Tom Henry Racing
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 02-08-2011, 09:56 AM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
Hot Spark Plug Wires in Stock
Update your spark with a set of MTI Racing Hot Spark Plug Wires for your 5th Gen Camaro.
These LSX spark plug wires are custom made for MTI Racing by the supplier to IRL and Daytona Prototype cars. Perfect for street, show or track. Constructed of high energy wire-wound core with 7mm high temperature silicone insulation jacket. Stainless steel terminals are used for superior corrosion resistance. High temperature silicone boots. Silicone over Fiberglass Heat Sleeving adds additional heat and abrasion protection to wire. These wires will last longer under heat, provide more energy and look better too.
They are not just for "highly-modified engines". They provide benefits even on stock engines.
FACT: Heat causes electrical resistance, and that robs ignition energy.
The MTI Racing wires tolerate the underhood temps better by using protective heat sleeving and fire braiding to keep heat away from the conductor wire. When the heat is on, the MTI Racing wires keep on delivering full energy, day after day, after day, after day.
Factory wires...not so much
BENEFITS:
•Protective Heat Sleeving
•Fire Braiding over wire
•Provides more consistent ignition for all applications
•Better clearance to headers
•Enhances engine compartment appearance
•Even available in custom lengths (for variety of valve covers and coil relocation options)
*For those cars with HEADERS.... With these wires, you have better clearance to headers, AND you are able to grab the boot so much better because the boot is smaller, allowing your fingers to get in there.
There are several lengths to choose from (for your application):
•Standard Length (99% of LS engines)
•LS9 ZR1, (0.75" shorter)
•LS-Tall Valve Cover (0.75" longer)
•LS-Truck (1.5" longer)
Available in three colors: (PLEASE SPECIFY COLOR WHEN ORDERING)
1.Red wire with Red sleeve
2.Red wire with Black sleeve
3.Black wire with Black sleeve
4.Blue wire with Black sleeve (only available for LS9 ZR1)
Pricing Thread Here.
MTI Racing
1190 Hayes Industrial Dr
Marietta, GA 30062
Kevin Esposito
770-919-7774
MTI Racing Kevin is offline   Reply With Quote
Old 02-16-2011, 04:45 PM   #2
MTI Racing Kevin
Drives: 2010 Camaro
Bump
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
MTI Racing Colored Plug Wires MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-19-2011 11:27 AM
Spark Plug Wires Hutch52 5th Gen Camaro SS LS LT General Discussions 3 01-07-2011 08:10 PM
OEM wires and spark plugs? jlugo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 12-22-2010 06:15 AM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 02:11 AM
