Old 02-04-2009, 04:32 PM   #1
1982camaro
1982camaro's Avatar
Drives: 1982 camaro
how reliable is the LS3? and why so big?
i have been thinking about the reliability of the LS3 engine as a daily driver. For some reason this engine seems more like a weekend toy type of engine that is only for 1 or 2 days a week.
is there any issues and how many miles can these engines last with proper maintenance? and how have they done being driven 7 days a week?
i thought that the 23 mpg rating was for the manual also but cylinder shutoff only works on autos. What should the epa be for a manual SS?
And why is it such a huge engine at 6.2 liters? Did GM really need that much size to make 420 horses? I heard Ford can do 400 HP with just 5.0 liters.
1982camaro is offline   Reply With Quote
Old 02-04-2009, 04:57 PM   #2
Tal
Drives: Old
I'm going to say this as nicely as possible but learn to use your shift key, especially at the start of a paragraph.
On to your questions though, there's no reason the LS block can't be reliable. It's a solid mix of proven design with modern technological improvements.
Manuals are geared different than autos, we don't have solid mpg numbers for any of them yet though so don't worry about whatever the difference might or might not be.
As for the engine, it's high displacement because it wasn't designed for little girls! Seriously though GM's LS block doesn't take any more space or weight than many 'smaller' engines. GM has a 2.0 liter that puts out 260+ horsepower, but it's a very different design. As for Ford their 4.6 liter puts out a piddly 300 horsepower while they use a supercharger on their 5.4 liter to get 540 horsepower. Throw a supercharger on the LS3 and you have the LS9 used in the ZR1 which is 638 horsepower. A full comparsion would take a long time, suffice to say my opinion is the LS block is more impressive, mainly since Ford's V8 is to heavy to even come close properly balancing a car, the GT500 for instance has a ridiculous 58/42 weight distribution problem. Some Ford fans love their heavy block anyway as it does have advantages.
Tal is offline   Reply With Quote
Old 02-04-2009, 05:06 PM   #3
garfin
Resident Disciple
garfin's Avatar
Drives: 2010 CTS-V 6MN '98 Camaro SS (Sold)
Just curious as to what you're basing your conclusion on when you say "for some reason" the LS3 is a "1 or 2 day/week "toy"?
You gotta know that the LSx motors are rock solid and a great example of American engineering. The engine has only 2 enemies - water and mechanical over-revving.
My friend is the original owner of his '98 T/A that he has used from day 1 as his daily driver - winter and summer (He lives in Ottawa, Canada). The car has over 325,000 km. on the clock (203,000+ mi) and the engine (completely stock) has never been cracked open! The car has seen its share of autoX events and track days...
Routine maintenance according to the book, coupled with not abusing these engines (i.e. flooring the gas pedal when the engine is cold!) adds up to solid dependability and long engine life.
As well, it appears that when the new Ford 5.0 V8 engine finds its way into the Mustang for the 2010 MY, it will be making somewhere between 325 and 350 HP - not 400 HP as you suggest.
http://www.leftlanenews.com/next-gen...t-engines.html
Even if it does make 350 HP, there is perhaps a 1 HP/liter difference in output between the LS3 (depending on which version you compare) and the new Ford engine(with 3 valves/cylinder vs. the LS3's 2 valve engine?).
The question is, will Ford be able to match the 6.2 L engine's fuel economy with their 5.0 L engine?
... and who knows what the LS3 might be rated at by the time Ford's new engine hits the streets?
Best regardSS,
Elie
2010 Cadillac CTS-V 6MN Thunder Gray
1998 Camaro SS # C079 SOLD
garfin is offline   Reply With Quote
Old 02-04-2009, 05:15 PM   #4
blackZbandit
blackZbandit's Avatar
Drives: BLACK ON BLACK 2012 CAMARO SS
Elie always brings words of wisdom... you sir are a scholar and a gentlemen
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig****
blackZbandit is offline   Reply With Quote
Old 02-04-2009, 05:20 PM   #5
1982camaro
1982camaro's Avatar
Drives: 1982 camaro
Thumbs up
I keep on hearing about this 5.0 "coyote" engine that is supposed to make 400 hp
Im just the type of car person that gets impressed when a small displacement NA engine can make a lot of power like a honda 2.0 NA 4 cylinder 247 hp engine straight from the factory.
