Raymonds Performance
5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums.
Old 02-07-2009, 05:18 PM   #1
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
2010 Stang vs Camaro (seems unbiased)
http://www3.signonsandiego.com/stori...muscle/?wheels
The young, muscular man had stopped to check out the 2010 Mustang GT test car, painted Sunset Gold and optioned with the panorama glass roof. It was still about three months before the 2010 would be on sale and few had been seen on streets, but much has been written about it in magazines.
I introduced myself and volunteered some observations about the 2010 model, comparing it with the new Camaro. A logical association, I thought, because both cars will go on sale at about the same time this spring. April 17 marks the Mustang's debut in 1964.
Among my bullet points:
Mustang has a solid rear axle. The Camaro has an independent, multilink rear suspension.
Mustang has a five-speed manual or a five-speed automatic transmission. The Camaro has a six-speed manual or six-speed automatic with sport mode and steering wheel paddle shifters.
The Mustang V-6 has 210 horsepower. The Camaro V-6 will have 300-plus, or about the same as or more than the Mustang GT V-8.
I didn't intend for my words to come off as “Nyah, nyah, nyah,” but they may have.
“You're an auto writer?” said the young man in loud tones. “You are the DEVIL!”
Then he caught a breath, jammed a full clip in the chamber and pulled the trigger on a barrage that went something like: “You go ahead and tach up that Camaro to 4,500 rpm and when you dump the clutch and splatter the rear end all over the blacktop, don't come crying to me.”
His words didn't stumble or stray, each one a shiny hollow-point bullet aimed at the heart.
But I winged him on the horsepower.
“That's why mine has a supercharger,” he said, and our conversation was over.
The 2010 Mustang looks like a complete redesign, but it is a significant “freshening” of exterior design and interior improvements.
By making such cost-effective changes to the 2010 Mustang, Ford also will hold the line on pricing. While the entry-level Camaro starts at about $23,000, a comparable Mustang will start at $21,845. The Mustang GT (V-8) starts at $28,845. The GT Premium test car was almost $40,000 with nearly all available options.
The Premium package, $3,000 and available for V-6 or V-8, adds such extras as Sirius satellite radio, ambient lighting (foot wells, door sills and more), satin aluminum instrument panel trim, upgraded interior trim and Shaker 500 audio system. If this Mustang is your dream car, you will want this package.
Performance
The V-6 is a fit package with 210 hp and 240 foot-pounds of torque. Four wheel disc brakes – 11.8-inch at the rear – are very capable. But ABS is optional on both models.
Horsepower for the GT is up by five, but curb weight is also up a few pounds, so it's probably a wash in feel of acceleration force.
The 315-horsepower at 5,750 rpm isn't as important as the 325 foot-pounds of torque at 4,500 rpm. Put your foot down and this pony car pulls at the reins. It wants to run.
The five-speed automatic transmission works smoothly enough, but it doesn't offer a manual-shift mode or steering wheel shift buttons. I use this shift function, but not everyone does.
Ford was still sweating the fuel-economy numbers at the end of January, but it expects the Mustang V-6 to beat the Challenger V-6, which is rated 17/25. The Camaro V-6 was hoping to be certified for 27 mpg highway.
Solid rear what?
The improved ride quality between an '09 and the 2010 Mustang is instantly noted in a test drive.
But, OK, if you are going to drag-race your Mustang, you may not want an independent rear suspension. An independent rear end costs more and weighs more, but if you drive your Mustang the way most people do, the IRS can be smoother riding. The Mustang's solid rear axle still gives an occasional clunk over bumps, but there is a minimum of head toss over speed bumps or when pulling into driveways.
The 33.4-foot turning circle of the V-6 is a proud accomplishment, and the GT is no Bigfoot at 37.7 feet. The Honda S2000 roadster is almost 26 inches shorter, but it has a turning circle of 35.4 feet.
Inside, there is noticeable refinement in good-looking dashboard plastic and other soft-touch materials. Assembly and alignment of panels and trim pieces are accurate to within fractions of millimeters, Ford says.
The dashboard design still has some influence from the 1960s. Lighted gauges are a modern adaptation, but the half arc of the 140-mph speedometer is packed with hash marks for speeds. It's a guess to find 25 mph.
Ford's Sync system for voice-activated phone and audio controls continues to get easier to use.
The ride height is comfortable for old guys and the cabin has less wind noise at speed than before. But it's still not quiet – there's plenty of good sound to be heard from the V-8 and the ring of the pipes.
Sightlines are good over the “powerdome” hood and over the shoulder, aided by little corner windows.
The panoramic glass roof, $1,995, is unique – and not available on Camaro. The tinted, reflective glass keeps the cabin cooler on hot days than a steel roof; air-conditioning energy is 20 percent more efficient. A manually operated roller blind controls the amount of light in the cabin, and a layer of sound-absorbent vinyl is sandwiched in the special glass to trim noise, vibration and harshness.
The roof is a pricey option and one that has to be seen to be appreciated – or rejected.
For everything Mustang isn't, it does the important things very well. It is comfortable, easy to live with and it gets the blood pumping. Ford has tended to this enduring piece of history and continues to make it better.
MerF is offline   Reply With Quote
Old 02-07-2009, 05:35 PM   #2
Silver Streak
Silver Streak's Avatar
Drives: 2008 Cobalt SS/TC
Send a message via AIM to Silver Streak Send a message via MSN to Silver Streak
Where is the camaro side of it, if it unbiased? Is there more, because I am not seeing the comparing. All I seen was a few numbers thrown and a write up about the mustang.
