Cold Air Inductions
Old 02-20-2011, 03:28 PM   #1
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Exclamation 50% Oil Life = Dark Oil?
I was just checking my oil and I noticed it seemed sort of dark. I really don't know what is normal for the car though so I figured I would see what others were experiencing.
I have about 4k miles on it since the last oil change and the oil life meter is reading 49% remaining. I have been doing a lot of short city trips in the cold winter weather where the car doesn't get a chance to warm up very well. The oil temp doesn't get up to normal before I turn the car off usually. I have a cam, headers, intake, and exhaust on an L99 if that matters any.
Does this sound normal from what others are seeing? Would my cam have any affect on oil life? Thanks!
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 02-20-2011, 03:29 PM   #2
Jabs
Jabs's Avatar
Drives: 2010 Black Camaro SS Stage 2
I also would like to know...
Jabs is offline   Reply With Quote
Old 02-20-2011, 03:34 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
just change it,,
Old 02-20-2011, 03:44 PM   #4
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
the oil turns dark about the same time you drive around the block...no big deal.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 02-20-2011, 03:49 PM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I change it every 3K miles or every 3 months, whichever comes first no mater what anyone says.
SUX2BU is offline   Reply With Quote
Old 02-20-2011, 03:55 PM   #6
camaro1
camaro1's Avatar
good man!!,, we are seeing so many issues from people going by the oil life monitor,, oil changes are cheap if you like your car and plan on keeping it for years to come.
Old 02-20-2011, 04:05 PM   #7
Atlas
Would you kindly...
Atlas's Avatar
Drives: Destitute
This. It happens
Also note that the oil life expectancy is merely a meter. More like a service light but with percentage. I first changed my factory oil at around 3550 with Mobile 1 full syn. Then changed it again at 6985. Draining the oil, It was darker than triple zero black. These engines nowadays are ok from 5k-7k before needing an oil change. But that's at the limit. The most important thing to do is keep an eye on your oil level. check it often. Coming from the import scene, those little engines live or die on a quart
Atlas is offline   Reply With Quote
Old 02-20-2011, 04:16 PM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I change my oil about every 3k - 4k (way before the oil life is up), but I race my car. If you run your car hard, you'll want to change your oil more frequently.
Old 02-20-2011, 04:22 PM   #9
Inferno Orange SS
Inferno Orange SS's Avatar
Drives: 2010 Camaro 2SS LS3
That oil monitor scares the crap out of me, my second oil change was done just under 5000km and the oil monitor still read 70% oil life remaining... Even the Manager at my local dealership said someone would have to be crazy to listen to that thing and that he still recommends changing it every 5000 or so. I agree with him completely.
Inferno Orange SS is offline   Reply With Quote
Old 02-20-2011, 05:29 PM   #10
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
I'd like to see some more information on this.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 02-20-2011, 06:00 PM   #11
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Sure he does .....they get paid to say that.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 02-20-2011, 06:23 PM   #12
C586
Drives: 2011 Camaro LS
3k change is a waste. I change the oil in my supra at 6-8k miles and always send it for analysis. They always say I had around 30% of oil life left. And its a race engine that usually sees about 25 psi and 8k rpms daily. Oil turns black pretty quickly once its in the engine. I change my filter halfway through the interval. I plan on doing the same with my camaro. I changed it at 500 miles and 1k miles and wont change it til prolly 5k then send it out and they will most likely say I had about half the life left in the oil.
C586 is offline   Reply With Quote
Old 02-20-2011, 06:25 PM   #13
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
If you're running synthetic, changing every 3k would be a huge waste.
xxlbeerz is offline   Reply With Quote
Old 02-20-2011, 06:26 PM   #14
L99SS
L99SS's Avatar
Drives: '10 Camaro IOM
Every 5000km?! You're just barely getting your money's worth from that batch of oil.
At many dealerships where income is more dependent on vehicle maintenence than auto sales, the managers just might tell you the same thing. From a strictly financial point of view, the more frequently he can get you into the shop, the better for his pocketbook.
Oil life is determined by how hard the engine is driven and how much strain the climate puts on the system. Today's synthetic oils are quite temperature stable and durable; 5,000-8,000 miles between oil changes for a broken-in engine is not unrealistic.
L99SS is offline   Reply With Quote
cam, dark oil, oil life
Roto-fab CAI, dry filter vs. oil filter Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 01-30-2015 11:19 AM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
