| Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress. |
Thread Tools |
#251 | |
Only drives on Sundays
Drives: 11 2SS/RS, Black/Inferno, L99 A6 Join Date: Feb 2011
Problem is that I did the gears, UDP and all the suspension mods at the same time. My guess is the gears. I experienced something similar on my old GTO when I went to 3.91 gears and really gained nothing. However, I love the gears, because it made the around town driving GREAT with the torque converter. It had been sluggish and rev happy with the TC alone. Padre |
#252 |
Wild and Cammed
Drives: 2002 Camaro SS Join Date: Jan 2011
Yeah thats true. You just don't have the power to weight ratio to get the full benifit of the gears? I had to remove my rear springs because when I drag raced it it was just to stiff and it wouldn't squat right. Therefore all it did was spin.
#253 | |
I should add that since I'm running 112.78 now in 75* and my previous best was 112.89 in 60*, I SHOULD be over 113 now. So technically, it is running a tad faster, just not what I had expected. Padre |
#254 |
Wild and Cammed
Yeah I should of looked at that! I think the best way to judge it is the butt dyno. as long as it's fun its good enough for me
#255 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS / 1951 Mercury Join Date: May 2009
I have a theory or two...
Thanks for taking all the vids and doing the write-ups very interesting.
2010 Camaro SS | LT's Cats UD CAI Tune DR |12.37@112
1951 Mercury | Chopped | SBC 1998 Formula | 348 TH400 88mm | 9.40@145 sold 2000 Camaro | 348 TH400 150 NOS | 10.0@134 sold ~All installs and tuning by Speed Inc. |
#256 | |
![]() Padre |
#257 |
12.19@112.89 / 1.65
Best from last outing (do I have this right or can you correct?) 12.381, best mph 112.88, best 60' 1.810 I'm not sure if I have your best ET from your last outing posted here or one of the bests. My thoughts: -12.3 on a 1.8 is spinning or it left lazy. I'm guessing it's spinning off the line? -Probably won't be able to really see the power gain until the 60 ft gets back to a low 1.6... I'm thinking the MPH will go up with a better 60 ft. -I would be curious if you could try different launch techniques to try to get to a 1.59 60 ft. -I'm also wondering what 6200 shift points would do.
#258 | ||
I think the main reason for going from 1.8's back into 1.6's is the launch technique with the new gears and suspension. The 1.8's were with significant spin. Once I figured out the launch (jab it to about 75% throttle, let it hook, then jab it to 100%), 1.70's and 1.6's were no problem. I just ran the corrected numbers on my best times of the night: 12.126 @ 114.394 MPH. Best corrected before the gears, suspension, UDP and EWP: 12.067 @ 114.051 MPH. Padre |
#259 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Padre, before the gears, what gear and rpm where you going through the traps at? And now what gear and rpm are you going through at? I was a thunder racing a couple weeks ago discussing a situation like this. I can't remember exactly, but what they said is when they have put gears in an l99, it slowed down because it shifted to the next gear a little before the traps. They had to retune the shifts to get it to go through in a lower gear. I dunno, but if you can't run it out without shifting, I see that slowing you down. 3.73 might have been a better choice. I'm just speculating for now till I see your response.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab |
#260 | |
I do agree 3.73's might be a better gear, but I do like the 3.45's because it was basically cheaper. ![]() Padre |
#261 |
Thanks for all the info Padre, one of my favorite threads on the web.
So basically traction is a big issue right now. Do they make QA1's for the 5th gens?
#262 | |
I think Mickey Thompson DR's would give me the 100% jab on the launch that I am looking for. But I don't see below 1.60 without more power. Oh, I forgot, I got under it yesterday: one U-mount of the rear sway (not on the links, but where it bolts to the frame) is partially pulled out. Still appears to work. I'll get a pic later, but it was that way for all my runs yesterday, including the 1.6 and 1.70's. Padre |
#263 |
Very weird
#264 |
I'm not familiar with the Pedders stuff, but if the suspension stuff is all focused on handling it's not necessarily going to help with drag racing. I'll poke around, I'm curious. I've run multiple sets of QA1's on 4th gens, I'd personally be interested in a front set for a 5th gen. My buddy is running double-adjustable Strange shocks in his 7 second drag radial 4th gen, so I'm learning more about those too.
I kinda forgot you are running Nittos. I never worked them too hard in the past, but I did go low 1.6's with some back about seven years ago. MT's would be better for sure, they are softer by a wide margin. But if your suspension is real stiff right now, maybe your car has less weight transfer now...
