R1 Concepts
Old 02-21-2011, 08:13 PM   #1
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Question Getting rid of the roller skates.
The oem brakes on my early build have those "roller skates" on top of them. To fit under my new 17" Bogart wheels, I gotta' make a change. Can I chisel the offending little devils off them? However they are removed, will the brakes perform differently? I assume that the "roller skates" were an attempt to "band-aid" a chattering sound in the brakes, am I right? So taken 'em off may cause a sound with which I'm willing to live, but the brakes will work as they did before the "surgery", correct?
I thank you fellahs, in advance.
Ivas is offline   Reply With Quote
Old 02-21-2011, 09:44 PM   #2
Redemption
Just Because!
Redemption's Avatar
Drives: 2010 SIM 2SSRS
Cut them off, or might as well upgrade the pads! =)
Redemption is offline   Reply With Quote
Old 02-21-2011, 10:34 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I don't have the SS but am upgrading to the SS brakes very soon. If my calipers have the skates, changing the pads will remove them? The pads are getting replaced with Hawk Ceramics before they go on the car.
[B]
Old 02-21-2011, 10:40 PM   #4
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
they are weights to stop squealing....cut them off and you will get noise for sure just go to hawks pc's....
THE "MENACE"
Capthowdy is offline   Reply With Quote
Old 02-23-2011, 09:21 PM   #5
JusticePete
Wrote the 5th Gen Book
JusticePete's Avatar
Drives: Camaro Justice
The Brembo brake squeal is common to many different vehicles and brands. Some Camaro owners are very sensitive to brake squeal in part because the 5th Gen is so quiet. You won't change the braking characteristics of your Camaro. If you are using Bogarts, you probably have some RWHP mods that raise the ambient noise level so you may not hear the brakes any way.
Old 02-25-2011, 07:17 PM   #6
Ivas
el Ruco
Thanks fellahs,
I took your advice and ordered the Hawk ceramic shoes from Jegs. There's no point in screwin' around with the skates and the OEM shoes when I should upgrade to ceramic in accord with my car running 11.2's in the quarter mile. It' safer overall.
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 03:57 PM
***STILLEN Camaro5 SS Brake System Upgrade Package*** Team STILLEN Suspension / Chassis / Brakes 20 08-06-2010 10:49 AM
getting a brake booster cuircut cel after maggie install. hot ss Forced Induction - V8 7 09-28-2009 07:19 PM
