HeadlightArmor
Old 02-15-2011, 09:05 PM   #1
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
BMR End-Links and Toe Rods Installed
I did the install at my house this weekend and it was fun. The only part that sucked was having to drop the rear cradle to install the driver side toe rod... other than that it was cake!
Here are some pics
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 02-15-2011, 09:41 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Those end links are just a little bit beefier than stock, huh?
Old 02-15-2011, 10:24 PM   #3
dmax86
dmax86's Avatar
just a little!!
Old 02-16-2011, 10:04 AM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Nice install pictures! Looks like everything went in pretty easy.
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 02-16-2011, 08:13 PM   #5
dmax86
dmax86's Avatar
It went well! Oh and Kyle i think i had you on the phone today about the sub frame brace and bushing kit and my phone dropped the call!! my bad i was walking into my next class and couldn't phone back!
Old 02-16-2011, 08:22 PM   #6
Apex Motorsports
Somebody has the bug!
Old 02-16-2011, 08:45 PM   #7
dmax86
dmax86's Avatar
haha yeah! I cant stop!
Old 02-16-2011, 10:05 PM   #8
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
ok so what method did you use for droping rear subframe? I am about to do toe rods and inserts!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 02-16-2011, 10:43 PM   #9
robsls3
Drives: 2010 camaro 1SS
motorcycle jack is what i used.
robsls3 is offline   Reply With Quote
Old 02-16-2011, 11:38 PM   #10
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Here are some pics
Attachment 207325
Attachment 207326
Attachment 207327
Attachment 207328
Attachment 207329
Attachment 207330
Great pics, thanks for sharing!
BMR guy is offline   Reply With Quote
Old 02-19-2011, 12:47 AM   #11
dmax86
dmax86's Avatar
i had 4* jack stands and a jack... that did the trick! its not to bad.
Old 02-20-2011, 10:54 PM   #12
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Two jack stands under the front cradle and two more under the rear subframe just in front of the rear cradle. These will hold the car up and keep it stable while you lower the rear cradle. Most just use a floor jack under the rear cradle, remove the 4 bolts then lower the cradle with the jack...
Old 02-21-2011, 09:47 PM   #13
jsharp
jsharp's Avatar
I plan to put race ramps on front and jack stands in the back. When you say just take out the 4 bolts and lower with jack where is the jack positioned to keep the cradle from rocking or falling?
Old 02-24-2011, 05:31 PM   #14
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
You can safely support the cradle with the jack under the differential. If you don't have a polyurethane pad on your jack, make sure you put a piece of plywood between it and the aluminum diff housing. you will have to play around with finding the balance center of the assembly but it's not too bad one you find it...
Edelbrock Adjustable Rear Toe Links Xplosive Performance Suspension / Chassis / Brakes 0 12-18-2010 05:02 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Toe Links with Polyurethane Bushings. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:55 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:44 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Del-Sphere Pivot Joints LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:39 PM
