Rick@Livernois
Old 02-10-2011, 08:17 PM   #1
ucfq8
ucfq8's Avatar
Drives: 2010 Orange Camaro 2SS RS
Exhaust rattle - Corsa Cat back just installed
Today I installed my Corsa cat-back on my camaro (L99). There is an annoying rattle sound at certain rpms. When im stopped and I rev the engine (till about 2000) and let go, the rattle stops. But as soon as the car is idle, the rattle is back. I think its coming from the brace that the exhaust crosses over. If it is, will washers do the job to give space ? If not, what kinds of braces are there to replace the stock one ? One more question, at about 4000 rpm and hitting the gas pretty hard, there is a whistling noise coming out of the back ?? Is this normal ?
ucfq8 is offline   Reply With Quote
Old 02-10-2011, 08:38 PM   #2
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
my corsa came with a different cross brace and spacers.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 02-10-2011, 09:13 PM   #3
ucfq8
ucfq8's Avatar
really ?? where did you buy it from ?? and what kind of cross brace is it ??
Old 02-10-2011, 09:52 PM   #4
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: SW 11' 2SS/RS LS3 Vert, Blk/Blk
My friend has a Corsa cat back and used the stock brace, he initially had a rattle, took it back and they tightened the mounts some how and has had no noises since. I posted a similar question about Flowmasters hitting the brace, I was told to have someone push the exhaust up while tightening he exhaust, and use a few washers for good measure.
Good luck!
Drago77 is offline   Reply With Quote
Old 02-10-2011, 09:55 PM   #5
my Corsa has no rattle
Old 02-10-2011, 09:59 PM   #6
Gbusy06
Tap Out
Drives: 2011 Camaro SS A6 SGM
You can use a few washers equal to a half an inch, placing them between the brace and undercarriage in order to create space between it and the exhaust. I had to do this with mine. No more rattles!!!
Gbusy06 is offline   Reply With Quote
Old 02-10-2011, 10:05 PM   #7
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
is it 3" or 2.5"? If it is 3" you will probably have to get a different cross brace or use washers...If it is 2.5" you just need to adjust how the exhaust is aligned. I had the same problem with my borla until I put the car on ramps, loosened the exhaust couplers, and used a floor jack to adjust how the exhaust fit on the car....
KnightRiderSS is offline   Reply With Quote
Old 02-10-2011, 10:06 PM   #8
2PitbullSS
2PitbullSS's Avatar
Drives: 2010 Camaro SS & 2003 Z71 w/6" lift
If you can get the car on stands, get under there loosen the clamps and GENTLY jack up the entire system at the x pipe/resonator. Once pushed all the way up tighten everthing back down. Once you release the jack it will sag just enough but not enough to rattle on the cross brace. It took me a couple times to get it.
416ci VVT Stroker built by LETHAL RACING
2PitbullSS is offline   Reply With Quote
Old 02-10-2011, 10:07 PM   #9
2PitbullSS
2PitbullSS's Avatar
oops beat me to it...
Old 02-11-2011, 04:56 AM   #10
y2k king
y2k king's Avatar
gmpartsdirect.
the brace came in the box like a kit from corsa.
10/28/2010 got it
Old 02-11-2011, 11:38 AM   #11
kaos_ss
kaos_ss's Avatar
Drives: 2013 Camaro ZL1
Corsa :(
I had a L99 and had the same problem with my Corsa Exhaust. The replacement resonator hits on the tunnel brace. I used the spacers that came with the exhaust but it didn't solve the problem. I eventually got rid of the exhaust and went with another brand.
You can always wrap it with that exhaust wrapping!!
kaos_ss is offline   Reply With Quote
Old 02-11-2011, 12:06 PM   #12
SwedeandBlondie
SwedeandBlondie's Avatar
Drives: 2011 Black 2SS/RS L99 on order
If you do as the others have said and raise the resonator up to where it contacts the bottom of the car, then tighten everything back up, you'll be fine. It'll settle down to where it doesn't contact the bottom of the car. Plenty of room above the brace after I did that.
Hardest part for me was getting the tips in the same spot on each side. My OCD was really ba that day LOL
Frank and Kim
2011 SS/RS Black on Black (Born 11/18/2010)
2011 Hemi Ram Crew Cab 1500 4X4 Black on Black
2009 HD Street Glide
2005 HD Fatboy
SwedeandBlondie is offline   Reply With Quote
Old 02-12-2011, 04:29 PM   #13
midnighter
Drives: nothing
That's not good.....I guess I'll research around before getting a catback.
Old 02-12-2011, 07:24 PM   #14
Tricky's SS
Tricky's SS's Avatar
Drives: 2010 Pace Car
Just installed my Corsa the other day. It came with spacers for the brace.
Tricky's SS is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
CORSA CAT BACK EXHAUSTS @ BEST PRICES! MoranoRacing V8 Bolt-Ons & Tunes 9 08-24-2010 10:09 PM
What did you do with your stock exhaust when you replaced it with a cat back system? Silver Bumble Bee Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 08-12-2010 05:48 PM
Corsa cat back or GMPP axle back exhaust? verboten V8 Bolt-Ons & Tunes 3 04-03-2010 05:07 AM
Just installed my Magnaflow 3" cat back system...first im[pressions Heelhook22 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 02-06-2010 12:50 AM
