JUICEDMOTORSPORTS
Old 03-20-2011, 09:28 PM   #71
xxIRONWILLxx
7.5 mpg and loving it!
xxIRONWILLxx's Avatar
Drives: it like I stole it!
Ok, got the lights in but I don't like how the panels diffuse the light. They don't match. I tried turning the reflector at every angle. I notched the panels so I could flush mount but that is even worse. I sanded to the edge of bevel but did not go over. The sanded portion is now mounted flush so no light is going through it. If I shim the panel out it looks better. I'm wondering. If I sand(evenly) over the edge,will the light then fill the sanded area? Or do I have to keep it shimmed? Another thing is, the center of the right side is very dim in the middle. I used clear cable retainers to try to stop it from sagging but it is still dim. I extended the lighting in the doors. Took the tape off. Used Oops! Extreme Remover(Advance Auto) and Qtips to take the paint of the door panels. Worked great. A couple quick applications and it came right off, no drama. Kind of a tight area to sand. Doors really turned out great. Any input on the dim center would help. Thx
xxIRONWILLxx is offline   Reply With Quote
Old 03-22-2011, 10:55 PM   #72
Gene Culley
Drives: 2013 SS
Smile
I have my panel tilted out a bit to shine the light up behind it. I didn't do the sanding method. Are you saying it is still dim in the center with the panel tilted out?
Gene Culley is offline   Reply With Quote
Old 03-24-2011, 01:49 AM   #73
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
If you look behind the hole in this picture, you can see it is sort of blocked off. That is actually the panel behind that dash that houses the A/C vents and all. One of the moderators here, TAG, says he loosened that bolt and pushed on it and it allowed the LED through. I did loosen the bolt and pushed that panel back a little with the screwdriver.
OMG, I drilled that am I screwed?!
CAMARO
Old 03-24-2011, 02:10 AM   #74
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
the more i think of it, i remember it being like a slim plastic piece that felt just like a bracket, so im hoping I didnt do any real damage
CAMARO
Old 03-24-2011, 05:31 PM   #75
xxIRONWILLxx
I was trying to mimic the door panel lighting and still have the dash panels flush mounted. I now think this is next to impossible. When I shim the panel out, I get really good lighting. The right side panel like to pull itself really far in, in the center. That's why I'm seeing dark, but I am working on it and think I have the answer. I used reflective tape behind the panel and that helped alot. But it still needs to be shimmed away to give the best light. I have a couple ideas on how to evenly shim the panel across the top. Should have it mostly done this weekend. Btw, the dimmer switch I installed really helps when you're thing to match the doors. The center is almost always brighter than the doors when it's wedged out. I'll post all the pics once I get this figured out. Thanks for the help everyone
Old 03-24-2011, 11:15 PM   #76
Gene Culley
Drives: 2013 SS
Smile
No, I went back later and drilled that piece out just to have spare room, so you're good.
Old 03-24-2011, 11:16 PM   #77
Gene Culley
Drives: 2013 SS
Smile
Thank you for your valuable information. I look forward to seeing your photos and hearing more information.
Old 03-25-2011, 11:21 AM   #78
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
awesome write up. As soon as I get the funds, I will be hitting you and Ofer up!
Old 03-25-2011, 10:59 PM   #79
Gene Culley
Drives: 2013 SS
Smile
Thanks man. Let me know if you need to know anything else!
Old 03-29-2011, 11:36 AM   #80
FED728
Drives: Aqua Blue SS
ABL
Great step by step write up. Will be using this and now I AM REALLY HOPING I have a plug. Can't wait to get home to see my vin number.
FED728 is offline   Reply With Quote
Old 03-29-2011, 11:57 AM   #81
ihaveacamaro
I like teeth.
Drives: #198
Order sent through Patrick... he said you guys should be getting more blue abl lights in a few days.
Can not wait to try this at home!!!
and I'm ordering the trim removal kit too haha. thanks for that tip
Roshan
Old 03-29-2011, 12:03 PM   #82
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
oh thank God
CAMARO
Old 03-29-2011, 12:27 PM   #83
HumanWiki
Drives: Car
If you carry your insurance card on you, check it. I know with mine from StateFarm it's listed there.
HumanWiki is offline   Reply With Quote
Old 03-29-2011, 02:14 PM   #84
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
i posted this in ofer's thread, thought i would post here also, might help.
i purchased some 1/4 in weather stripping, put i along the trim, and raise or lowered it in areas. This is to hold the rod and in turn, the rod create to proper gap needed. hope this help, kinda crappy vid, but oh well
lupe
overhaulengines is offline   Reply With Quote
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 01:05 PM
