02-22-2011, 08:53 AM | #1 |
Drives: 2010 Camaro SS (LS3, 150-Shot N2O) Join Date: Jan 2011
Going sprayed for first time. need a little help
Ok. So I've been driving forced induction tuners for years now. I finally sold my last one (an SRT4) and decided to get a LS3 camaro.
I'm wanting to go a little different this time around. I'm wanting to use nitrous, but I'm not sure exactly what all I need to go sprayed. First question. How much is decently safe? I've heard 150 isn't a bad a shot for the LS3. My main question: If I spray a 150wet shot. What cam would be best for me? Brand? Lift? Duration? I've heard of LS2 guys talking about using a .620 on the bottle. I've already got a local LS2 tuner/expert that is going to tune the car and has offered his opinion on this, but I wanted to check here as well. |
02-22-2011, 10:30 PM | #2 |
Drives: 2010 Camaro SS Join Date: Feb 2010
All you need to spary an LS3 is the kit. Other parts I recommend is a window switch or progressive controller, bottle heater and pressure guage. Remeber to pull timing either in the tune or using an MSD box. Cam really doesn't matter much with spray. 150 is a safe shot on an LS3 with the proper timing pulled.
02-23-2011, 07:37 AM | #3 |
k. would an MSD box only pull timing when the system is armed? Id rather not pull timing with my trinity since I wont always be spraying at WOT.
02-23-2011, 07:50 AM | #4 |
BAMF SS
150 is fairly safe
You need to pull timing, if you have an aftermarket tune on your car. There is no way around that. If you want to risk blowing up your motor, than don't. There are lots of ways to pull timing just when you are spraying and not when you aren't. like the lingenfelter controller or the hsw interface. I have no experience with the MSD unit, so I can't say there Don't bother about cam specs. Getting a "nitrous cam" is for people who run big shots of nitrous (250+). If you aren't spraying that much, than don't worry too much about it. a window switch is damn near necessary (I wouldn't ever do the fast and furious push button setup in a car), a progressive controller is nice, but isn't worth it really in your situation. Bottle heater should also be considered necessary, with a 150 shot, i wouldn't bother getting a nano setup. Same goes for a purge... not only for just the cool factor but for the function (and it's cheap) Blow down tube is strongly recommended fuel pressure safety switch is retarded
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
02-23-2011, 10:16 PM | #5 |
The LPE LNC-002 box isn't available yet. They should be re-releasing it soon. The MSD box has a knob to toggle between the 2 tunes. The added benefit with the LPE unit is that it also doubles as a launch controller.
Similar Threads | ||||
CF2 SoCal Convoy Meet up locations and Times | comm17 | California Meets and Events | 87 | 04-12-2011 10:11 AM |
Hankook, CGR, Blu808 Camaro Sets time attack lap record. | Blu808 | Camaro Photos | Spyshots | Video | Media Gallery | 31 | 03-14-2010 03:38 AM |
Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 11:57 AM |
First time Camaro owner, long time fan... needs advice | Kalden | Cosmetics and Lighting Modification Discussions | 3 | 07-12-2009 08:36 AM |
Time Problem? Maybe? | TAG UR IT | Site Related Announcements / Suggestions / Feedback / Questions | 9 | 08-30-2007 03:53 AM |