#265 | ||
#266 | |
Padre |
#267 |
That would help weight transfer for sure. I took them off my 4th gens.
#268 |
OK, I removed my front sway bar completely.
Also pulled the fog light to let air directly in on the air filter. A gimmick, yes, but it was easy to do. I have a piece of grey foam to secure it from water when not racing.Last chance at bolt-on 11's: tomorrow night aty Steele. All the other tracks in the SE are close for the NHRA bracket finals in Montgomery this weekend. Padre |
#269 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
If traction is a problem what about some better tires? But you need to drive to and from the track, correct? I guess you could always swap on something at the track. I know that a good suspension will bring great benefits but if I can play devils advocate for a second.My car 60's in the 1.4's, with some spin, with the stock suspension. I do have a set of trailing arms but that's it. And I leave at 1400 rpm. I'm hoping that with the 14.50 slicks I'll be able to leave at 2k and get a high 1.3 with the stock stuff. Time will tell. I doubt that it will do it in GA. Ted will still need to make some adjustments and the weather is gonna suck.
I just think good tires will to more than anything else.Padre, are you comming next weekend?
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#270 | |
![]() With the suspension mods, my traction worsened. I have cut 1.65's with stock + trailing arms and 555r's. I have matched that, but with a staggered launch (roll, punch). So it does have a 1.5 in it, with the 555r's. I just want to get the suspension down first. Then the next step is Mickey Thompsons. If anything, it will be a learning experience to see if removing the front sway gets me back to where I was. Thanks for the input. Hope to see you in a week. ![]() Padre |
#271 | |
Good luck!
#272 |
Run #2 tonight @ Steele:
12.152 @ 113.69, 1.677 sixty, 7.784 @ 89.65 New personal best. Padre
#273 |
OK, here's the rundown on last night at Steele, Alabama International Dragway, Midnight Madness.
This week, two changes: ditched the front sway (it drives fine around town and on the higway, so no worries). Also popped the driver's foglamp to get some cool air on the filter (works like a charm - kept the IAT sensor from getting heat soaked - it was about 9* over ambient in the staging lanes, and ambient in the runs). Very nice night for racing. DA was between 1300 and 1000. Clear, wind died down, big temp/dewpoint differential (good thing). Temps were between 64* and 60*. The electric water pump worked even better in the low temps. This is with the EWP on, motor off, sitting in the staging lanes for 3 minutes. By the time I was staged, it would be at a perfect 180*. First run was a 12.3 @ 112, with a 1.7. I then added 1* of timing. That's it. 1/4: 12.152 @ 113.69, 1.677 sixty 1/8: 7.784 @ 89.65 ![]() ![]() ![]() ![]() Just about as a perfect run as I could hope for. Launched off idle, and you can see, quick steady roll-in, and it hooked perfectly. Meanwhile, they let the big boys run. One fellow must have sprayed oil on the track, because TVWilkes in his new race car (2000 Z28, 410 iron LS-motor, 4:30 gears, slicks, skinnies) pulled a wheelie off the line, but had to dodge the wall before the 1/8th. ![]() Well, the track was shutdown for about an hour for clean up. But they only cleaned it to the 1/8th (didn't help) and the track was worthless. Here's my run against a Honda that runs as good as 12.8 - he treed me as I was struggling just to keep it straight. As you can see, I backed out of it, and went home. All in all, very happy with the performance of the car right now and my new personal best. I think before I go cam, I'll be redoing the suspension - Pedders adjustable coilovers? - no sense in going halfway, especially if I'm going to add another 100rwhp to it.Padre
#274 |
Congrats!!
#275 |
congrats..
Sent via Moody's EVO
OBX headers/Flowmaster AT exhaust/C.A.I. intake/ADM race scoop/RX catchcan/Black replica wheels/Vmax throttle body/JRE tune
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | Today 09:32 AM |
| 2011 Victory Red 2LT/RS, let the modding begin | dianeokie | Member Car Journals | 162 | 04-27-2013 04:22 PM |
| 2011 SS Detnews review - 2011 Camaro SS Fits In With Classic Cruisers | Johnnyma45 | 5th Gen Camaro SS LS LT General Discussions | 21 | 09-05-2010 01:15 AM |
| 5th gen vs 4th gen | JCO2185 | Chevy Camaro vs... | 158 | 07-26-2010 08:16 AM |
| Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) | Tran | 5th Gen Camaro SS LS LT General Discussions | 715 | 07-23-2009 11:05 PM |
