JDP Motorsports
Old 02-17-2011, 10:35 PM   #1
iom
Drives: 2010 camaro iom ss rs
JBA HIGH FLOW CATS PART#1812SYC DON'T FIT MY L99
Hi guys ,
I purchase the Jba mid pipes with high flow cats for my 2010
Camaro l99 & I am having some major probs.
The driver side pipe does not fit , its way off !
I am able to bolt it on with out the o2 censor but
It's impossible to connect the censore here's why .
1.there's no room because the tranny is blocking it .
2.even if you try to force the pipe to align right so that
It's pressing against the tranny the o2 censor will not screw
In the mid pipe
I check the mid pipes and there in perfect condition there's nothing wrong with them .
I compare both pipes and they are a complete set one left and
One right .
So I'm asking for help guys , has anybody installed these on a l99 ?
Is there any special instructions to get this done ?
Maybe I just got a bad set ?
Maybe there's a different part number for the l99 ?
Because I seen a pic on one of the forms with the
Install completed and it looks like the tranny is different
From mine !
iom is offline   Reply With Quote
Old 02-17-2011, 11:09 PM   #2
Goliath
Goliath's Avatar
Drives: 2010 Camaro 1SS L99 A6
I didn't have any issue with the installation. Could be a dumb suggestion but did you try to switch the pipes from left to the right to see they fit? You might be putting the left pipe to the wrong right side of the header.
Take some pictures so the experts here can give you more suggestions.
The Most Interesting Man in the World - On Muscle Cars
"I don't always drive muscle car, but when I do, I prefer the Camaro. "
Goliath is offline   Reply With Quote
Old 02-18-2011, 10:50 AM   #3
2010 4 DW
Drives: White 2010 RS/SS
Put the o2 sensors in them before you try to bolt them up.
2010 4 DW is offline   Reply With Quote
Old 02-18-2011, 11:25 AM   #4
jtzako
Drives: 2010 IBM Camaro SS
Install the sensor first for sure, but also, you may be able to loosen other things to get it to work.
My Solo high flow cats driver side also was difficult to get fit correctly but the passenger side was fine.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 02-18-2011, 01:38 PM   #5
bigdog96z
bigdog96z's Avatar
Drives: '13 Avalanche & 2010 2SS/RS/M6 SIM
JBA catted midpipes
You need to install the O2 sensors first. Then loosely bolt the manifold bolts while you get everything lined up. It is a tight fit but I had reasonable clearance once everything was tightened up.
My car is an LS3 though so the L99 might be slightly different.
You will like the sound once they are on
bigdog96z is offline   Reply With Quote
Old 02-26-2011, 09:13 PM   #6
bigrob301
bigrob301's Avatar
Drives: 2011 Camaro SS
Send a message via Skype™ to bigrob301
Talking
Switch them around you've got them backwards
bigrob301 is offline   Reply With Quote
Old 02-26-2011, 09:21 PM   #7
SS/RS NJ
Chevy/Buick Internet Mgr
SS/RS NJ's Avatar
Drives: 2SS/RS Victory Red
I have them on my L99 but I also have the LT headers. I had to loosen everything, remove the brace, and spin/rotate the high flow cat so the o2 cleared the trans. Call JBA if you have any trouble. They have very good customer service.
2010 Camaro 2SS/RS M6 Victory Red
AEM C.A.I.
MGW Shifter - tried the Hurst...save your money and get the MGW.
MTI Rear dovetail spoiler.
Replaced: 2010 Silver Ice A6 2SS/RS
SS/RS NJ is offline   Reply With Quote
1812syc, high flow cats, jba, mid pipes
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
Aftermarket Cold air intake SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 10-01-2010 03:32 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Dealer Installed Options firehawk1 5th Gen Camaro SS LS LT General Discussions 5 04-18-2009 08:17 PM
