RDP Motorsport
Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress.
Old 02-15-2012, 07:33 PM   #451
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by Padre View Post
Visor fits and folds up (mostly). I took the 7" screen and split it (one part behind visor, other in front), then rebolted it, with just two holes in the visor.
Attachment 336267
Padre
So you have two screens?
SUX2BU is offline   Reply With Quote
Old 02-15-2012, 07:38 PM   #452
Padre
Only drives on Sundays
Padre's Avatar
Drives: 11 2SS/RS, Black/Inferno, L99 A6
Here's the thread discussing my carputer.
http://www.camaro5.com/forums/showthread.php?t=203203
The 7" screen on the visor is a USB auxiliary. With Windows, I can set it to be the primary screen, and the one on the Netbook is unused until I unplug the USB monitor. I also set up the Netbook so that it remains running when closed.
I just unplug all the USB stuff and take the Netbook out into my home to play with tunes or install software or surf. Real easy setup.
Padre
The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos, Blog
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
Padre is offline   Reply With Quote
Old 02-15-2012, 08:30 PM   #453
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Padre
I see what you meant. I thought you had a screen on each side of the visor.
Old 02-28-2012, 04:59 PM   #454
Padre
Padre's Avatar
Rolled past 10k today:
Still waiting for a chance to hit the track.
Padre
Old 03-05-2012, 12:44 AM   #455
SixGracing
The Reaper
SixGracing's Avatar
Drives: 2010 2SS/RS LS3 A6
Attachment 341542
Padre
Bring that sweet ride out here to Vegas. Temps have been in the mid 60's to low 70's and sunny.
Update on my car. The taxman was very delayed this year. Since this $$ was a big part of what was to fund my car it has put my build behind a bit. But, will be starting on the 12th of this month. I am going to start with a NA car like you did Padre and then work into the Procharger. Having it cammed, springs, lifters, CAI, possibly a stall/torque converter and a tune. See what that gets me.. Hopefully get to go down to the Las Vegas Motor Speedway and do a before and after 1/4 mile run. Will be adding the procharger after I play with this setup for awhile. I'll be starting a build thread.
SixGracing is offline   Reply With Quote
Old 03-05-2012, 04:09 PM   #456
SixGracing
The Reaper
SixGracing's Avatar
One more thing Padre, did you ever rule out whether or not the stall/torque converter gained you any hp? For racing would you recommend a TC?
Thanks again!
Old 03-05-2012, 06:28 PM   #457
Padre
Padre's Avatar
With the torque converter, I gained a solid 4/10ths at the track. It's more difficult to compare HP from one stalled car to another, but performance-wise, it's proven.
Good luck with you build! It's hard to be patient for me. I gotta get to the track! Maybe this weekend if the weather holds.
Padre
Old 03-06-2012, 02:56 AM   #458
SixGracing
The Reaper
SixGracing's Avatar
I'm probably just as anxious as you are to see how your car does now with the
D-1SC. Especially since my build will be very similar to yours. Low 11's? High 10's? Should be a pretty awesome whatever the numbers are.
Old 03-06-2012, 12:39 PM   #459
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
I'm gonna guess 10.70ish at about 127-129mph.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 03-06-2012, 01:18 PM   #460
Padre
Padre's Avatar
Bingo. That's my goal, though I want over 130mph.
I'm sure my first run will be a throwaway, but once I get the shifting tuned in, 10.7's @ 130+ or bust!
Padre
Old 03-07-2012, 09:08 AM   #461
2010 4 DW
Drives: White 2010 RS/SS
When you going racing next?
2010 4 DW is offline   Reply With Quote
Old 03-07-2012, 10:40 AM   #462
Padre
Padre's Avatar
Sunday of the weather is clear. Looks iffy now.
