JUICEDMOTORSPORTS
Old 02-09-2011, 10:24 AM   #1
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
CAI maintenance / service
Just curious from the current owners of the C.A.I. intake what is required to maintain and service the unit? This will be my first purchase of an after market intake so I was just curious if and how often you are require to clean or replace the cone, etc. etc...
Also, why in the world is the black intake more than the ceramic? Thought it would be vise versa...
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 02-09-2011, 10:31 AM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
25K miles on the filter. Some people will just buy new. Or you can use a cleaning/recharge kit.
CAI said the lastest black intakes are ceramic coated then the black put on. But in all fairness to the early ones, the black coating isn't just on the tube it's the whole system. Ceramic is just the tube.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-10-2011, 12:54 PM   #3
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Smile
We offer recharge kits for $12.95 how often you clean/recharge it is totally dependent on the amount of driving you do as well as the conditions you drive in. You should be able to do a visual inspection of the filter and see when it's getting real dirty and clogged.
The black powdercoat is more because we do the powdercoat over the ceramic coating. Also the entire box gets coated where the ceramic silver set up gets Jo finish on the box.
I hope this helps, thanks for choosing CAI Inc. I know you will be happy with your choice!!
Sales @ CAI Inc is offline   Reply With Quote
Old 02-11-2011, 10:29 AM   #4
Jus1dab
Jus1dab's Avatar
I'm also interested in buying a CAI intake. Does in come pre oiled? Are there any on line specials? When I recieve my income tax check it will be burning a hole in my pocket.
Jus1dab is offline   Reply With Quote
Old 02-11-2011, 11:06 AM   #5
Phase V
Summer
Phase V's Avatar
Drives: 2010 2SS/RS IOM w/ Black Stripes
Send a message via AIM to Phase V Send a message via Yahoo to Phase V Send a message via Skype™ to Phase V
I have the dry version and just brush mine out and rinse with water unless they also sell a wet version
CAI intake w/ ADM air scoop, Rotofab W/W Reservoir, Hurst Shifter, Skip-Shift Eliminator
AAC lighting, Kooks headers w/ high flow cats and Borla ATAK cat-back
Restoring or need parts for a Chevy. Look no further than Don's East Coast Restorations
Phase V is offline   Reply With Quote
Old 02-11-2011, 12:09 PM   #6
brantley847
v It bites.
Last stupid question...
I know with a basic air filter you just remove...clean or replace. With this intake are you just replacing/cleaning or is it required to clean the tube as well?
2011 2SS/RS
Old 02-11-2011, 12:59 PM   #7
montreal2010yellow
montreal2010yellow's Avatar
My understanding is that there should'nt be any dirt in the tube. If so, the filter is doing it's job.
Old 02-11-2011, 01:26 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
With the filter off, run your hand up inside the tube and feel around. There shouldn't be any dirt or oil up inside the tube but if there is, it would be a good time to take if off and rinse it out. Know that there will probably be a little bit of oil from the PCV line between it and the TB, unless you have a catchcan.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-11-2011, 02:50 PM   #9
Sales @ CAI Inc
Our filters all come oiled, there should be no need to do any type of cleaning to the intake tube.
Old 02-11-2011, 03:00 PM   #10
IndeedSS1
IndeedSS1's Avatar
I didn't think CAI offered a dryflow filter.
Old 02-11-2011, 05:55 PM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I have the black and it is awesome looking. The sound at WOT is amazing. It screams muscle. Excellent and easy install.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 02-12-2011, 09:08 AM   #12
brantley847
v It bites.
The black does look pretty damn sweet....that is my biggest problem right now, deciding between the two.
2011 2SS/RS
Old 02-12-2011, 11:26 AM   #13
mikey8
mikey8's Avatar
Drives: 2017 2SS
I have the original, with about 10K miles. I haven't done anything. The screws that hold the top on, don't seem to lock anymore, just spin at a closed position. It still fits securely and doesn't feel loose. I'm sure I must have over tightened them. The filter itself still looks clean and new. I'm very happy with the CAI intake. The black one wasn't available, when I bought mine.
mikey8 is offline   Reply With Quote
Old 02-12-2011, 01:42 PM   #14
Phase V
Summer
Phase V's Avatar
I could have sworn when I bought mine last year I had the option to choose wet or dry. im sure im just crazy. I love my CAI either way
What is the real Service Interval Verio Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 12-27-2013 12:44 PM
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 10:26 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
SS A6 or M6 faster?????? MY2010SS 5th Gen Camaro SS LS LT General Discussions 275 05-20-2010 05:15 PM
