remove the cable.
This is how a detached cable looks.
This is pretty easy so far. Now, let's get some work done!
Find your bulb. It has a green harness with a red button on it.
Stick your hand down there and get it. Try not to get stuck, like Betro02.
If your lights were just on, you can use them for warmth, like we did.
It's cold outside. What else can I say?
Now that you're warm, go back to the front of the car. There's a fuse box on the passenger side. At the front of it, there is a positive. We had to improvise a little to get the included cable to fit here, but we figured it out.
Remove the screw from the positive at the front.
Take the positive cable and attach it here.
Put the screw back where it belongs.
When you drop it, you'll yell, "No!" Don't worry. It lands right here.
Pick it up and put it where it goes. Don't drop it this time!
You can ground to the side of the engine bay using OE screws.
Plug the stock harness into the HID harness.
Plug in the other wires. They should click. If they don't click, then you should unplug them and try again. Failure to make them click could result in a yellow flicker, lower light output, or an incomplete circuit (no light at all).
We tested the first bulb after all of this. If you test it, don't leave the protective styrofoam on the bulb. You'll quickly smell burning. HIDs are hot. Be very careful.
The kit comes with 2 zip-ties. We used 3 to attach the ballasts and control module to OE cables and 1 to attach some loose cable to some OE cable on the driver side. I'd recommend getting 2 extra zip-ties.
Go do most of that stuff again to the other side. I recommend starting with the passenger side because it is
Here's the before-after comparison. :seesaw:
This is how your halogens look.
This is how your high beams look. They're brighter.
Holy crap—that's bright!
I wear my sunglasses at night so I can avoid HID blindness.
Now, go get some HIDs!
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 02-08-2011, 11:36 AM   #2
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
awesome write up...thanks
hapisok is offline   Reply With Quote
Old 02-08-2011, 10:51 PM   #3
bigwayne3000
Drives: 2011 Camaro LS
How much was the kit you went with and whered you get it from? I'm thinking of adding HIDs to my LS.
bigwayne3000 is offline   Reply With Quote
Old 02-08-2011, 10:58 PM   #4
bigwayne3000
is this the kit?
http://www.xenithxenons.com/product_p/gen-kit.htm
Old 02-08-2011, 11:07 PM   #5
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
sick write up !!
SlowSS is offline   Reply With Quote
Old 02-08-2011, 11:12 PM   #6
The_Blur
Jayhawk USN
The_Blur's Avatar
Originally Posted by bigwayne3000 View Post
That is the kit. You want to select H13—this number is also written on the stock bulb base if you want to confirm—when you pull down on the list. Also, it is worth noting that standard xenons only give low beam light. For an extra $35, the bixenons also have a high beam. I went with 6000K. They are super white with the tiniest hint of blue.
TO: Camaro5//
warn 145:155 ban
Old 02-08-2011, 11:55 PM   #7
bigwayne3000
How does this kit compare to the AAC HID conversion kit they have for $225?
Old 02-08-2011, 11:55 PM   #8
patrickt
patrickt's Avatar
Drives: still saving!
very nice writeup!
patrickt is offline   Reply With Quote
Old 02-09-2011, 12:09 AM   #9
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
LOL this write up is HILARIOUS LOL. I loled hard when you taught us how to open the hood... Very good sir =D
jagan323 is offline   Reply With Quote
Old 02-09-2011, 01:12 AM   #10
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Good job, on the write up. I liked the sarcasm in your post. Made me laugh.
=Stephens= is offline   Reply With Quote
Old 02-13-2011, 11:32 PM   #11
chicagobulls
one car wolfpack
chicagobulls's Avatar
Drives: 2010 Camaro V6
what button do i press to open the hood pictures please
chicagobulls is offline   Reply With Quote
Old 02-13-2011, 11:36 PM   #12
Sevn86
Sevn86's Avatar
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 02-13-2011, 11:43 PM   #13
The_Blur
Jayhawk USN
The_Blur's Avatar
I'm going to start posting DIY threads on topics like this.
TO: Camaro5//
warn 145:155 ban
Old 02-14-2011, 05:31 PM   #14
AUS10BMX
AUS10BMX's Avatar
Drives: 2010 2LT RY, 2014 Silverado
Very Nice! These in 6000K will match my fogs and DRL switchbacks perfect! I have been debating between many sites on what kit to get, and this price seems convincing. Although I don't mind paying more for a really great product.
Do you know what kinda of warranty or coverage they have on bulbs and ballasts going out? I know some of the more expensive companies hold a pretty good warranty if anything fails.
Edit: http://www.xenithxenons.com/category_s/20.htm Seems pretty fair.
Hypertech | Airaid | JBA Exhaust | RX Catch Can/CNC TB/Black Ice-Olator | Ported Intake/Heads | 1LE Brembos | F14's | RS Headlights | ZL1 Grille
AUS10BMX is offline   Reply With Quote
brighter, halogen, headlight, hid
INSTALL OF BARTON SHORT THROW SHIFTER BLACK10 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 141 03-20-2017 11:01 PM
Install of new Pioneer AVH-P3300BT with painted black Metra kit Darth Martel Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 50 09-13-2011 09:50 AM
Roto-Fab Cold Air Intake Install - PHASTEK Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 03-17-2011 03:46 PM
4.10 or 3.73 Gear & Install Kit Combo Apex Paul Transmission / Driveline 21 08-21-2010 02:55 PM
Edelbrock E- Force Super Charger Install On 2010 Camaro rt66 Forced Induction - V8 17 06-02-2010 04:15 PM
