Old 02-23-2011, 02:43 AM   #43
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Originally Posted by Gene Culley View Post
The dash looks 100% as bright as the door panels where it is the brightest and thickest, yes.
So now the bigger question, did the ABL tools really help? was it "that" much easier? lol
CAMARO
Old 02-23-2011, 10:47 PM   #44
Gene Culley
Drives: 2013 SS
Smile
Originally Posted by Toasty View Post
Yeah, I thought about that. I bet some acetone free nail polish remover would work and not damage the panel... that or brake fluid, lol...
You may be correct. In very small amounts, it may work. Brake fluid
Gene Culley is offline   Reply With Quote
Old 02-23-2011, 10:48 PM   #45
Gene Culley
Drives: 2013 SS
Smile
Originally Posted by Capthowdy View Post
someone blew through a few panels trying to do the sand method...maybe he has some of the bad ones to test some removal products...
I think the easiest way to sand is to tape them off with painters tape and then you can't go any further down than the line.
Old 02-23-2011, 10:49 PM   #46
Gene Culley
Drives: 2013 SS
Smile
Originally Posted by Kahdir View Post
A Plug 'n' Play kit under $200 would work
How much for replacement dash insert pieces?
It depends on what color for the dash insert pieces. You're looking at $50 to $175.
Old 02-23-2011, 10:50 PM   #47
Gene Culley
Drives: 2013 SS
Smile
I guess you're referring to the trim removal tools? Heck yeah, I wouldn't even bother doing it without them. I use those trim removal tools for everything! Once you start using them, you will find a reason to use them more and more in the future!
Old 02-24-2011, 09:35 AM   #48
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
hey i am prepping do to this, and wondered, rather than sanding for the other way, rather use acetone to remove some of the paint instead?
I tried Goof Off, and it didn't work that well. I used a 3m spot sanding pen to sand just the bevel of the trim. http://www.amazon.com/Prep-Pen-PrepP...8558024&sr=8-2
I kind of wish I had them, but I did find you can pinch the first clip from behind and once you get one clip removed you can easily just pull them out from down the line.
You just get some sore fingers doing that.
skuttduck is offline   Reply With Quote
Old 02-24-2011, 10:48 AM   #49
GrtWht_2010_2SS_RS
GrtWht_2010_2SS_RS's Avatar
Drives: 2010 2SS RS, White w/Black Stripes
Regarding the sanding method: Can anyone post a photo of the exact location that sanding is required? Additionally, how much sanding should be done on that area.
A friend and I attempted this project this weekend and everything went smooth, however we did not care for the 2-3 mm gap method. We finally gave up after two days of trying to adjust the tubing and everything to make it right but just couldn't. We still have plans to finish but want to find out the above questions before proceding further.
GrtWht_2010_2SS_RS is offline   Reply With Quote
Old 02-24-2011, 07:41 PM   #50
cdn2usa
cdn2usa's Avatar
Drives: 2010 2SS
I used paint remover (tuff-strip) purchased at Lowes. Had it around for years after doing some furniture re-finishing. For the doors it worked great, first taped it off, applied with a small modeling brush, wairted less than a minute removed with a Q- tip. After about four applications it was perfect. If you leave it on for too long it would eat the plastic. For the dash I have only done the driver's side so far. I took the paint with no problems but the look is better when it's sanded IMO, used 600 grit.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged,
Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera.
cdn2usa is offline   Reply With Quote
Old 02-24-2011, 10:17 PM   #51
Gene Culley
Drives: 2013 SS
Smile
I agree. I figured the tools were cheap and it is easier to remove trim. I have a Hummer H3 that I removed the center console bezel and all and that could not have been removed by hand!
Old 02-25-2011, 09:23 AM   #52
GrtWht_2010_2SS_RS
Where did your line start? Did it begin at the edge of the bevel? Once you got it sanded down, did the light shine through nicely? Thanks for your response.
Old 02-25-2011, 10:43 AM   #53
cdn2usa
cdn2usa's Avatar
Drives: 2010 2SS
If your talkiing about the dash, it's still to clear for me, but your looking right at it, it's not like the door panels. I am going to try sanding with a lower grit or maybe tape to fog it up.
Old 02-25-2011, 11:24 AM   #54
skuttduck
skuttduck's Avatar
Best way to describe the sanding is to do just at the bevel, then look at it from the front at a light and see if you can see it. You also run your fingers back there and look from the front that is a good way to tell if your sanding is good.
You don't need to sand completely up from the bevel, in fact I think I have a couple MM of original paint at the very top. I usually sand about enough for the thickness of about half a pencil eraser.
Old 02-25-2011, 10:21 PM   #55
verboten
Drives: Black
How much vinyl tubing do i need?
verboten is offline   Reply With Quote
Old 02-25-2011, 11:40 PM   #56
Gene Culley
Drives: 2013 SS
Smile
I would say 6 inches will be good enough.
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 01:05 PM
