sjm autoprod
Old 02-21-2009, 09:39 AM   #15
duder4thgen
Drives: Bird
Originally Posted by epd313 View Post
I am looking for some advice. I ahve a 2SS A6 on order and keep thinking I should get the LS3 instead. Is there anyhting that says one is better than the other? Back in the day it was stick all the way. I have a stick in my 2000 SS, but have to admit, it gets old in traffic, maybe I'm just getting old, who knows. Technology today seems to point to the L99, any advise, I'm starting to get a headache and I have months yet to wait
Stock for stock its going to be a drivers race between the a6 and m6. If you are going to keep it stock, stick with what will make you happier on a daily basis. If you are going to mod it, I'm willing to bet the m6 is going to be a better place to start out at.
duder4thgen is offline   Reply With Quote
Old 02-21-2009, 09:47 AM   #16
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i would say if your going to mod it go with the auto, a 3000 stall converter and delete the afm, cam and a tune and you will blow away a 6speed manual with the same cam/bolt on mods
Old 02-21-2009, 10:36 AM   #17
Parker
Parker's Avatar
Drives: 2010 Camaro SS/RS
Part of the AFM package is VVT and that will help with power efficiency from low to high RPMs. Just like advancing and retarding the spark does.
Parker is offline   Reply With Quote
Old 02-21-2009, 11:34 AM   #18
Grape Ape
Drives: 96 Bronco w/ a 5 speed
Originally Posted by THE EVIL TW1N View Post
Also, the L99 may have the same heads found on the L76, since that too has AFM. Although the castings are the same as the L92 heads, to save costs the L76 (and possibly the L99) has heavier solid valves vs. the lighter sodium filled L92/LS3 valves.
The AFM gear is in the block, not the heads.
Grape Ape is offline   Reply With Quote
Old 02-22-2009, 02:49 PM   #19
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
Here are some pics of the lifters for AFM/DOD which will be used in the L99:
The LS3 will have normal hydraulic lifters, a different valley cover, and it will not have this in front of the camshaft which is for VVT:
mike@newera is offline   Reply With Quote
Old 02-22-2009, 03:46 PM   #20
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
that will be debated. actually it already has been debated.
but to add to your argument, there are a nice group of AFM G8's out there running superchargers as well with no problems.
regardless of which one you go with. they will both be bad ass from the factory as well as with adding mods.
I piss excellence
and fart awesomeness
Old 02-22-2009, 03:51 PM   #21
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
at the cost of fuel economy, don't see the point of still having it active, the AFM
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 02-23-2009, 09:57 AM   #22
CamaroSpike23
Truth Enforcer
I dont know what their mpg's are after the sc install, ill have to look into it. but the other thing to keep in mind is that EPA estimates are just that.... estimates.
just like the 4th gens where people were getting 30+mpg in their cars, im sure that both the LS3 and L99 will get better than the EPA estimates
I piss excellence
Old 02-23-2009, 10:02 AM   #23
duder4thgen
Drives: Bird
I agree, I take back my statement about the m6 being better to mod from. Might be a little simpler to start with, but in the end, once you get to a cam swap, there isnt that much more to swap out with afm than you would with a normal ls3. Guess its all up to driver preference.
Old 02-23-2009, 10:16 AM   #24
CamaroSpike23
Truth Enforcer
camming the L99 will be a little trickier as you have to allow some leeway with the AFM and the lifters. now if you tune it out and remove all that stuff and basically convert to an LS3, then cam swap to your hearts content
I piss excellence
Old 02-23-2009, 10:25 AM   #25
duder4thgen
Drives: Bird
Well, I'm not sure if anyone is making a cam right now thats compatable with AFM. I would think with the l99, if you are going to cam it, youre going to have to take out the AFM, which is a couple more parts than doing a cam swap on a ls3, but really not that much more labor.
Old 02-23-2009, 10:27 AM   #26
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
The only thing I am concerned about with the L99 are the cylinders wearing out quicker over the years on one side than the other and how that will affect things ten years down the road..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 02-23-2009, 03:19 PM   #27
CamaroSpike23
Truth Enforcer
depends on how big of a cam you are going with.
I piss excellence
Old 02-23-2009, 06:18 PM   #28
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
All pistons are always moving. And the fuel/valves deactivate two cylinders in each bank. No worries about wear.
Mr. Wyndham is online now   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 vs. L99 LS3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-21-2009 11:39 PM
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 11:22 AM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
