Solo Performance
Old 02-20-2011, 03:02 PM   #15
Merc
In The Circle
Merc's Avatar
Originally Posted by Gene Culley View Post
You're looking at about $40 for the splitter and light pipe and $35 - $40 for 3 LED's. Vinyl tubing is only a couple of dollars. This is just off the top of my head.
K THX.
Old 02-20-2011, 03:24 PM   #16
19K3SS
Drives: 2010 Camaro SS/RS
Before going this route, I've had one concern. I would think that the light would look like it's coming from behind the panel, not through the panel as it is on the doors. How would you say it looks in person?
Delivered 29May09: 2SS/RS Black w/ CGM Rally Stripes, Black Int, 6spd, 20" Polished
VIN: 2G1FT1EW2A9108883
19K3SS is offline   Reply With Quote
Old 02-20-2011, 04:16 PM   #17
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Good job
Excellent step by step.Will definitely help out when we do our own.Thanks for the write up & heads-up on some of the obstacles.
Thanks to offer,tag, and you for pioneering this modification.Job well done !
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 02-20-2011, 04:32 PM   #18
Merc
In The Circle
Merc's Avatar
I was wondering the same thing.
Old 02-20-2011, 04:44 PM   #19
Gene Culley
Drives: 2013 SS
Smile
When you're in the dark, you can't tell that the light is coming from under the door panel as opposed to behind it. So what I mean is, sitting in the vehicle, everything looks good. You can do a 180 look from side to side and it all looks uniform and the concern is not really whether it is coming from under a panel or behind it, if you know what I mean.
Also, like I said, it is really hard to photograph, but the light does also shine through the front of the panel, since I already have the ABL panels.
You could sand the top of the dash panels and have it shine through the front of the panel only, but then you're looking at drilling and cutting so that you can actually fit the light pipes behind the panel with the panels fully pushed in.
Gene Culley is offline   Reply With Quote
Old 02-20-2011, 04:46 PM   #20
Gene Culley
Drives: 2013 SS
Smile
Thank you. It took me like 3 hours to do all of the pictures and write everything up and post it, so once I get a chance to step back and read it again I may do better.
Old 02-20-2011, 05:05 PM   #21
anglwngss
Lone Star Camaro
anglwngss's Avatar
Drives: 2011 Synergy Green 2SS/RS
Thanks for the write up. It looks really nice. Just for clarification re: the drill vs. no-drill method.. The no-drill method has the light bar sticking out about 2-3 mm, which is hardly noticeable, and with the drill method, a person has to sand the top of the dash, drill a little bit so the light bar will go behind the dash?
The drill method would more closely resemble the ABL in the doors, but the no-drill method is quicker/easier. Do I have this right?
anglwngss is offline   Reply With Quote
Old 02-20-2011, 05:34 PM   #22
camaro2lt
camaro2lt's Avatar
what would be the drive from harrisburg up to where you are soo i can get this done lol
Old 02-20-2011, 05:57 PM   #23
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
First hat tip to Gene Culley for a hell of a thread.
Old 02-20-2011, 05:58 PM   #24
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
If you wanted some assistance and/or want to see mine let me know!
I did mine in a slightly different method. Kind of a combination method, no drill, but I sanded.
To get the trim to go back into place for my method you will need to trim the clips a bit. If you look at the trim you will see that the 2 ends and the center clip are in the way, and this is the reason the trim sticks out with the tube behind it. Here is KTCAM's pic showing that.
In fact if you have a late model 2010, or a 2011 lighting the dash is far easier than fishing to the gauge cluster, since you can tap the purple black wires going into the door at the kick panel.
If you click the link for my car you will see I did a no drill solution for the glovebox light using the second GM light that I was going to use near the gauge cluster.
Oh and the GM door lamps will fit into the footwell lighting area as well.
skuttduck is offline   Reply With Quote
Old 02-20-2011, 06:11 PM   #25
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Great DIY.
I need to tackle this project myself
Old 02-20-2011, 06:15 PM   #26
2SSRS@Gen5diy
Great DIY.
Are you and you car coming to CF2 If so i will give a light pipe if we can do a DYI with your car.
Old 02-20-2011, 06:22 PM   #27
bigwayne3000
Drives: 2011 Camaro LS
I've read Ofer's thread numerous times and then read this and honestly this makes it much easier for me to understand. Not sure why but it just does haha. Thank you for writing this up. Now w/ me having an '11 LS I need to order some new panels for my car. Looking for orange. Cant find them anywhere though.
bigwayne3000 is offline   Reply With Quote
Old 02-20-2011, 06:23 PM   #28
GTAHVIT
Blessed
GTAHVIT's Avatar
Uhm.... lemme think....
DONE!
Let me know what you need from me.
COOL!
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 01:05 PM
