Old 02-15-2011, 09:53 AM   #15
FH212
FH212's Avatar
Drives: 2001 Mecham Trans Am
Nice info...........
2001 "MECHAM" Trans Am #3 - 7.0L LS1 600+HP
2001 Firehawk 10th Anniversary
2000 "FIREHAWK" Trans Am #212 - SOLD
FH212 is offline   Reply With Quote
Old 02-15-2011, 10:05 AM   #16
Thorlius
Thorlius's Avatar
Drives: '08 Corvette 2LT Coupe
Do they do this on the CTS-V LSA too?
Thorlius is offline   Reply With Quote
Old 02-15-2011, 10:38 AM   #17
Bonneville2000
Drives: Bonneville
Yes. Common process with ZR1, Z06 and CTSV and Camaro ZL1 blocks.
Bonneville2000 is offline   Reply With Quote
Old 02-15-2011, 02:21 PM   #18
2SSRS-CGM
Drives: '13 Dusk SS M6
Originally Posted by hairtrigger View Post
Yes and it keeps the cylinder bores round after you bolt the head down, ensuring good ring seal which is critical for power.
Is there an echo in here?
Initial Success or Total Failure-US Army EOD
2013 Dusk Edition SS M6: Cold Air Inductions CAI, Ported/Polished Exhaust Manifolds, Corsa Sport, CTS-V brakes, Stoptech Slotted Rotors, Goodridge G-Stop SS brake lines, FR ZL1 Satin black wheels (20x10-20x11) Heritage Grill, ZL1 front rock Guards and 69 SS badges front, rear, and sides, tinted marker lights and windows.
2SSRS-CGM is offline   Reply With Quote
Old 02-15-2011, 02:22 PM   #19
dmiller66
Tampa Gulf Coast Family
dmiller66's Avatar
Drives: '13 2SS/RS, Blue Ray Metallic, Auto
Cool and all but probably not necessary for 99.99% of us who use our cars as daily drivers.
dmiller66 is offline   Reply With Quote
Old 02-15-2011, 02:27 PM   #20
brAnd7onX
brAnd7onX's Avatar
Drives: 2012 1SS IOM
Basically in short, this is them breaking in the engine correct? This process helps seat the rings?
brAnd7onX is offline   Reply With Quote
Old 02-15-2011, 02:28 PM   #21
2SSRS-CGM
LMAO
Old 02-15-2011, 02:34 PM   #22
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
For a reliable engine over extended years? it would relate to all of us..
However, what I don't get is it says a near perfect design based on this honing...so if that near perfect..what in the world is in our cars? Just decent? Not trying to sound whiny, just have no knowledge of this process.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 02-15-2011, 02:43 PM   #23
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
Interesting, dont really know what this means but interesting lol
so will it have more hp? lol
Old 02-15-2011, 02:50 PM   #24
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Deck plate honing nearly duplicates the head bolt loads that cause distortion in the block when they are screwed in. By using the same gaskets, bolts, and torquing procedure, the cylinders deform like they would after the engine is assembled. After the plate is on, honing the cylinders makes them perfectly round again thereby eliminating blow-by and keeping the cylinder shape constant, improving efficiency and getting a longer life. When the engine runs, the block actually twists and deforms, and gets pulled every which way when all the components are screwed and bolted to it. By duplicating the loads that influence the distortion, you eliminate little inconsistancies, get a happier engine that will live a longer life. This is more important when pushing a design to it's limits. The higher the performance, the less room there is for error. This process is one that racers have been using for ions, and while these little inconsistancies don't effect the engine too much, when you're looking for every little bit of power, or looking for hitting a specific safety factor when you're pushing the envelop, this is one of the tools one can use to nearly assure the best running and longest lasting engine possible. If you've ever heard of engine blue-printing - this is an element of that process.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-15-2011, 03:03 PM   #25
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
When I had the LT-1 engine built for my '73 Corvette in 1975 the engine builder used a torque plate, and a few years later the engine was checked by a local guy who ran Top Fuel dragsters and he told me my engine had better leak-down than his mega-buck Top Fuel engines. I definitely think it's worth it.
Meh
My 5th is offline   Reply With Quote
Old 02-15-2011, 03:08 PM   #26
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
WOW! That is really something! AND it makes so much sense. I've been a licensed mechanic for 28 years and knew nothing of this process. Mind you, I've never been into building high performance engines, but I'm glad I learned about this process.
Can never be too information savvy! LOL
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 02-15-2011, 04:57 PM   #27
justmeron
justmeron's Avatar
Drives: 2010 camaro
Send a message via AIM to justmeron
Wouldn't you think this process would be used on all the engines for a better product?
2010 2011 Chevrolet Camaro Faded Black Side Vent Highlight Decal Kit
Life is not like a box of chocolates, its more like eating a whole jar of jalapenos.... what you do today may burn your ass tomorrow!!!!
justmeron is offline   Reply With Quote
Old 02-15-2011, 05:11 PM   #28
Synerbee
SoCal Headturners
Synerbee's Avatar
Drives: 2010 SGM
It cost factor that probably preventing them from doing that, and extra time.
Synerbee is offline   Reply With Quote
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
