JUICEDMOTORSPORTS
Old 02-15-2011, 06:21 PM   #29
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by Icandrivejustnotlegally View Post
It cost factor that probably preventing them from doing that, and extra time.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-15-2011, 06:32 PM   #30
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Absolutely cost and time are both factors, but look at it this way...if you ever want an engine built, you're that much wiser with this knowledge in you data base!
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 02-15-2011, 07:15 PM   #31
Mark H
Drives: 04 Denali
Very interesting. I'll be watching this thread
But Officer, I swear its just a vacuum leak.
Those red things? those are smog pumps!
2004 Sierra Denali ----- 2/4 drop
LSX 438 TWIN TURBO
LSX Block Video
Block number 00370. Build Date 04/17/2007
Mark H is offline   Reply With Quote
Old 02-15-2011, 08:38 PM   #32
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Very nice! It's little touches like this that will give GM the edge over the other manufactures.
armysig is offline   Reply With Quote
Old 02-15-2011, 09:23 PM   #33
REAPER SS
REAPER SS's Avatar
Drives: 2010 CAMARO BLK 2SS/L99
REAPER SS is offline   Reply With Quote
Old 02-15-2011, 09:39 PM   #34
ex-SS-ve
Originally Posted by justmeron View Post
Wouldn't you think this process would be used on all the engines for a better product?
I always figured it was the standard for how a block should be machined and just assumed that it was common practice for every auto manufacturer to ensure the best quality built motor. Guess i was wrong about that.
ex-SS-ve is offline   Reply With Quote
Old 02-15-2011, 11:04 PM   #35
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 1LE...Drove: 2012 ZL1
Originally Posted by radz28 View Post
Deck plate honing nearly duplicates the head bolt loads that cause distortion in the block when they are screwed in. By using the same gaskets, bolts, and torquing procedure, the cylinders deform like they would after the engine is assembled. After the plate is on, honing the cylinders makes them perfectly round again thereby eliminating blow-by and keeping the cylinder shape constant, improving efficiency and getting a longer life. When the engine runs, the block actually twists and deforms, and gets pulled every which way when all the components are screwed and bolted to it. By duplicating the loads that influence the distortion, you eliminate little inconsistancies, get a happier engine that will live a longer life. This is more important when pushing a design to it's limits. The higher the performance, the less room there is for error. This process is one that racers have been using for ions, and while these little inconsistancies don't effect the engine too much, when you're looking for every little bit of power, or looking for hitting a specific safety factor when you're pushing the envelop, this is one of the tools one can use to nearly assure the best running and longest lasting engine possible. If you've ever heard of engine blue-printing - this is an element of that process.
Great explanation!!
Originally Posted by dragon22 View Post
WOW! That is really something! AND it makes so much sense. I've been a licensed mechanic for 28 years and knew nothing of this process. Mind you, I've never been into building high performance engines, but I'm glad I learned about this process.
Can never be too information savvy! LOL
That's kinda cool to read!
Don't let this lull you into believing the LS3s, etc are given "mediocre" attention. They have GREAT build quality and tolerances...the LSA, in this case, is given slightly more attention simply due to its higher power-levels, and potential for something to break.
Do you think Ford should use the expensive plasma-arc technology on ALL their cars? It's a better design than just standard press-fit sleeves....
Remember...high-performance "supercars" get to try out emerging technologies, first because their cost allows them to absorb the premium of these techniques....and then, in time, some of this trickles down to other, less-expensive cars. It's the same with the Volt -- the pinnacle of automotive efficiency in design. The aerodynamic work on the front air damn has made it to the Cruze...and the lithium batter/controller technology has made it to several Buicks with an "eAssist" badge.
Expensive cars get more stuff packed into them...high-po cars need hi-po attention...
"Keep the faith." - - Read Twice Before You Post.
Old 02-15-2011, 11:22 PM   #36
ZYA_LTR
Drives: Waiting to be ordered
The torque-plate honing has been around awhile, so it isn't any kind of new magic mojo for engine building, but it does add alot of hands-on manual human labor that obviously adds tons to the cost of assembly, as the process to finish hone a block is time consuming requiring constant measuring and adjustment to the boring bars's stone pressures and such. I have done this work in an engine shop, and takes a skilled touch to do it carefully and correctly, try calling your local engine shop and ask them what they charge to do it, plus the costs for the machine and training of individuals to do it, on top of where do they draw the line for # of machines/employees running them to keep up with production and not slow it down. Glad to see they are adding this touch to the ZL1, but doesn't make me think any less of the LS3's.
ZYA_LTR is offline   Reply With Quote
Old 02-16-2011, 12:46 AM   #37
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
Its a component of a precision build.
Its the difference between something you can do in your garage or a precision build to be honest. So is the align hone. Most shops don't do that as well but again its a component of a precision build. We do it every single time... deck to set proper quench, hone with correct tq plate and fasteners including side fasteners, align hone, balance..... Our engines cost a little more but they are precision built.. no step is ever skipped and I've talked to shops who will say that align honing is a waste and so is a few other things. BUT we've had customers bring us their engines and all we do is take them apart ..machine them properly and put them back together using all the same parts and gain 15-25 hp just from proper/precision block prep work.
CC Performance is offline   Reply With Quote
Old 02-16-2011, 03:54 AM   #38
CyberGamaro
CyberGamaro's Avatar
Drives: BLK 13 Camaro 1SS/1LE
This noob just learned something
Ordered on Oct 19: 17 NGM 1SS/1LE/PDR
TPW-11/14
Built on: Nov 17
4200 Status
CyberGamaro is offline   Reply With Quote
Old 02-16-2011, 09:07 AM   #39
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
Don't know if this has been posted before but on the LSA motors the heads are rotocasted to handle the extra cylinder pressures.
b4z is offline   Reply With Quote
Old 02-16-2011, 09:17 AM   #40
detltu
detltu's Avatar
Drives: 1991 Z28 1LE; 2015 Zl1
As many have mentioned this is not a new technique. It has been in use for racing engines (and probably very high end performance engines like Ferrari or Lamborghini). I am not sure when GM started using this process for Corvette engines but the LS7 for sure had it, anyone know if the LT5 was deck plate honed? It wouldn't surprise me either way. I think the big news here is that unless Ford has used the process on high end mustangs, this is likely the lowest price point car that has ever been offered with this process from the factory.
I would also assume that this process has been somewhat automated for LSA production.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x
1991 Camaro Z28-
1991 Camaro Z28 1LE-
2015 Camaro ZL1- finally a reality
detltu is offline   Reply With Quote
Old 02-16-2011, 09:24 AM   #41
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
^^Thats got to be the clearest way of explaining this.
Does anyone know if Ford or Dodge are using the same process on their Mustangs or Challengers? (referring to the GT/GT500 and 6.4L 392..)
I have read the 5.0 Mustang motor is pretty advanced in it own right also.
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 02-16-2011, 09:52 AM   #42
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
I agree. They have done something to keep the cost down.
IamJacksCamaro is offline   Reply With Quote