Padre
Old 03-07-2012, 11:22 AM   #463
MANNYS2SS/RS
TRI-COUNTY CAMAROS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Padre
Can't wait to see what your new setup does. I haven't had a chance take my to the track either. It started with a vibration after my axles install, now I have to wait for the axles to come in. Keep us posted.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 03-10-2012, 06:21 PM   #464
Padre
Padre's Avatar
Looks clear for tomorrow.
Also, lost 75 pounds:
The Corbeau seat is from my GTO days, just bought a Camaro bracket for it.
BTW, the driver seat weighs 60lbs, the passnger 45lbs.
Padre
Old 03-10-2012, 06:28 PM   #465
mlee
www.Camaro5Fest.net
mlee's Avatar
Drives: Number Twenty-Three
Sweet... can't wait to see the numbers...
Old 03-10-2012, 07:16 PM   #466
10spokess
Wild and Cammed
Drives: 2002 Camaro SS
How much lower are those seats compared to stock
10spokess is offline   Reply With Quote
Old 03-10-2012, 07:36 PM   #467
Padre
Padre's Avatar
It's actually "feels" higher. With my helmet on, I hit the roof. But it's not terrible. It may be because of the straight back.
If I buy a more permanent one (the red matched my GTO but not the SS), I'll get a reclining one.
Padre
Old 03-11-2012, 03:42 PM   #468
Padre
Padre's Avatar
1st 10-sec run:
1.728 sixty spinning
7.099 @ 102.42
10.955 no mph today
Padre
Old 03-11-2012, 04:03 PM   #469
MANNYS2SS/RS
TRI-COUNTY CAMAROS
Congrat's
Old 03-11-2012, 04:15 PM   #470
Padre
Padre's Avatar
Make that 1.62 with a 10.788.
Padre
Old 03-11-2012, 08:23 PM   #471
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
Congrats, Padre! Your build journal inspires me to keep planning, even if the 'real' mods are a year away.
Three of Swords is offline   Reply With Quote
Old 03-11-2012, 08:27 PM   #472
Padre
Padre's Avatar
Planning is half the fun.
Summary of the day:
10.788 w/ 1.627 sixty, 1/8th: 6.942 @ 102.84.
No MPH today (first weekend, needed new sensors). I guestimate 125mph.
Lots of new Mustangs today. For some reason they didn't want to run me.
Nice young lady got a great video, gotta wait till she sends it to me. No videos of my own. All my electronics were off today. Must be the solar flares.
Mr. 10-second Padre
Old 03-11-2012, 09:04 PM   #473
white 2SS/RS
Drives: ADM Built 2011 2SS/RS A6
Congrats Padre!
I would have loved to have seen some mph at the big end, but can't wait to see the vids!
ADM Scoop, CAI Intake, VRPW, GT11 cam, 1 7/8" Stainless Works, 3" Magnaflow, Yank SS3600, 3.45 gear
1.63 60' / 7.39@93.2 / 11.61@115.0
white 2SS/RS is offline   Reply With Quote
Old 03-11-2012, 09:06 PM   #474
SixGracing
The Reaper
SixGracing's Avatar
That is incredible Padre! I remember when litre bullet bikes were the only thing running in the 10's. You're doing it in a Camaro! Freakin bad a**!!
Congrats!
Summary of the day:
Mr. 10-second Padre
Old 03-12-2012, 07:39 AM   #475
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
Great Run Padre, I have really followed your build and it's nice to see those 10's you were shooting for!
Pfadt Suspension, Supercharged, Showstopper 'bling', Pedderized by Bruce and Tuned by Mike Norris Motorsports
CAMARO WIKI Tran Wiki 43 06-05-2013 04:54 PM
2011 Victory Red 2LT/RS, let the modding begin dianeokie Member Car Journals 162 04-27-2013 04:22 PM
2011 SS Detnews review - 2011 Camaro SS Fits In With Classic Cruisers Johnnyma45 5th Gen Camaro SS LS LT General Discussions 21 09-05-2010 01:15 AM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 08:16 AM
Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) Tran 5th Gen Camaro SS LS LT General Discussions 715 07-23-2009 11:05 PM
