Tom Henry Racing
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 02-07-2009, 04:57 PM   #1
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
LS3 vs L99?
According to GM High Tech some of the major difference between the two motors are
1. VVT
2. AFM
3. 10.4:1 Compression ratio
4. lower lift cam
But one thing that really caught my eye was the lower fuel cut off rpm for the L99. GM High Tech Mag states that the fuel cut off for the LS3 is 6600 rpms, while the fuel cut off for the L99 is 6200 rpms. Is this really the fuel cut off for the L99? That seems too low.
If this is true then red line must be somewhere around 6000 rpms for the L99 vs 6500 rpms or so for the LS3. I'm wonder how much this will affect the peformance of the L99 A6 vs the LS3 M6.
To compare- My LS2 GTO's redline is 6500 rpms and I'm not sure about the fuel cut off.
Old 02-07-2009, 05:07 PM   #2
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
the cut-off is there to protect the valvetrain at higher rpms from getting torn up.
the thing to look at is the power curve. as ive said before, its nice to rev to the moon, its nicer to move.
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 02-11-2009, 01:54 PM   #3
PatrickfromMD
PatrickfromMD's Avatar
Drives: Navigator/Corvette/2010 Camaro
1. VVT
2. AFM
4. lower lift cam
I have read much of the same for the L99 motor (I have one on order).
In addition to not needing as high an RPM due to less cam, I read that the AFM does impose some restrictions to the valve train at higher RPMs.
This should not be an issue if you keep the motor stock. If you are looking at adding traditional performance mods, then this RPM limit needs to be taken into consideration.
I’m keeping my ears open for ways to beef up the valvetrain to handle more, but have yet to see any useful information short of removing the AFM
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
Old 02-11-2009, 04:32 PM   #4
RS/SSYellowJacket
Old School
RS/SSYellowJacket's Avatar
Drives: Ordered Yellow/Black RS/SS2 M6
A shorter Valve Duration will reduce the peak RPMs at wich you reach Peak HP. Also if the Valve lift is less then less HP at the given RPM peak will be realized. Short Lobe Centers usually create quicker HP and TQ curvers. Where a longer Lobe Seperation usually increase the length og the HP and TQ Curves.
So the Auto with AFM and VVT uses the smaller cam to better manage the fuel consumption and there by reducing the power levels and making the peak RPM range lower. However the TQ curve will start at a lower RPM and reach is peak quicker. So the Auto car will basically show simular performance as the manual tranny car and the gearing in the Auto is usually lower per gear than a manual making the Torque multiplication effectivally higher per gear.
This made more sense inmy mind I am sure than it does in print. So take it with a large grain of salt if it confuses you more. I was havig a hard time trying to make something technical make sense in lehmans terms. I am not necessarily that good at.
RS/SSYellowJacket is offline   Reply With Quote
Old 02-11-2009, 04:47 PM   #5
King Mouse
King Mouse's Avatar
Drives: EXT
You are right. Pointy cams, less duration, have greater torque at low RPMs but less HP.(they peak sooner) Longer duration cams have more HP but you need more RPMs to get it due to scavenging caused by overlap of intake and exhaust lobes. (more of a top end motor)
There are many other factors involved. Just some basic cam theory.
King Mouse is offline   Reply With Quote
Old 02-11-2009, 11:59 PM   #6
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
Also, the L99 may have the same heads found on the L76, since that too has AFM. Although the castings are the same as the L92 heads, to save costs the L76 (and possibly the L99) has heavier solid valves vs. the lighter sodium filled L92/LS3 valves.
THE EVIL TW1N is offline   Reply With Quote
Old 02-14-2009, 10:58 PM   #7
mike@newera
mike@newera's Avatar
Drives: 2010 Camaro 2ss L99 A6
True, but I would guess camshaft powerband has a lot to do with this along with the valvetrain.
mike@newera is offline   Reply With Quote
Old 02-16-2009, 04:37 PM   #8
epd313
epd313's Avatar
Drives: 2010 IOM 2SS
I am looking for some advice. I ahve a 2SS A6 on order and keep thinking I should get the LS3 instead. Is there anyhting that says one is better than the other? Back in the day it was stick all the way. I have a stick in my 2000 SS, but have to admit, it gets old in traffic, maybe I'm just getting old, who knows. Technology today seems to point to the L99, any advise, I'm starting to get a headache and I have months yet to wait
epd313 is offline   Reply With Quote
Old 02-16-2009, 04:38 PM   #9
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
L99- more moving parts, less efficiency
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 02-16-2009, 04:41 PM   #10
epd313
epd313's Avatar
L99 has more moving parts?
