Old 02-08-2011, 07:38 PM   #1
crewxp
Drives: 2LT RS Summit White Camaro
How-To on how to install AAC sidemarkers?
Is there a how to on installing AAC sidemarkers? The 'authorized' dealer near me quoted me 100 to install footwell lighting with switch, 150 to install sidemarkers, 250 to install after burners, and 350 to install the halos.
I had them only pre-wire my cupholder lighting because its further away from the center console, but they left a giant power cable along the front side of my car. they didn't tuck it in :/
I didn't get any instructions on how to install them. i looked on the dvd it came with as well as the papers. are they something i can do myself?
crewxp is offline   Reply With Quote
Old 02-08-2011, 07:52 PM   #2
Alain
Alain's Avatar
Drives: 2010 SS, RS, Manual. 2012 F150, FX4
the side markers are easy to install man. DO NOT PAY to have it done, it'll take you 20 minutes at the most.
i've had my side markers from AAC since they first started making them and they are freaking awesome !
It's gonna be hard to tell you without pictures but i'll try. If you look inside the wheel well you'll see that there are little screws that keep the lining attached to the car.
1- take those screws off, take as many off as you need for you to be able to peel the lining back.
2- peel the lining back and you'll see a little tab on the stock side markers, you'll need a screw driver, take the screw driver and push in the little plastic tab which will make the side marker pop out.
3- once you pop out the stock side marker, just unplug the wire remove it, take the LED marker, plug it in and snap it into place.
4- then put the wheel well lining back and put the screws back on it.
that's it.
like i said, it's tough without pictures (i didn't take any when i did it). once you start the job you'll see how easy it is, it'll make sense to you.
good luck, let me know how you make out.
Alain is offline   Reply With Quote
Old 02-08-2011, 08:24 PM   #3
camaro2lt
camaro2lt's Avatar
crewxp give me a call and i can walk you through how to install everything
Old 02-08-2011, 08:35 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
http://www.camaro5.com/forums/showpo...&postcount=626
This works, but I found a much easier way. For the rear markers. Let's say rear right marker. Lay on ground with your head lined up with the end of the car. Now stick your left arm up inside of the rear quarter panel and you should be able to go all the way up to the side marker. Repeat the process on the left side, but with your right arm.
Note: I have JBA 3" exhaust, so it may not work with with the stock set up
Click to view my build thread
Old 02-08-2011, 09:43 PM   #5
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I just helped someone install their sidemarkers. Takes 20 minutes tops for all 4. DO NOT pay someone to do this for you.
Old 02-08-2011, 09:54 PM   #6
camaro2lt
camaro2lt's Avatar
i think the rears were easy but the fronts were a little pain
Old 02-08-2011, 10:11 PM   #7
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I foudn it just the opposite. I used a crowbar to install my rear ones, but I am lowered and have pretty large arms.
Old 02-08-2011, 11:42 PM   #8
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
was able to get the rear side markers by reaching my hand up on the inside, popped out pretty easy. actually didnt need to pop off the wheel well lining for the front ones, able to pull it back enough and use a screwdriver to reach the tabs. you DONT need to pay someone to do this, pretty simple install
pyr0b0y is offline   Reply With Quote
Old 02-09-2011, 02:21 PM   #9
crewxp
sure thing. im going to install it when its not freezing outside (this weekend) and I will try the above. If all else fails, I will most definitely give you a call.
Old 02-09-2011, 08:24 PM   #10
camaro2lt
camaro2lt's Avatar
sounds good just call whenever.
Old 02-10-2011, 10:29 AM   #11
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
that's it.
Thanks for chiming in with good advise guys!
AACstyle is offline   Reply With Quote
Old 02-12-2011, 05:05 PM   #12
crewxp
Installed my rear sidemarkers today. The above method works, you just have to have skinny arms and and strong fingers to push the lever. Plug and play really
They really do look awesome at night though. They definitely are a must on a car.
I think I may have a problem though. Like 6 LEDs ok the left sidemarkers sometimes flickers off and on. And the right side seems like it has less glue than the right. It sticks out a bit more than the left.
Anyone know if AAC is open on the weekend?
Old 02-12-2011, 09:58 PM   #13
wolfeman
Drives: Future 2011 Camaro
wolfeman is offline   Reply With Quote
Old 02-12-2011, 11:24 PM   #14
crewxp
pics of what?
Is there a difference between AAC and Showstopper sidemarkers? crewxp Cosmetics and Lighting Modification Discussions 58 03-29-2011 06:47 PM
Help with AAC dual halo install The Stig USA - Mid-Atlantic 13 01-30-2011 04:53 PM
Attention: The 1st Annual AAC Open House / Meet & Greet/ BBQ/ Mardi Gras Experience! AACstyle USA - Southeast 16 07-14-2010 12:29 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
