Old 12-27-2011, 09:42 AM   #351
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Originally Posted by white 2SS/RS View Post
Awesome stuff Padre! I just read through the whole thing.
I love the step by step, mod by mod log. Well done.
I'm planning on doing something very similar with my L99. I might have to start a thread like this once I really get underway with mine. You've inspired me.
I did notice something though. Go to about the 50 second mark on the Darlington pass and listen. It almost sounds like the engine hangs for just a second once it gets into 4th. Then it doesn't do it in your last vid. Was that you playing with locking the converter or something?
Thanks bro!
Very observant on the vid. With the new cam, the way it shifts and the way the torque converter locks up has changed. Between Darlington and my last run at Steele, I played with the tables.
Basically I zeroed out the TCC Desired Slip tables. A couple of other little things, but that's the main thing. I'm still not completely happy with the Lockup for daily driving. Sometimes it slips too much at highway speeds (70-75mph), which is why my gas mileage has gone down 2-3mpg.
But thanks for the props. I've been doing the step-by-step thing because it's a lot funner this way and I learn more. Plus, perhaps others will benefit.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 12-27-2011, 09:50 AM   #352
Padre
Padre's Avatar
Originally Posted by VanquisherSS View Post
Are you running the cam with the shorties?
Yes, I'm still running shorties!
Originally Posted by Camarowguy View Post
I'd like to see if a swap to long tubes picks up any.
We felt that Longtubes might improve the top end, which is the direction I'm going with this cam and upcoming supercharger. Plus, it's really really fun ringing this puppy out to 7000rpm now! It pulls and pulls.
It would be very interesting to see what happens if I swap out Longtubes. It might be that I'm leaving very little on the table, or the LT's could really open it up. I'm inclined to the former - LT's might gain me ~10hp (guess). I'm thinking it might get me into the 119's, maybe 120.
Padre
Old 12-27-2011, 11:22 AM   #353
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Nice! Great gains, I have the DT Shorties on mine and I've been playing with a blower friendly cam when I bring the car out next year. Good to know someone has had some success and I won't put it in and gain 4hp
I would imagine you'd see bigger gains with LTs if you put the blower or had some heads on there. I'd think it would start to choke up at that point. My .02.
Can't wait to see what you do next!
VanquisherSS is offline   Reply With Quote
Old 12-27-2011, 11:48 AM   #354
white ZL1
Drives: none
Padre
Even with the desired slip zero'd? Hmm... I'm sure you've logged TCC slip and psi? Have you played with the regulator offset at all?
white ZL1 is offline   Reply With Quote
Old 12-27-2011, 12:01 PM   #355
Padre
Padre's Avatar
What's up next is the ProCharger D1-SC.
With that, I have a FAST LSXr 102 Intake Manifold, which on SC'd cars does show 30hp or so. I also have the Nick Williams 102mm Throttle Body, which on centrifugal blowers may be of little or no benefit.
Since I'm at 424rwhp now, I'm shooting for just 600rwhp with the SC setup. I want to be conservative till I get a feel for the car and what the bottom end can hold.
We may also go with a gimmick on the SC, namely using a wastegate. GM High Tech had an article about it recently. Do a Google on "centrifugal blower wastegate" or click here for a scan. It may open up some very interesting options.
We'll also be trying GM's ZL1 fuel pump option.
Padre
Old 12-27-2011, 12:04 PM   #356
Padre
Padre's Avatar
This last trip was my first time playing with the TCC, so when I have time I'll be doing more extensive logging. Until now, all I've changed in the Tranny are the auto shift properties (feel, pressures, speed). I installed the 3200 TC with no changes to the TCC and it worked great, so I made no changes. But the new cam has changed the whole feel, so I need to revisit it.
Padre
Old 12-29-2011, 12:04 PM   #357
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Padre
I'm on the fence about it. I kinda feel with the extra breathing the cam gave you, it might give more gain than you think. You gonna need them with the super charger anyway, but putting them on now would be more interesting.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 12-30-2011, 04:12 PM   #358
Padre
Padre's Avatar
The trigger has been pulled on the ProCharger D-1SC through Atlanta Performance and Fabrication (John Lee).
:seesaw:
Plan is to install it with a 41mm TiAL wastegate, Dual 255 Walbro, 80lb LS3 injectors.
The wastegate will enable us to pulley-down for low-end power and keep the max boost at whatever we want, basically 8-9psi. Maybe even be able to put an electronic boost controller on it.
Meanwhile, to sum up the thread so far:
Padre
Old 01-01-2012, 12:30 PM   #359
white ZL1
Drives: none
:seesaw:
A buddy of mine is doing the wastegate thing on his Novi 2000 powered TBSS. He's also going to go with an EBC, but isn't sure which one yet. Interesting stuff, for sure.
Keep it coming, Padre! You're leading the way for what I want to do for the next 12-16 months!
Old 01-11-2012, 04:25 PM   #360
Padre
Padre's Avatar
Got D1?
Taking the car down tomorrow to start the install.
What do you guys think... should I start a new thread, "Padre's SS, Part II: Supercharged"?
Padre
Old 01-11-2012, 07:29 PM   #361
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
No keep it all together.....this is one of my favorite threads to check when ever I get online...
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 01-19-2012, 04:11 PM   #362
Padre
Padre's Avatar
Half way there!
Should be hitting the dyno next Thursday.
Padre
Old 01-21-2012, 12:16 PM   #363
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
You are going to love your D1SC
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 01-21-2012, 02:17 PM   #364
Fubar
Drives: SW 2SS/RS M6
Awsome build Padre, been watching this for a while.....
Fubar is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
2011 Victory Red 2LT/RS, let the modding begin dianeokie Member Car Journals 162 04-27-2013 05:22 PM
2011 SS Detnews review - 2011 Camaro SS Fits In With Classic Cruisers Johnnyma45 5th Gen Camaro SS LS LT General Discussions 21 09-05-2010 02:15 AM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 09:16 AM
Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) Tran 5th Gen Camaro SS LS LT General Discussions 715 07-24-2009 12:05 AM
