southerncarparts
Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress.
Old 05-16-2011, 10:02 AM   #76
Pro Stock John
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Do you have a recent race weight?
2010 Camaro SS | LT's Cats UD CAI Tune DR |12.37@112
1951 Mercury | Chopped | SBC
1998 Formula | 348 TH400 88mm | 9.40@145 sold
2000 Camaro | 348 TH400 150 NOS | 10.0@134 sold
~All installs and tuning by Speed Inc.
Old 05-16-2011, 10:15 AM   #77
Padre
Only drives on Sundays
Padre's Avatar
Drives: 11 2SS/RS, Black/Inferno, L99 A6
No, but I guessed 3950 pounds with me in it. That's based on 3913 stock weight -50lbs exhaust -50lbs wheels/tires -25lbs battery -25lbs misc +160lbs me. +1/4 tank of gas, +30lbs of tools in the car.
Mas o menos.
Padre
The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos, Blog
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
Padre is offline   Reply With Quote
Old 05-16-2011, 10:29 AM   #78
Padre
Padre's Avatar
I just notice this. I picked up Dynolicious from the App Store for my IPhone. Tried it out on this run:
Couple of things:
1. I used an input weight of 4000lbs.
2. Dayum that thing is accurate!
3. The shift points show me where I can hopefully tweak some more HP.
4. 4.6 0-60 (if I read it right) isn't shabby!
5. How do you like my name for the car? Hehe.
Padre
Old 05-16-2011, 11:02 AM   #79
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Ummmm, I was gonna tell you mine ran 13.59 @110.1 on that app because its supposed to be super accurate....but I figured id get the bs flag. Btw, that was with just a tune a vararam. My 60 foot was a dismal 2.5 seconds and I let off right before the run was over. I honestly feel like I have one of those "freak" cars. Out if all the l99 cars I've test drove, the one I bought felt a hell of alot faster. Who knows?
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 05-16-2011, 11:04 AM   #80
Camarowguy
Camarowguy's Avatar
I'll run it again on some better concrete and I won't let out this time and I'll see what it does. I added a ported throttle body after that run.
Old 05-16-2011, 11:06 AM   #81
Pro Stock John
What are you thinking of about the shift points? Not that I'm always a maven for mph, but I was thinking that you'd be seeing 112-113... Does the pcm lock up your converter in 3rd?
Old 05-16-2011, 11:09 AM   #82
Camarowguy
Camarowguy's Avatar
Btw, I'm loving this thread. Padre, it looks like you gained almost the same from the Shorties and midpipes the same as full lengths, no?
Old 05-16-2011, 11:17 AM   #83
Padre
Padre's Avatar
I have not changed any TCC or lockup features. The only thing I have changed is to increase the shift pressure (by about 50%) and decrease the desired shift time (by about 0.25) on the 1-2, 2-3, and 3-4 shifts.
The 3200 torque converter adds something to the equation that I'm not enough of an expert at. It works fine now. In the past (in my WRX and my GTO), I have tried commanding lock-up in 3rd and did gain MPH, but on the above graph, it would look like another shift.
Just looking at that chart, I noticed the dip in HP on the shift, and as importantly, the length of the dip. So on one run, I tried subtracting more time on the desired shift time, but I didn't notice a change. You can only "desire" so much shift time, I suppose. Maybe I can add more pressure.
Last month, with the torque converter first installed, I had to add time on the 1-2 shift, because it "gulped" on the shift (commanded throttle position even dropped). So adding time cleared that up.
Basically, from my experience, I do suspect that commanding lock-up in 3rd would gain me less than 1 mph. But I haven't tried it formally on this setup yet.
Timing adjustments have helped me fine tune the car more than the initial transmission tune.
Padre
Old 05-16-2011, 11:27 AM   #84
Camarowguy
Camarowguy's Avatar
I suspect the gulp you experienced may be the same thing I get when running the traction control on. If I launch with it on and then tap it off real quick it doesn't do it. My barks the tires pretty hard and I'm thinking that's the issue
Old 05-16-2011, 11:40 AM   #85
Padre
Padre's Avatar
My rough guess right now:
My track results show a combined
+0.365 ET
4.58 MPH
4000lbs
= gain of about 45 HP.
- minus better weather, -5-10hp
No tune (mine was, in the end, just KR reduction timing changes)
So, 35-40rwhp? (Absolute low end = +30rwhp.)
What do LT's, bolt-on only, high-flow cats, with no tune claim for RWHP?
Where's that duck smiley?
Hehehe.
Padre
Old 05-16-2011, 12:00 PM   #86
Camarowguy
Camarowguy's Avatar
That's Awsome. Why does everyone frown on Shorties then? Is your gulp possibly what I mentioned above?
Old 05-16-2011, 12:07 PM   #87
Padre
Padre's Avatar
I think that's exactly it. More later.
Old 05-16-2011, 12:42 PM   #88
10spokess
Wild and Cammed
Drives: 2002 Camaro SS
Dang Lets see those 11 second time slips lol
10spokess is offline   Reply With Quote
Old 05-16-2011, 01:00 PM   #89
Pro Stock John
Again, thanks for posting all the detail mod by mod. With respect to trap speed, I might not be taking into account the raceweight and the overall gearing of the car. Do you finish the quarter in 3rd or 4th? What's next a small gear change?
Old 05-16-2011, 01:14 PM   #90
Camarowguy
Camarowguy's Avatar
If I put mine in sport mode it doesn't do the "gulp" but it doesn't shift as hard as in drive. I wonder if I can swap this around in the ECM?