Silver Streak is offline   Reply With Quote
Old 02-07-2009, 06:04 PM   #3
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
I enjoyed reading that, why can't all reviews be like this
^ and to answer Silver Streak question- They actually drove and tested both mustangs and they did not have a Camaro, what would be the point of comparing- I hate bench racing
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 02-07-2009, 07:36 PM   #4
MerF
Go Rays!
MerF's Avatar
Eh. Maybe it's a stretch to call it a comparison, but I thought it interesting that an article that is showcasing the new Mustang starts out with the comparison to the Camaro.
Old 02-07-2009, 07:38 PM   #5
Muscle Master
SS Lightning
Drives: An SRT8
All about the Heritage
Old 02-07-2009, 07:41 PM   #6
Silver Streak
I see your point! I just seen the Camaro in person for the 1st time today, and I can tell you this, I could never write anything unbiased comparing it with anything now lol.
Old 02-07-2009, 07:48 PM   #7
KatarHol
Drives: '04 Mustang GT
I'm going to start coming here for my Mustang updates. I thought this was a Camaro forum? Why is there a daily Mustang thread under every topic? For a supposedly "inferior" car,you guys waste alot of time fretting over it.
KatarHol is offline   Reply With Quote
Old 02-07-2009, 07:50 PM   #8
Muscle Master
SS Lightning
Drives: An SRT8
Because they are scared of the 2010 Mustang ... Let me rephrase
... They are cautious, the Camaro fans
Old 02-07-2009, 07:52 PM   #9
MerF
Go Rays!
MerF's Avatar
I get Google alerts for anything on the internet that shows up about the Camaro.
I get a mustang forum every day on at least one of the alerts.
Keep your friends close, and your enemies closer.
Sun-tzu
Chinese general & military strategist (~400 BC)
Old 02-08-2009, 07:23 AM   #10
TheCavalry
Here it comes
TheCavalry's Avatar
Drives: 2010 Camaro 1SS, '02 Lancer OZ
MerF just put the pwnage on lol
Ordered IBM 1SS 20" Polished Wheels
You want to kick ass, or fondle the door panels, sissy? - Jason Kavanagh
TheCavalry is offline   Reply With Quote
Old 02-08-2009, 07:43 AM   #11
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
This is a Mustang fluff piece where the writer is hoping after reading how much better the Camaro is in all specs that you forget about that point by the end of the article since there is no mention of the Camaro at the end.. This is to me a Mustang apologists thread trying to convince himself and the reader why the Mustang is still a great buy..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 02-08-2009, 01:25 PM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Know your enemy and know yourself and need not fear the result of a thousand battles.
Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP
No. Let me repeat that. No. FbodFather
Camaro5 Fest III Information
Camaro5 Fest III pre-registration
Old 02-08-2009, 01:34 PM   #13
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Its good to know revfiews on other cars. Im happy to hear the Mustang has gotten a bit better, but damm, i still know my Camaro is 10 times better.
ANyways the only thing im sweating now, is the speculated 4.0 DI v6 that the chally is supposed to be getting ina year. ( I think it was a 4.0)
Old 02-08-2009, 03:02 PM   #14
jakemaxx
jakemaxx's Avatar
Drives: 1969 impala
it just blows my mind that any one would buy a v8 mustang when the v6 camaro only has 11 less hp!!!! and the v8 camaro has 110hp on the gt.
jakemaxx is offline   Reply With Quote
Old 02-09-2009, 01:52 AM   #15
porcupinekiller
porcupinekiller's Avatar
Drives: 2010 GT500
I dunno....maybe because you can actually buy a new Mustang today and drive it.
porcupinekiller is offline   Reply With Quote
Old 02-09-2009, 09:31 AM   #16
DGthe3
Moderator.ca
DGthe3's Avatar
Because some people understand that there is more to going fast than peak hp. Power to weight, torque, and 'area under the curve' mean a whole lot more than peak power.
Old 02-09-2009, 09:52 AM   #17
wjones14
wjones14's Avatar
Drives: 2005 Mustang GT
Auto makers market horsepower figures for consumers exactly like you. Carroll Shelby said this many years ago: "Horsepower sells cars, but torque wins races." The average consumer continues to only look at horsepower, and ignores the more important torque number.
Go ahead and buy the Camaro V6 - it's a fresh car, a good deal and you get a lot of bang for your buck. Just don't try beating a Mustang GT with it, because you'll fail.
2005 Mustang GT, Screaming Yellow, Hurst 5-speed
Past cars: 1965 Corvette 396 Convertible, 1971 Olds 4-4-2 W-30, 1974 Z28, 1980 Z28, 1984 Z28, 1987 Mustang GT, 1995 Mustang GT - all M4 or M5.
wjones14 is offline   Reply With Quote
Old 02-09-2009, 10:11 AM   #18
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
You've got to love the perpetual, ever present, "Camaro V. Mustang" comparisons.
Which car is faster is only one measuring tool. You can choose any number of facts to argue which is better.
And rest assured, there'll be stories of V6 Camaro's beating GT Mustangs, just as there'll be stories of Mustangs beating Camaro's. It's as predictable as the rising of the sun.
My point is, enjoy which ever car it is you choose to drive. There will always be someone faster than you.
Moose is offline   Reply With Quote
2010 Baldwin Motion Camaro possibility.... MotionIII 5th Gen Camaro SS LS LT General Discussions 15 02-02-2012 06:18 PM
2010 meets 2008: Chevy Camaro named ‘Official Vehicle of 2008 SEMA Show’ Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 39 07-27-2008 12:46 AM
2010 Chevy Camaro to offer two V6s at launch; Z28 to trump SS? radz28 Camaro ZL1 Forum - ZL1 Specific Topics 51 06-23-2008 12:12 PM
