Jason 98 TA
Old 02-11-2011, 11:57 PM   #1
AGENT-006
AKA 'Mr. 006'
AGENT-006's Avatar
Drives: 2010 CGM Camaro
Exclamation Someone help me with footwell lighting!
im trying to hook up my footwell lighting..but i dont want it in sync with my domes..i want it on when im driving at night..any tips on how i can do this?
AGENT-006 is offline   Reply With Quote
Old 02-11-2011, 11:59 PM   #2
Alfieboy
Madman
Alfieboy's Avatar
Drives: 2017 1SS
u would need to either hook it up to parking light-headlamp circuit..or a separate toggle switch
Alfieboy is offline   Reply With Quote
Old 02-11-2011, 11:59 PM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
put in a switch.
Old 02-12-2011, 12:00 AM   #4
PoorMansCamaro
Drives: Really Slow
or connect to the fuse that's connected to your cluster lights.
Old 02-12-2011, 12:02 AM   #5
Viper595
Redline drop, or go home
Viper595's Avatar
Drives: 2010 Camaro SS
Originally Posted by PoorMansCamaro View Post
put in a switch.
this, sir.
I can fix cars. I can't fix people.
2010 Camaro SS #123444 - K&N Typhoon CAI, Muffler Delete, MPD-1 Spoiler, Headlight Armor Blackouts. Mods to come: longtubes/tune/flux capacitor
Understeer
is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Viper595 is offline   Reply With Quote
Old 02-12-2011, 12:06 AM   #6
AGENT-006
AKA 'Mr. 006'
AGENT-006's Avatar
how wud i put in a switch? lol
Old 02-12-2011, 11:01 AM   #7
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Buy a single pole single throw switch. Cut the power wire and hook one side of the cut to one terminal on the switch and the other side of the cut to the remaining terminal on the switch.
Jayrcr3 is offline   Reply With Quote
Old 02-13-2011, 07:52 PM   #8
showstopper
Drives: 2010 RS/SS
I think the easiest way would be is to tap into the ambient lighting. If you remove your headlight switch it is the yellow wire with the black stripe. This should do the trick. Pm me with any questions.
showstopper is offline   Reply With Quote
Old 02-14-2011, 08:15 AM   #9
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
Would it be too bright to be on at night? I just installed the blue led from Ivan at Southwest Speed (Thanks Ivan), and it is bright as heck. I love the blue, but if the foot well lights are as bright then it would be too bright to drive with them on I would think.
2010 Camaro Black with White Stripes, Jannetty Racing Roto-Fab CAI, VMAX Ported Throttle Body, Long Tube Headers, GMPP Axel Back, Emblem Pros Custom "VOODOO" Under hood Bow tie, Chrome Gill Inserts, HUD plate, Sparks Performance White SS front and rear Plate MPD-1 Spoiler
Hired Gun is offline   Reply With Quote
Old 02-14-2011, 09:40 AM   #10
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
you go to your quad pack gauges and tap the source there, it will work with your interior lights dim too
camaro4mybday is offline   Reply With Quote
Old 02-21-2011, 11:13 AM   #11
hendrix05
Drives: 2010 2LT, Non-RS, red
Hey folks, brand new guy around Camaro5. Bought a used 2010 V6, LT2 in October and I am starting to get the bug on customization.
I am looking to hook my footwell lights (which I plan to buy from AAC) up to the dome circut above the gas pedal like most folks on the forum are doing. I have the led dome light already. I also would like to also turn the footwell lights on while driving with a dimmable switch that I plan to install on the dash, to the right of the steering wheel. I don't want them on full intensity while driving, but just kick em on a tad.
My questions are:
Can it be done? I am thinking just tap into dome circut, then also install switch and have a seperate power source for the dimmer switch. then hooking the lights to both. Do I need any kind of relay for this?
What kind of dimmer switch do I need? Where can I shop for one?
Any help with this would be great! I am a intermediate wiring guy, but I wanted to get it right in my head before I begin.
Thanks,
hendrix05 is offline   Reply With Quote
Old 02-21-2011, 06:44 PM   #12
camaro4mybday
"Camaro Joe"
simply go to your 4 gauge pack and tap the interior light wire, you do not need a dimmer switch it will dim with your interior, as for a switch switch the ground instead of the power
Old 02-21-2011, 07:07 PM   #13
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
That's the best advice so far. Camaro4mybday right on
chevy 3 is offline   Reply With Quote
Old 02-22-2011, 07:54 AM   #14
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
My footwell lighting is currently connected to my dome light. If I wanted to install a switch so that I could turn them on manually what would I need. I want the lights to still come on with the dome, however i want the option to turn them on manually also. Would I need a three position switch or can I just wire the dome light to the nutral and the constant power to the positive terminal on the switch and wire the Footwells lighting to both.
Another option I was thinking about was just leave them wired to the dome directly and install a jumper to the switch so I can turn them on manually also.
Any Suggestions?
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
HOW TO WIRE REAR SEAT FOOTWELL LIGHTING overhaulengines Camaro DIY & HOW-TO instructions & discussions 40 04-26-2014 12:23 PM
AACstyle LED strip vs. CCFL footwell lighting binlow84 Cosmetics and Lighting Modification Discussions 29 11-06-2011 12:50 AM
ABL lighting and Footwell Light Install? JProberts USA - Mid-Atlantic 3 02-25-2010 11:17 PM
AACStyle footwell lighting problem TRSS2 Camaro DIY & HOW-TO instructions & discussions 8 01-23-2010 07:41 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 10:32 PM
