Old 02-15-2011, 08:07 PM   #1
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
CTS-V brakes vs. Brembo 6 piston upgrade brakes
After hearing about the Brembo 6 piston brake upgrade this morning, I've done a little reconsidering.
Can anyone explain the pros and cons between the CTS-V brake upgrade on a Camaro SS vs. the upgrade package that WSI is selling?
The price difference isn't much, so I'm looking to see what exactly is different. The only difference I can see is the rotors come in the CTS-V pacakge.
I'm still doing preliminary research so facts comparo is what I'm going for.
Thanks!
Old 02-15-2011, 08:11 PM   #2
Cully
Drives: 2011 1SS/RS Synergy Green Camaro
What is the going price for each?
Cully is offline   Reply With Quote
Old 02-15-2011, 08:15 PM   #3
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
MSRP is ~ 3400 and 3700 for them.
Old 02-15-2011, 08:21 PM   #4
Mr Twisty
Mr Twisty's Avatar
They're both 6 piston, is that right?
The CTS-V setup will give you larger diameter, thicker rotors, which will help with heat dissipation, they also don't have to work quite as hard. Pad selection will also make a BIG difference in either selection.
If you're staying on the street, flip a coin. If you're planning on hitting twisty track hard, go with the CTS-V setup.
-- Benjamin Franklin
Old 02-15-2011, 08:25 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
What parts are only $1700- 1900 for the front CTS-V, i will install it for you for less then the rest of your asking price.
Old 02-15-2011, 08:29 PM   #6
Indpowr
Drives: Corvette C6
Or you can go bigger to 8 pistons like our SSBC
Old 02-15-2011, 08:29 PM   #7
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
The CTS-V dual cast rotors are lighter than the OE SS rotors. Both can be replaced with true two piece rotors.
Old 02-15-2011, 08:30 PM   #8
Indpowr
Drives: Corvette C6
+1
our 2 piece too
Old 02-15-2011, 08:35 PM   #9
Mr Twisty
Mr Twisty's Avatar
Originally Posted by Indpowr View Post
+1
our 2 piece too
Are those CTS-V rotors?
Old 02-15-2011, 08:37 PM   #10
Indpowr
Drives: Corvette C6
No, true 2 piece
Old 02-15-2011, 08:38 PM   #11
JusticePete
No, true 2 piece
I think he was asking about fitment as in do these fit a CTS-V?
Old 02-15-2011, 08:39 PM   #12
Indpowr
Drives: Corvette C6
Ah, LOL, blond moments. I have no idea if they have a 2 piece rotor for the CTS-V line.
Old 02-15-2011, 08:48 PM   #13
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
If I'm getting this correctly,
The rotors of the CTS-V are lighter...
Both use monoblock calipers...
pad selection will make the most difference...
Did I get this right?
Old 02-15-2011, 08:53 PM   #14
JusticePete
Correctamundo.
I use custom made Cobalt Friction XR1 front and XR2 rear. They are perefect for track and summer street use. Expen$$$$$ive, but perfect.
2010 Camaro Brembo Sport Disc Brake Upgrade available from INTENSE Todd @ INTENSE Suspension / Chassis / Brakes 2 11-24-2009 11:30 PM
Baer 15" 6 Piston Extreme Plus Brake Upgrade for 2010 Camaro Available Now! Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-04-2009 10:17 PM
Question regarding Brembo brakes. Bentley78 Wheels and Tires Talk Sponsored by The Tire Rack 26 04-29-2009 02:55 AM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 08:23 PM
What's written on the brembo brakes FUTURE TOP DOG OWNER 5th Gen Camaro SS LS LT General Discussions 19 09-19-2008 09:11 PM
