JDP Motorsports
Old 02-21-2011, 10:16 PM   #1
MG
MG's Avatar
Drives: 2011 Camaro
Anyone switched to Z06 brakes?
I know at least one person has the ZR1 carbon ceramics but I've read that they're computer controlled so it would be too complicated to get them right.
And I know some people are using CTS-V brakes.
How about Z06/GrandSport brakes?
MG is offline   Reply With Quote
Old 02-22-2011, 03:33 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The CTSV brakes are better. I have friends with both and the CTSV with its massive weight disadvantage is considerably better at braking than the Z06. I think it has to do with the brake pad area. The CTSV has more. I seem to remember a thread where someone posted the Camaro vs Z06 braking distance and the Z06 was no better, even with a weight advantage.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-22-2011, 11:48 AM   #3
Chris_B
Chris_B's Avatar
Drives: Several
The Z06 brakes would be a downgrade from the SS brakes from a performance and longevity standpoint. They might look a bit better (depending on personal opinion), but that would be the only possible improvement.
Chris Bernal
Brake Maven
Chris_B is offline   Reply With Quote
Old 02-22-2011, 06:12 PM   #4
pbm457
pbm457's Avatar
Drives: 2009 Dodge "Cuda", 2010 Camaro
the Z06 brakes have padlets instead of two pads that our cars or the CTS-V has. Z06 brakes= a step in the wrong direction.
pbm457 is offline   Reply With Quote
Old 02-22-2011, 06:15 PM   #5
IROCanSS
Drives: 89 IROC 350
Well there ya go...
Old 02-22-2011, 07:17 PM   #6
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
I agree 100%. I have a Z06 and have tried several compounds with the stock calipers and have had nothing but issues. An easy fix for someone with that caliper is going with a Hawk or Cobalt single pad conversion, thus getting rid of those stupid padlets/hockey puck they call brake pads
The smaller pads can't control the heat the same way as a larger pad, plus the larger pads have a larger surface area which aids in stopping power, temperature and control.
The 6-piston Brembo upgrade caliper or the CTS-V kit would be a better and more affordable direction to go in!
/Erik
Erik@Torq is offline   Reply With Quote
Old 02-22-2011, 07:36 PM   #7
Chris_B
Chris_B's Avatar
Drives: Several
And let's not forget that swapping in a larger, 1-piece pad still gets energized by three identically-sized pistons. This is far from the ideal of a sequentially-sized piston stagger. Pad taper issues will result where proper 6-piston caliper design eliminates taper. The larger pad will run cooler, but will not stop any better and will taper under hard use.
Chris Bernal
Brake Maven
Old 02-22-2011, 07:40 PM   #8
Erik@Torq
Erik@Torq's Avatar
You are absolutely right, great info right there.
Old 02-22-2011, 07:52 PM   #9
MG
MG's Avatar
Drives: 2011 Camaro
Interesting!
Thanks for the help
ZL1 / CTS-V Brakes JusticePete Suspension / Brakes / Chassis 581 02-13-2016 11:39 AM
brakes losing power assist? 1977and2010 Suspension / Brakes / Chassis 6 02-28-2010 06:31 PM
has anybody changed the v6 brakes to the SS brakes? camarowa Suspension / Brakes / Chassis 19 01-24-2010 09:12 AM
question about brakes Fotowns Finest 4th Generation Camaros 12 11-05-2009 05:09 AM
2007 Chevrolet Corvette Z06 Ron Fellows Championship Edition KILLER74Z28 General Automotive + Other Cars Discussion 14 04-10-2007 10:29 AM
