Cold Air Inductions
Old 02-21-2011, 03:45 PM   #1
PB3
PB3's Avatar
Drives: 2010 CGM 2LT/RS/GFX/M6
Race Ramps
Alright, did the first oil change on the car since dropping it. What PIA that was. My low-pro jack wasn't long enough for me to reach the floor jack points on the front of the car. Anyone that dropped their cars have the Race Ramps? Where you able to climb them without rubbing? I used to use the Rhino Ramps for my wife's car but the front splitter from the gfx was no going to let it work. Besides those things suck a monkeys choad and slide everywhere.
I have Eibach springs.
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
PB3 is offline   Reply With Quote
Old 02-21-2011, 03:50 PM   #2
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
I have the Griot's Garage low profile Jack (little expensive though). No issues that way. I have the Pfadt springs, lowered 1.25".
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 02-21-2011, 03:57 PM   #3
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I dont have mine dropped but I do have the Race Ramps, that one piece 67'.
I highly recommend them. I dont think you would have an issue even being dropped and if you did just get a spacer like a 1 x 10 piece of wood to step up too. However vettes use these with no issue.
Cheers
K
Moriartii is offline   Reply With Quote
Old 02-21-2011, 04:27 PM   #4
PB3
PB3's Avatar
Wow, good looking jack! I think the Race ramps would have a bit more benefits to my purpose than a $400 jack.
Old 02-21-2011, 04:34 PM   #5
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
Just got my Race Ramp Trak Jax last week, haven't had a chance to use them. Take a look, much less expensive that the ramps themselves just to get it off the ground a little.
Old 02-21-2011, 04:58 PM   #6
PB3
PB3's Avatar
Nice! Thanks for mentioning these. These would be perfect!
Old 02-21-2011, 05:16 PM   #7
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
I have Race Ramps Trak Jax and Pedders Xas at full drop and my car goes right on the ramps without rubbing. One recommendation I have is to avoid the set with the built in stops. They make it hard to get the wheel fully on the top of the ramp. I have a flat set for the rear and the set with stops up front. I wish they were all flat.
Kilo-9 is offline   Reply With Quote
Old 02-21-2011, 05:24 PM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I just use some 2"x6" studs for extremely lowered cars. I think i spent $10.
SUX2BU is offline   Reply With Quote
Old 02-21-2011, 05:56 PM   #9
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 02-21-2011, 06:26 PM   #10
camarowa
camarowa's Avatar
I definitely did not spend $400, think it was $199. But still......Have been looking at the race ramps mentioned here, might have to pick a set of them.
- Airaid CAI V2
Old 02-21-2011, 07:47 PM   #11
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
24" 2x12s with truck bed-liner solve the jack problem and serve as a transition to the ramps. We use them in our shop all the time. Actually we have them 48", 36", 24" and 18" lengths.
Old 02-21-2011, 07:55 PM   #12
600hp-lpe
Drives: 2010
Me too... lot's of 2X12's in various lengths that I beveled the edges on 30deg angles so they don't kick up when driving on them.
I have one per tire to drive on to get the low profile floor jack to fit underneath the lowered Camaro, and some more for loading the car into the trailer.
600hp-lpe is offline   Reply With Quote
Old 02-21-2011, 09:29 PM   #13
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Eibach springs here with 67 race ramps not problems front nor back.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 02-22-2011, 03:42 AM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
No need to spend a fortune unless you just want expensive stuff, or you use them ALL THE TIME. My theory is, I don't have my car up on jacks more than a couple times a year so why invest a small fortune in them. A decent race jack can be had for less than $100 at HF, and two 1-2ft long pieces of 2x4 can be found. Run the front tires up on the 2x4's and the jack will slide under without a problem.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
A bad @$$ race.... SSE 4 2SS 5th Gen Camaro SS LS LT General Discussions 22 11-02-2010 08:57 PM
Race or Not to Race? There's only one honest answer... DCCAM 5th Gen Camaro SS LS LT General Discussions 34 06-01-2010 11:59 PM
QTP GM EFI Race Series Raceway Park NJ 10/24 Quick Time USA - NY / NJ / PA 0 10-09-2009 10:04 AM
Donohue to race Camaro heavyt100 Camaro Motorsports Discussions 2 09-18-2009 12:56 PM