Old 05-16-2011, 01:16 PM   #91
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
Awesome thread Padre, been following each up grade and trying to keep up on the upgrades. Can’t decide if I want to go high flows next or gears, any thoughts? I don’t have any tune and trying not to use one until later down the road. Thanks a bunch for sharing.
Halltech, VMax, BBK Headers & X-Pipe, Solo Cats, BMR Level 2 Suspension, CCW SP16a Wheels 10"/11.5", 1LE 3.91's, JRE Tune
Halltech CAI, VMax TB, BBK Headers, Solo Performance H/F Cats, BBK X Pipe, Muffler Delete, BMR Suspension, 1LE 3.91 Gears,
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers
& Side Vents, SS Fender Badges, 6.2L Cowl Lettering, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 13.017 @ 108.63)
AC is offline   Reply With Quote
Old 05-16-2011, 02:43 PM   #92
Padre
Padre's Avatar
They are related somehow, because I did not lift on the throttle, but the reported TPS dropped from 84% (what the computer sees as wide open), to the 40%'s or somesuch. So something in the computer backed you off the throttle like traction control does. But I had traction control off, so the exact cause of the "gulp" is unknown to me. But the fix, for me, was to add more time (back in) to the desired shift time. Just a gut feeling, and it worked.
Exactly. On the chart above, you can see the 3-4 shift at about 10.0s. So I'm in 4th for just 2.1s.
So I have a 3.45 differential from an M6 and it goes in this week (hoping). A6 differential is 3.27. That ought to stretch out the time in 4th, moving earlier the 3-4 upshift. I haven't done the math yet, but I know I'll be happy with an earlier shift.
Anybody want a slightly used A6 3.27 diff? It actually would be great for a 3.73 gear swap from a vendor like Jannetty, and then you could sell your old diff...
Padre
Old 05-16-2011, 02:47 PM   #93
Padre
Padre's Avatar
Thanks. The JBA High-FLow Catted Midpipes fit the JBA Shorties well. But the midpipes are an awkward fit on the stock manifold, works, but not great fitment. Solo makes midpipes too, ask around about their fitment.
I think the JBA Midpipes are a great mod for keeping most of the stock sound and not making the AFM noise worse, as headers do. It's an easy +20hp and easy to install.
Gears are also a great mod for performance and keeping the daily driving good. Torque Converter is great for performance but hurts daily driving (revving higher off the line and therefore noisier).
Padre
Old 05-16-2011, 03:12 PM   #94
Pro Stock John
I'm losing my mind, for some reason I though you had gone 12.19@111mph and actually you went 112.89mph... Practically 113mph with bolt-ons is fantastic and just about 4000 raceweight to boot.
How much trial and error has it taken you to figure out the trans tuning with HPT?
Old 05-16-2011, 04:03 PM   #95
Camarowguy
Camarowguy's Avatar
Padre
I was thinking about a 2800 stall convertor like a yank convertor. I don't want to do anything that I will regret. As I said before I think I got one of the faster cars and my goal is to run in the 11's. I'm planning on doing everything you have (except wheels) plus a ported tb, underdrive pulley, cam and dyno tune. I think you'll be in the 11's with gears once you get your tune lined out perfectly.
Old 05-16-2011, 05:39 PM   #96
10spokess
Wild and Cammed
Padre
What Gears did you go with again?
Old 05-16-2011, 06:00 PM   #97
Padre
Padre's Avatar
Old 05-16-2011, 06:06 PM   #98
Padre
Padre's Avatar
I did get 112.95 with run one.
The tranny tune with HP Tuners was done after a lot of research on their forums and elsewhere. But it boiled down to simple changes in the pressure and desired shift times. I changed it only in shifts 1-2, 2-3, and 3-4 since that's all I need at the track, and around town I put the stock tranny tune back in. Actual adjustment at the track took just a few runs and one tweak (when I had the gulp).
Padre
Old 05-16-2011, 06:12 PM   #99
Padre
Padre's Avatar
As I indicate earlier in the thread, I have the 3200 FTI from RX. Big advantages are that it's billet, lighter, and new.
I personally do not recommend going with a reworked stock converter (as many are). No reason not to get a new one that is lighter and stronger, cheaper and with no core charge or anything. You may get more daily driveability out of a 2800 stall, but I don't know if it would do as well as mine did - four-tenths.
Oh, and I still have my Meziere Electric Water Pump and my SLP Underdrive Pulley waiting to go in. They'll go in after I get my 11-second slip with the gears.
Padre
Old 05-16-2011, 06:29 PM   #100
Camarowguy
Camarowguy's Avatar
Are you gonna do the water pump and pulley separate? I'd like to see the gain of each. I didn't think yank was a reworked stock convertor? I was either going with one of those or a vigilante. I picked up almost a second on my third gen with a vigilante.
CAMARO WIKI Tran Wiki 42 05-18-2013 09:32 AM
2011 Victory Red 2LT/RS, let the modding begin dianeokie Member Car Journals 162 04-27-2013 04:22 PM
2011 SS Detnews review - 2011 Camaro SS Fits In With Classic Cruisers Johnnyma45 5th Gen Camaro SS LS LT General Discussions 21 09-05-2010 01:15 AM
5th gen vs 4th gen JCO2185 Chevy Camaro vs... 158 07-26-2010 08:16 AM
Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) Tran 5th Gen Camaro SS LS LT General Discussions 715 07-23-2009 11:05 PM
