Solo Performance
Old 02-19-2011, 05:09 PM   #1
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
Something in suspension making a noise, video inside, help!
Hey guys, here's the video of what my car is doing when going over bumps. Holy hell is it annoying and I dont know what it is. I've had pfadt springs and sways on for about 3 months now and haven't had a peep out of them, this just started probably a week ago. Any thoughts as to what it could be?
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 02-19-2011, 05:25 PM   #2
Captain McFunk
Okay guys, got it solved. Been battling for awhile. Turns out one of the end link bolts had loosened up. I have stock endlinks and pfadt sway bar. I tightened the bolts down, and the noise stopped. Anyone else ran into this?
Old 02-19-2011, 05:33 PM   #3
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
I love it when the fix is easy. Yeah, I've heard about a loose endlink making noise several times here on the forum.
Jaysin is offline   Reply With Quote
Old 02-19-2011, 07:28 PM   #4
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
Endlinks are almost always the culprit. The nuts used to secure endlinks from the factory have some resistance, quench, designed in. Every time you take the nut off it loses some of the quench that is supposed to prevent them from coming loose. At Pedders, we LocTite almost every nut we touch in the suspension or replace them with new nuts. If the problem returns, get fresh nuts or reinstall them with LocTite.
Old 02-21-2011, 05:58 PM   #5
RichJ.
Shop Owner
Drives: 1 ton silverado
You should always replace locking style nuts. Because they loose some of there prevailing torque after the first time used.
RichJ. is offline   Reply With Quote
Old 02-22-2011, 10:09 AM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
LOL....I was going to suggest you get a room instead using your car.
Build Journal