That gm 260 hp engine is a turbo
im asking these questions because i am seriously considering an SS camaro as a daily driver for at least five years.
Old 02-04-2009, 05:35 PM   #6
bolteon593
Drives: 2011 GT500
I like how you manage to not mention that the honda engine your talking about (I'm assuming it's the 237hp engine in the S2000) gets 25% worse gas millage while having one hundred less lbs of torque!!!! and 23 less hp... (when comparing it to the turbo charged I4 found in the colbalt ss)
each engine is engineered differently, i'd rather have more gass millage, more hp, much more tq and a turbo then to have the pride (?) of knowing my engine is mediocre and NA....
the ls3 is a hell of a motor... it's base wouldn't be used in the ls9 if it wasn't. go educate yourself, then be impressed. "car person" hah.
bolteon593 is offline   Reply With Quote
Old 02-04-2009, 05:46 PM   #7
1982camaro
1982camaro's Avatar
Drives: 1982 camaro
im not saying the ls3 motor isnt one hell of a motor.
the s2000 came out 10 years ago and as far as gas mileage, they both do the same when doing mixed driving which is 21 mpg
Old 02-04-2009, 05:47 PM   #8
Tal
Drives: Old
If you want high horsepower, naturally aspirated, lower displacement you mean you like DOHC engines. If that's your thing, GM doesn't do that on a V8, but DOHC isn't all roses as they weigh more and takes up more space per liter of displacement.
IF what you care about are just two numbers HP/displacement and being naturally aspirated Honda's F22C1 does have nice numbers but as a total package it's fairly mediocre by modern standards. The power curve is weak, and it's less fuel efficient at 18/25 vs 19/28 for similiarly weighted cars (S2000 vs Solstice GXP, so slight weight and extra gear advantage for the Honda actually), it just doesn't keep up with GM's 2.0T or several other modern 4's.
Old 02-04-2009, 06:00 PM   #9
1982camaro
1982camaro's Avatar
Drives: 1982 camaro
i like all kinds of engines, just seems like anyone can make big power with a big displacement engine.
Old 02-04-2009, 06:00 PM   #10
bolteon593
Drives: 2011 GT500
The s2000 came out 10 years ago and as far as gas mileage, they both do the same when doing mixed driving which is 21 mpg
Cobalt is 22/30... not sure how you get a mix number below it's city millage...
The s2000 did come out 10 years ago, for 28k back then that's about 35k these days; great comparison.
*sigh* some people just dont get it.
Old 02-04-2009, 06:02 PM   #11
jesserayjames
jesserayjames's Avatar
Drives: Drives a 2012 IOM 2SS/RS 6M
Cool
Don't worry about it, just go buy yourself a V6, sounds like you don't need more than 300HP.
CAMARO 2SS/RS 6M
jesserayjames is offline   Reply With Quote
Old 02-04-2009, 06:07 PM   #12
1982camaro
1982camaro's Avatar
Drives: 1982 camaro
i'm just going according to motortrend. it has 21.7 mixed for the cobalt ss.
the s2000 is impressive for being a decade old. shows honda is 10 years ahead of gm in the 4 cylinder category.
im not comparing prices, thats a whole different subject
Old 02-04-2009, 06:10 PM   #13
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
Pushrod is the American way, don't like it, go buy a bimmer or somethin
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 02-04-2009, 06:11 PM   #14
1982camaro
1982camaro's Avatar
Drives: 1982 camaro
the v6 is doing 0-60 in 6.2, my prelude is around the same area.
i need something faster. The v6 camaro is not going to be enough.
