Caryle Racing
View Poll Results: T Tops or Carbon Fiber?
T Tops 14 73.68%
Carbon Fiber Conversion (Fenders, doors, etc) 5 26.32%
Voters: 19. You may not vote on this poll
Old 04-29-2011, 01:35 AM   #197
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Originally Posted by Rickerbucks View Post
That was a GREAT drive from Quartzite into Pheonix was it not. LOT of fun in that convoy.
YEAH! soooo much fun......love the look of your car! still looking for a place that will lay my roof in carbon fiber!, any pics of your interior? i noticed a couple people asking lol
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 04-29-2011, 05:21 PM   #198
pyr0b0y
need....more....hp
pyr0b0y's Avatar
got my plates to compliment my engine:
SS BEEST
Gota wash the car tomorrow for a car show so ill post an actual pic tomorrow
Old 04-29-2011, 05:42 PM   #199
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
SS BEEST
I like the bee reference!
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 05-03-2011, 12:42 AM   #200
pyr0b0y
need....more....hp
pyr0b0y's Avatar
ordered a set of Nitto 555Rs today, 305s. they should be in later this week! found out the CF hood is a little further on backorder than expected, 6 WEEKS! but good new is that my CF guage pod and center bezel will ship next Friday .
cutouts will go on next week along with my new set of mufflers. Roll cage and harnesses should also be ready to go for the AutoX in marina on the 15th.
spoke more to my shop about getting a new engine. right now im probably gunna be getting a 418 stroker LS3. but i found out that since its a bigger engine the blower wont do as much as it is now. if i go down to smaller pulleys.....probably have about the same rwhp as now. so now i gotta look at switching to TT or a bigger supercharger. i see lots of people running prochargers, but then i would lose my tq #s as well. I love how the maggie has an even distro of hp and tq. also someone is running a 427 TT and has 793hp/8??tq. gotta do some more research.....any input?
Old 05-03-2011, 01:03 AM   #201
Silver2SSRS6spd
Prefer to be blown!
The Auto-X is on the 21st, trying really hard to get my car ready.
I say that you should get a your bottom end built to boost specs so you can run 10 or more PSI. The maggie should be good to close to 1000hp I think!
Old 05-03-2011, 02:22 AM   #202
pyr0b0y
need....more....hp
pyr0b0y's Avatar
it says AutoX is on the 15th? do i have the right sight?
http://www.norcalufo.org/main/index....ents&Itemid=59
and btw im gunna call magnusen tomorrow and find out what i can do about swapping to the 10 rib setup with the smallest pulley setup they have....i no a couple people are running into belt slip problems.....yes i can go to 700-750 on the LS3 built, but it would be nice to do a stroker or something different....
Old 05-05-2011, 11:15 AM   #203
pyr0b0y
need....more....hp
pyr0b0y's Avatar
went out to the drag strip last night. made my first pass ever and got a 13.060, missing a gear with a HORRIBLE R/T. made a second pass and (i think) completely blew my clutch (hopefully thats all!). couldnt drive it at all so had to get it towed back to Blu808. my shop is in Atlanta for a FormulaD event and wont be back till Monday night. My car was scheduled to go in for work on tuesday anyways. As of right now, by the time i get my car back on the 14th, i'll have:
new clutch
roll cage
Sparco harness belts
electronic cutouts
new mufflers
steel braided brake lines
cross drilled/slotted rotors
carbon fiber center console bezel
carbon fiber dual gauge pod
Autometer AFR Gauge, Wideband meter
Nitto 555R Drag Radials
Old 05-05-2011, 11:31 AM   #204
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
Ouch, what rpms was you launching at? Also if you dont have a driveshaft loop on there yet for safety, you need one with that power & tracks require it. Good luck with the upgrades, sweet car man
*Powered by Maggie**553rwhp 541rwtq*
ddavis is offline   Reply With Quote
Old 05-05-2011, 11:52 AM   #205
pyr0b0y
need....more....hp
pyr0b0y's Avatar
didnt look, but nothing higher than 2500 (for a split second), than got into it and it broke. that was my first time just flooring it from pretty much a stop. they told me i need a flameproof jacket and driveshaft safety loop before i come back.....
Old 05-06-2011, 05:06 PM   #206
pyr0b0y
need....more....hp
pyr0b0y's Avatar
finally decided on the type of engine im going with . its gunna be a 418 stroker LS3 with twin turbos. I decided on the 418 over the 427 because Texas Speed mentioned the 418 is moer applicable for boost rather than the 427, which is used more for N/A (at least the aluminum block is). Its not all going to happen at once, but ill have the engine built, installed, then sell my current block, sell the supercharger, then buy the twin turbo setup. For the twin turbo setup, i spoke with hellion and will be getting 61mm or 64mm ball bearing turbos to cut down on the turbo lag. The 61mm supports up to 1000hp, and the 64mm handles up to 1200rwhp. The injectors will need to be at least 80ft/lbs; more than likely ill go with 90 to be safe....more details to come later.....
Old 05-06-2011, 06:48 PM   #207
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Very nice Josh!!
Old 05-06-2011, 07:16 PM   #208
pyr0b0y
need....more....hp
pyr0b0y's Avatar
hoping to get 1000 by my 21st bday in august lol
Old 05-06-2011, 07:21 PM   #209
WadeWilson
How U Doin?
WadeWilson's Avatar
That's just crazy!! 1,000 at the crank or 1,000RWHP? Either way you're crazy.
Not that there is anything wrong with being crazy.
Old 05-06-2011, 07:25 PM   #210
pyr0b0y
need....more....hp
pyr0b0y's Avatar
1000hp @ the crank for sure! well have to see if my bank account has enough zeros left to get me up to 1000rwhp
carbon fiber intake, goldrush rally 4, the neighbor hater, tron camaro, twin turbo
Tom Henry Racing THR22 2010/LS3/IBM/Supercharged SS Camaro [COTW 10/29/12] GTAHVIT Member Car Journals 5217 06-27-2016 09:14 AM
3rd Gen Camaro Street Stock build thread (dialup beware) zlathim 3rd Generation Camaros 7 02-20-2013 12:04 AM
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-05-2010 12:49 AM
Anyone in St. Louis want a black SS March build Camaro Sean_W Camaro Price | Ordering | Tracking | Dealers Discussions 11 03-08-2009 02:31 PM
