02-20-2011, 07:49 PM | #1 |
Banned
how to launch manual car...without dumping clutch?
anyone can give me advice or something on how to launch the car without dumping the clutch?
02-20-2011, 08:17 PM | #2 |
Drives: 2010 camaro Join Date: Aug 2009
i usually hold at approx 2800 to 3000 rpm and let off clutch quickly but not to quickly while accelerating at same time,, just lots of practice , but i am sc and if i did it any other way i would spin to bad...there are lots of factors which would make a diff...if you have drs, coming out the hole would be entirely diff...so really you have to just get a feel for your car...and if you start to wheel hop, get off throttle...wheel hop is the hardest thing...it will break something ..good luck
02-20-2011, 09:17 PM | #3 |
Banned
what is this...wheel hop u speak of ?
02-20-2011, 10:32 PM | #4 |
I tried to hold the car at around 3K and slip the clutch but just melted the tires. My technique is to start off idle and on the last yellow push down on the throttle while letting up on the clutch. I start out with the clutch pedal up almost to the point where it's starting to engage. I ride the clutch out almost all the way through the 60' and it seems like the engine stays at about 3K rpm while pulling the car out of the hole. The clutch reeks afterward but it has gotten me 2.0 60's with no spin or wheel hop on stock psi pirelli's.
02-20-2011, 10:34 PM | #5 |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
Hmm if you dont know what that is no offense but you shouldnt be drag racing a manual car yet. do some research on the basics first.
since i basically have the same car, rev to about 2,500 rpms and to launch without dumping you basically hold the clutch in its grabbing area longer to lengthen the amount of time it takes to transfer power to the wheels. if you just dumb it you send all the power at once which will just cause spin. you want to gradually, but quickly transfer power by doing what i outlined. a good launch will have a little spin but just some slight chirping. |
02-21-2011, 09:06 AM | #6 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
I hold it at 3500rpms, hold clutch just before it grabs...let go of the clutch slow for about a second or two and puch the gas...My car launches pretty hard like this with very little tire spin for a sec. I havent hit the track yet but it works on the street. You want as much RPM as possible and dont slip the clutch to much, if it smells after 1 launch you slipped it to much. Go practice on a back road, thats what I do.
10.91 at 122 H/C stock block N/A
03-02-2011, 12:17 PM | #7 |
NuptualNemesis
Drives: Silver 1SS M6 - 480hp 11.57/120.79 Join Date: Jul 2009
Check out this thread http://www.camaro5.com/forums/showthread.php?t=62548
03-11-2011, 01:28 PM | #8 | |
Drives: 2010 Camaro SS Join Date: Jan 2011
i think i missed something....why dont you just use the launch control feature the car comes with?
2010 camaro 2ss LS3
Corsa catback exhaust w/muffler delete, hennessey intake, Pfadt springs, Hurst Short throw Shifter, Murdered black. GO TEAM LS3 |
03-11-2011, 01:31 PM | #9 |
03-11-2011, 01:42 PM | #10 |
Cant believe i didnt catch that.
2010 camaro 2ss LS3
03-11-2011, 04:37 PM | #11 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
You might want to try the "knee jerk" method. I had to learn this method to get my manual 05 GTO off the line without wheel hop.
What you do is hold your rpms (say 3000 rpms) and just lift up on the clutch (knee jerk) to get the launch started. This is done WITHOUT adding any additional gas. You DO NOT push the gas pedal down until your car starts moving off the line. This method works great to prevent wheel spin and hop. So you do not lift the clutch and smash the gas pedal down at the same time. You wait a fraction of second after you start lifting up on the clutch (car starts to move forward) before you get into the gas. You can adjust your rpms based on the track conditions. When you're first learning this method you might bogg the launch (but you'll still run a faster 60' than if you had gotten wheel spin or hop). As you get better at it, you'll learn how to quickly get into the gas as soon as you feel the car moving off the line. Last edited by SGOS252382; 03-11-2011 at 05:43 PM. |
03-14-2011, 10:51 PM | #12 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Some really good advice in here. Now do those rear trailing arms really help wheel hop?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
03-17-2011, 11:29 PM | #13 |
Drives: '69 SS Convertible Join Date: May 2009
Absolutely.....I was getting wheel hop evertime. Put on a set of Spohn TAs and it all went away for me.
Build Journal |
Thread Tools | |
Similar Threads | ||||
Understanding Paint Correction-The Nitty-Gritty | Mr CLuTcH | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 29 | 03-02-2012 03:51 AM |
Camaro 2010 Issues | Tim's.2010.Camaro.SS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 57 | 06-04-2010 09:27 AM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
#4768 - Delivered and Made Ready the Right Way! | Number_9 | 5th Gen Camaro SS LS LT General Discussions | 62 | 07-16-2009 02:42 AM |
