Cold Air Inductions
Old 02-09-2011, 01:08 PM   #1
kelsanova
Drives: 2010 Chevy Camaro 2SS IOM/blk rally
Question Backlight for grill
I have seen some camaros with a backlight behind the grill. I couldn't find any other threads on this because I'm not really sure what they are called. For the people doing this...where is it located? And is this just an LED strip from AAC or what? Just curious about what they are and how they are installed. Thanks for the info!
Kelsanova
kelsanova is offline   Reply With Quote
Old 02-09-2011, 01:11 PM   #2
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
Talk to AAC.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 02-09-2011, 11:47 PM   #3
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
I used an LED Strip wired to a switch under the steering wheel.. Check my Sig
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 02-09-2011, 11:52 PM   #4
thespymaster
thespymaster's Avatar
The pod lights from AAC
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 02-10-2011, 11:17 AM   #5
kelsanova
Thanks fellas.
Kelsanova
Old 02-10-2011, 11:24 AM   #6
kelsanova
Where did you mount them? Pics?
Kelsanova
Old 02-10-2011, 12:53 PM   #7
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
pyr0b0y is offline   Reply With Quote
Old 02-10-2011, 02:58 PM   #8
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
If you are installing the strip you can remove the radiator panel and access the area behind the grill and mount to the bumper reinforcement. We usually use 2'-5' or LED strip to illuminate the grill, depending on the amount of light you are trying to achieve.
http://www.camaro5.com/forums/showthread.php?t=97615
Here is Three feet of our RGB installed in a Camaro grille.
[/QUOTE]
You can do a lot with the strip so if you want to play it safe we sell 200" rolls that will allow you to get creative and really illuminate your vehicle
We have several colors and applications for our 3528 high-powered LED strip.
The great part about this product is the ease of use and installation! It is made to be used in just about any case where you need to add lighting.
- Can be cut down to any length and still be re-used.
- Real 3M self-adhesive backing makes installation a breeze.
- Super-Bright output, it only takes a couple inches of this strip to highlight an area of your Camaro.
We have this strip available in:
  • Cool White
  • Warm White
  • Blue
  • Red
  • Green
  • Amber (Orange)
  • UV Purple
  • Hot Pink
  • RGB (Color-Changing)
The Exterior Version is 100% Waterproof and can be mounted on the outside of the car: http://www.automotivelightstore.com/...sexterior.aspx
The Interior Version is also available here: http://www.automotivelightstore.com/...sinterior.aspx
We have pre-made 3' Sections (perfect for grills and trunks) available here: http://www.automotivelightstore.com/1Mflexstrip.aspx
The ColorSHIFT version can change colors and requires a controller: http://www.automotivelightstore.com/RGBstrip.aspx
RGB Color Changing Demo:
RGB Installed in 2010 Camaro:
The fun does not stop there, this is truly a universal product it can be used in your home as well!
Use it to make cool wall art:
It took less than 5 ft of this to make this busa shine!:
www.AACstyle.com
AACstyle is offline   Reply With Quote
Old 02-10-2011, 03:03 PM   #9
pyr0b0y
need....more....hp
pyr0b0y's Avatar
really like the UV purple.....any pics of lighting on a yellow car?
Old 02-10-2011, 04:23 PM   #10
AACstyle
AACstyle's Avatar
We actually have a Rally Yellow Camaro here right now getting UV Halos and Footwell lights install but no grill lighting, would have been perfect
www.AACstyle.com
Old 02-10-2011, 05:26 PM   #11
pyr0b0y
need....more....hp
pyr0b0y's Avatar
can you post some pics? I was tihnk UV would be good but pics would really help....otherwise i was thinking blue
Old 02-10-2011, 05:29 PM   #12
kelsanova
[QUOTE=AACstyle;2824373]
So, I am buying the ColorSHIFT oracle halos and fogs. Can I just buy the ColorSHIFT leds and wire them in with those? Will that work or will I need a seperate controller still?
Kelsanova
Old 02-10-2011, 06:34 PM   #13
AACstyle
AACstyle's Avatar
UV Purple Looks great on Rally Yellow, especially since this customer already had purple stripes
You got it, you can tie in all the ColorSHIFT strip into the same controller
www.AACstyle.com
Old 02-11-2011, 11:05 AM   #14
kelsanova
Thanks Justin, ordering today!
Kelsanova
led, lighting
