Old 02-23-2011, 01:06 AM   #1
havoksin
Drives: 2011 Silver Camaro LS
Steering Wheel Controls and PDIM Add-On HUGE question
Does the BCM update apply to both, like its the same update? Or is it one update for the Steering Wheel and one for the PDIM? If it's just one update, can you install the PDIM for example, update it, and install the steering wheel controls later and have it work right away?
havoksin is offline   Reply With Quote
Old 02-23-2011, 05:28 AM   #2
EDGE_
EDGE_'s Avatar
Drives: 2010 1SS/RS SIM L99
No they are separate updates. I did exactly that, I installed my PDIM, got it working and then I installed my SWC a few months later and had to take it in to get programmed before it would work.
EDGE_ is offline   Reply With Quote
Old 02-23-2011, 06:44 AM   #3
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
I installed the PDIM and steering wheel controls on the same day and took the car in to get them activated and was amazed that the service people didn't even know that they were separate. The reprogrammed the BCM for the steering wheel controls and when I picked the car up told me it was all ready. When I went to check to see if everything worked, the USB did nothing nor did the normal AUX jack. They argued with me up and down that they did everything required. When I told them that the PDIM and steering wheel controls were separate issues they looked at me like I had 3 heads. I had to actually go back into the garage area and #1 prove to them that it was a programming issue since the USB did have power on it (so it was hooked up correctly) and #2 tell them how to program it (with the instructions I had left with them earlier in the day). Complete incompetence. I should have gotten overtime that day (since I work for GM). Be sure to have documentation for both and repeat many times that it's 2 separate programming instances. The steering wheel controls need a BCM reprogram and the PDIM needs a simple radio update (not a reprogram). They simply update your car's profile on the master GM site that you now have a PDIM and then they send that information to your radio. Whole process for the PDIM takes like 5 minutes. The BCM is 45 so in total you should only pay for an hour of labor.
Darth Martel is offline   Reply With Quote
Old 02-23-2011, 10:53 PM   #4
havoksin
Thanks for your replies! It seems like YMMV when it comes to knowledge and prices for the dealerships. I'll give them a call before I install anything. Thanks again!
Details about PDIM & Bluetooth functionality & upgrading your non C&C car with them Matt'sSS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 02-09-2015 07:56 AM
PDIM Question. (Very Important!!) infinitiboy92 5th Gen Camaro SS LS LT General Discussions 11 11-23-2010 10:59 PM
installed PDM and Steering Wheel controls...question 2010IBMSS 5th Gen Camaro SS LS LT General Discussions 15 10-19-2010 04:37 PM
Put in PDIM and programmed;now question Mass SS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 10-10-2010 08:42 PM
Transformer Edition Camaro Questions 2010bumblebeeSS 5th Gen Camaro SS LS LT General Discussions 17 04-21-2010 10:05 PM