Old 02-16-2009, 04:43 PM   #11
Muscle Master
SS Lightning
Drives: An SRT8
Yes, The AFM
Old 02-16-2009, 04:56 PM   #12
CamaroSpike23
The Jalopy Jedi
the auto's of old were not the greatest. the new 6 speed auto that GM has is a bad mofo.
this new auto isnt the slushbox of yesteryear.
depends on what kind of efficiency you are looking at. fuel efficiency? AFM rocks. lol
I piss excellence
Old 02-16-2009, 05:00 PM   #13
Muscle Master
SS Lightning
Drives: An SRT8
Efficiency period, of course Fuel efficiency is gonna kick ass
Old 02-20-2009, 05:23 PM   #14
ChevyBoiSS
ChevyBoiSS's Avatar
Drives: 2006 Monte Carlo SS
for the person that wont be modding their car to hell because 400hp seems to be MORE than enough for me, lol.. Im fine with the way things are.
ChevyBoiSS is offline   Reply With Quote
Old 02-21-2009, 08:39 AM   #15
duder4thgen
Drives: Bird
Stock for stock its going to be a drivers race between the a6 and m6. If you are going to keep it stock, stick with what will make you happier on a daily basis. If you are going to mod it, I'm willing to bet the m6 is going to be a better place to start out at.
duder4thgen is offline   Reply With Quote
Old 02-21-2009, 08:47 AM   #16
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i would say if your going to mod it go with the auto, a 3000 stall converter and delete the afm, cam and a tune and you will blow away a 6speed manual with the same cam/bolt on mods
Old 02-21-2009, 09:36 AM   #17
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
Part of the AFM package is VVT and that will help with power efficiency from low to high RPMs. Just like advancing and retarding the spark does.
Parker is offline   Reply With Quote
Old 02-21-2009, 10:34 AM   #18
Grape Ape
Drives: 96 Bronco w/ a 5 speed
The AFM gear is in the block, not the heads.
Grape Ape is offline   Reply With Quote
Old 02-22-2009, 01:49 PM   #19
mike@newera
Here are some pics of the lifters for AFM/DOD which will be used in the L99:
The LS3 will have normal hydraulic lifters, a different valley cover, and it will not have this in front of the camshaft which is for VVT:
Old 02-22-2009, 02:46 PM   #20
CamaroSpike23
The Jalopy Jedi
that will be debated. actually it already has been debated.
but to add to your argument, there are a nice group of AFM G8's out there running superchargers as well with no problems.
regardless of which one you go with. they will both be bad ass from the factory as well as with adding mods.
I piss excellence
Old 02-22-2009, 02:51 PM   #21
Muscle Master
SS Lightning
Drives: An SRT8
at the cost of fuel economy, don't see the point of still having it active, the AFM
Old 02-23-2009, 08:57 AM   #22
CamaroSpike23
The Jalopy Jedi
I dont know what their mpg's are after the sc install, ill have to look into it. but the other thing to keep in mind is that EPA estimates are just that.... estimates.
just like the 4th gens where people were getting 30+mpg in their cars, im sure that both the LS3 and L99 will get better than the EPA estimates
I piss excellence
Old 02-23-2009, 09:02 AM   #23
duder4thgen
Drives: Bird
I agree, I take back my statement about the m6 being better to mod from. Might be a little simpler to start with, but in the end, once you get to a cam swap, there isnt that much more to swap out with afm than you would with a normal ls3. Guess its all up to driver preference.
Old 02-23-2009, 09:16 AM   #24
CamaroSpike23
The Jalopy Jedi
camming the L99 will be a little trickier as you have to allow some leeway with the AFM and the lifters. now if you tune it out and remove all that stuff and basically convert to an LS3, then cam swap to your hearts content
I piss excellence
Old 02-23-2009, 09:25 AM   #25
duder4thgen
Drives: Bird
Well, I'm not sure if anyone is making a cam right now thats compatable with AFM. I would think with the l99, if you are going to cam it, youre going to have to take out the AFM, which is a couple more parts than doing a cam swap on a ls3, but really not that much more labor.
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
LS3 vs. L99 LS3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-21-2009 10:39 PM
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 10:22 AM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 09:21 AM
