sjm autoprod
Old 02-12-2011, 03:07 PM   #1
xpanda305x
Banned
Drives: Dark Knight
how to wire AAC Hella 90mm Foglights?
okay i have a 1LS that as many of you guys know...dont come with foglights or wiring or anything! so i ordered the AAC hella 90mm foglight and...needless to say...they only come with the bulb waiting to be plugged in into a H9 socket..but as we know...the camaro doesnt come with H9 socket nor does mine come with fogs period...so i was wondering...how would i wire them up? i am running HIDS. so what im thinking is putting the hids and ballast on a relay and then tapping them into a switch. so what do you guys think?
Sent from my T-Mobile myTouch 3G Slide using Tapatalk
xpanda305x is offline   Reply With Quote
Old 02-13-2011, 12:59 AM   #2
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I am in the same situation. I figured that there is a power relay in the dash by the driver door, I am going to use that as my power so when the car shuts off, so will the lights. I did this in my Charger, take the wheels off, jack up the car, pull back the fender plastic, mount the fogs, run the wires. And having the switch mounted inside the car.
=Stephens= is offline   Reply With Quote
Old 02-13-2011, 01:01 AM   #3
xpanda305x
Banned
Drives: Dark Knight
you installed them already?!
Old 02-13-2011, 01:20 AM   #4
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I was going to do that tonight, and I got side tracked and I am going to wait til next weekend to do them. I have done the same install before on my Charger, so I already have the experience of knowing what to do. Here is the foglights I have, waiting to be installed, with HID's H3 bulb. I got them on ebay, seller is autofoglighting. I like these because they have the Halos built into them already.
2010-11 Camaro ACC LED Side Marker Mods for Turn Signals GearHeadPeter Cosmetics and Lighting Modification Discussions 44 03-13-2015 02:25 AM
Installed Modified AAC LED side markers/turn signals GearHeadPeter Cosmetics and Lighting Modification Discussions 15 01-20-2013 07:09 PM
Any Reviews on the AAC Hella 90mm Fogs? xpanda305x Cosmetics and Lighting Modification Discussions 7 01-02-2011 05:19 PM
Anyone in South Florida able to install hella 90mm foglights? xpanda305x USA - Southeast 1 01-01-2011 12:41 AM
Anyone have picts of the Hella 90mm fog / DRL projectors installed (on AAC's website) Matt'sSS Cosmetics and Lighting Modification Discussions 7 09-15-2010 03:52 AM
