Old 02-20-2011, 08:28 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
pedders coilovers 1/4 track setting
well instead of trying to spend a lot of time with trial and error..thought i would ask ..who is running coilover and turning good times at 1/4 track...and has coilovers...i have pedders coilovers and would like to know are you tweaking out your coilovers , front and back? if so, where do you feel you are getting best ride in 1/4..i,m hoping pete or rob will give me some insight , i do have Pedders 2010 Chevrolet Camaro Track II kit and prob a little extra...could you give me some ideal settings for front and rear..thanks
mikepage0007 is offline   Reply With Quote
Old 02-20-2011, 10:47 PM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Sorry to be late in my reply. Can you answer a couple of setup questions?
1. RWHP
2. Wheel and Tire package
3. What are your alignment specs?
Old 02-21-2011, 06:49 PM   #3
600hp-lpe
Drives: 2010
... also, which Peddeers coilover's? the Xa's, or the supercars?
600hp-lpe is offline   Reply With Quote
Old 02-21-2011, 07:45 PM   #4
mikepage0007
Drives: 2010 camaro
xa,s...approx700 rwhp, 18in mh racemater dr,s...28in.tall ....and still running front 22in tires...27.8 inches tall..and i don,t know alihnment specs...it is a daily driver with 22,s , but 18 dr for track day..dropped 1 1/2 inch
Old 02-21-2011, 07:51 PM   #5
JusticePete
What you are looking for is optimal weight transfer at launch and on the 1 /2 up-shift.
1. Get you rear wheels as close to 0 camber as possible. The more square your rear wheels are to the track surface the greater the tire surface. More tire surface = lower ETs.
2. Set your front dampers to 3 off full soft.
3. set your rear dampers to the mid point of 15 off full soft
These will serve you well as a starting point and you can dial them in for your specific car and track conditions.
Old 02-21-2011, 09:43 PM   #6
mikepage0007
Drives: 2010 camaro
thanks pete...i usually have my rear set @ mid point, will try to soften up front..i will check with my perf shop as they did the alignment when installed my pedders kit
Old 02-22-2011, 07:40 AM   #7
JusticePete
You sire are welcome. Let us know how things work out at the track!
Old 02-24-2011, 07:17 PM   #8
mikepage0007
Drives: 2010 camaro
forgot to ask, many moons ago it was rumored that racing at dragstrip, lowered cars seem to break more axles than at stock height..something to do with angle of shafts on a dropped camaro..any truth to this...anyone clear this up, should i get out my spinner wrench and bring the ass up some? running approx 1 1/2 lowered..thanks again
Old 02-24-2011, 07:28 PM   #9
600hp-lpe
Drives: 2010
It is not so much the angle of the axles as compared to the stub that goes in the R end housing.
It has more to do with higher RPM launches, traction, and the Dreaded 'wheel hop'.
If the car starts wheel hopping, back off immediately.
Is your car Std or Auto?
Auto cars are more forgiving on the launch. Std trans are more harsh.
Don't launch in upper RPM's and you should be fine.
The axles break in one of 2 spots. Either they split the CV joint where the balls are, stretching the carrier for the balls to the breaking point, or they snap the axle where it slims down on the driver's axle.
The replacement 1000 HP axles from any of the vendors on the forum address these issues and give you piece of mind.
Quite a few people have broken the stock axles. I have heard of only a few breakages (like 3 or 4) with the HP axles. Anything can be abused to the breaking point.
Wheel hop is the biggest breakage culprit.
Old 02-24-2011, 08:09 PM   #10
mikepage0007
Drives: 2010 camaro
thanks for the input, it is m6, and did have wheelhop when stock , since all the pedders upgrades , have not wheelhop anymore, but then again i have to much hp @ 654 rwhp to wheelhop without drs..i ordered drs, and am gonna start off with approx 3k rpm and work up..but with drs, i could possible hook and wheelhop..so leaving at dropped height is ok?..no positive results from bumpimg back up to near stock height in rear.?
Old 02-24-2011, 09:05 PM   #11
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
Actually I think raising the rear would cost you traction be means of less weight transfing to the rear at launch. I have both the Nitto and Micky t DR's and still dont have any wheel hop with the Pedders Justice II package, why not skip the DR's for the track and go with the Boggart 17's with Hoosiers?
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 02-24-2011, 09:10 PM   #12
mikepage0007
Drives: 2010 camaro
well i just order my mh racemasters with 15% off for my z06 rims...supercahrged ss ran good with his mh dr,s and so have a couple others hit 8,s and 9,s with there mh dr,s..he feels the hoosiers are costing him on top end due to being so soft...drs roll harder and that can help et..plus 18in dr setup for 800.00, can,t beat it
Old 02-25-2011, 09:42 AM   #13
JusticePete
Changing the angle of the half-shafts will increase the operating temperature at speed, but should not increase the failure rate at the drag strip. Really sticky tires will increase the failure rate at the strip, especially so if you launch at high RPMs.
Old 02-25-2011, 04:10 PM   #14
mikepage0007
Drives: 2010 camaro
thanks again everyone, i will try to keep launches within a safe margin i hope, i will set dampeners at petes recomendation and leave at dropped height ..probably not even shift @ 6200, will shift a little early ..to try and prevent breakage..
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices JDP Motorsports Suspension / Chassis / Brakes 115 02-16-2015 08:42 PM
pfadt and pedders coilovers bmbbl be Suspension / Brakes / Chassis 47 02-14-2011 04:50 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 05:20 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 01:25 PM
