Flowmaster Exhaust
Old 02-21-2011, 08:28 AM   #1
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
exhaust welds leaking?
so i crawled under my car last night checking my nuts and bolts after having installed my headers-catback, and noticed little black dots where the welds are. they are pin holes (i'll get some pics up later) but leak non the less. is this normal and/or acceptable? not sure if its pressure that is blowing the exhaust out, i wouldn't think so since its 2.75" or is it just from condensation buildup leaking out with carbon deposits? any insight is appreciated.
thanks
hapisok is offline   Reply With Quote
Old 02-21-2011, 08:48 AM   #2
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
At weld points?? Sometimes with mufflers, they have weep holes to drain condensation build up, but weld points are usually areas that need complete sealing.
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 02-21-2011, 09:26 AM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
yup....exhaust leaks.....
going to have to go over it again.... the welds are going to look like crap now.
This is why I always suggest using band clamps isntead of welding.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 02-21-2011, 11:33 AM   #4
hapisok
hapisok's Avatar
kinda sucks...the only welding done was by the manufacturer. is it possible flow some solder with a torch to fill it or would it just melt? kind of a noob at this but i get the general idea.
and its definitely NOT a weep hole. i saw the weep hole on the stock exhaust, and thats why all the stock ones have black suit on the bottom of the cans.
thanks for the feedback
Old 02-21-2011, 11:42 AM   #5
danhr
BAMF SS
danhr's Avatar
sounds like a manufactor defect.
Old 02-21-2011, 11:42 PM   #6
J.L.TYCHE
Tampa Gulf Coast Family
J.L.TYCHE's Avatar
Drives: 2011 Corvette
What welds are leaking? between the header and cat? or on your cat back system?
J.L.TYCHE is offline   Reply With Quote
Old 02-21-2011, 11:46 PM   #7
J.L.TYCHE
J.L.TYCHE's Avatar
Is the weld leak on the ARK cat back system,or where your headers are welded to your cat back? Are you cat less with tubes between the headers and cat back ?
Old 02-22-2011, 06:24 PM   #8
hapisok
hapisok's Avatar
its on the cat back. its not a noticeable leak, one that would cause rasp or anything like that. just noticed little carbon deposits around some of the weld joints. after rubbing the carbon off, pin holes/pits were visible. not a bust on the system as they made it look clean without having big beads of weld around the seams...just annoying really. i'll get some pics up this evening.
Old 02-22-2011, 06:29 PM   #9
LS3SuperSport
HotRod
LS3SuperSport's Avatar
Drives: 2010 Camaro 2SS M6 Black/IO Int.
more than likely porosity in the welds, it happens when welding over rust/ carbon, etc.. or when the gas being used with the MIG welder is low or off.
LS3SuperSport is offline   Reply With Quote
Old 02-22-2011, 06:49 PM   #10
hapisok
hapisok's Avatar
interesting...just learned something today. thanks
Old 02-22-2011, 06:55 PM   #11
LS3SuperSport
HotRod
No problem
Old 02-22-2011, 06:59 PM   #12
hapisok
hapisok's Avatar
here are a couple pics. oddly enough, the carbon build up is on two different pipes but in the same area. almost directly across from each other. so if it were an issue with the gas, that would make sense i suppose...not a welder. did some ark welding back in shop class but that was years ago.
Old 02-22-2011, 07:04 PM   #13
LS3SuperSport
HotRod
looks like a combo of lack of fusion and porosity.. hard to explain but its weld defects from the manufacturer
Old 02-22-2011, 07:05 PM   #14
hapisok
hapisok's Avatar
what kind of long term effects could it have on the welds?
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 606 Today 05:18 AM
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
*/* Exhaust and Intake's */* Borla/Magnaflow/ Agency Power/ K&N/ AEM */* ImportImage V8 Bolt-Ons & Tunes 73 11-01-2010 11:21 PM
RPI Designs KOOKS HEADERS AND EXHAUST SYSTEMS on sale thru September! RPI Designs V8 Bolt-Ons & Tunes 3 08-04-2010 04:17 PM
