sjm autoprod
Old 02-24-2011, 07:42 AM   #1
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Camaro tuner in Tampa. Corvette tuner in Tampa. Firebird tuner in Tampa. Trucks
www.TampaTuning.com Still the best priced tuner anywhere!
Welcome to www.TampaTuning.com where we specialize in high performance custom computer reprogramming of General Motors powered LS 1 through 9 powered muscle cars and trucks. Our high standard for customer service guarantees you’ll love the performance gains at prices your spouse can tolerate.
www.TampaTuning.com will design a customized remapping of your vehicle’s computer (PCM) for optimal efficiency. Our tuner has nearly 9 years of tuning experience and has been trained at the basic and advanced tuning schools which specialize in dyno tuning General Motors equipped vehicles with HP tuners software. We are located in South Tampa about 3 miles from MacDill Air force Base.
We use the most powerful updated version of HP Tuners software which unleashes the horsepower and torque for an assortment of General Motors vehicles. Our computer enhancements will make your motor more efficient. www.TampaTuning.com specializes in the following high performance cars and heavy duty trucks for tuning:
1997-2011 Chevrolet Corvette C5 & C6 including ZR1, Grand Sport, Z06s
1998-2011 Chevrolet Camaros Generation 4 and 5 Z28, SS, RS
2002-2011 Cadillac CTS, STS, XLR, SRX, DTS, Escalade
2000-2011 Avalanche, Hummer, Tahoe, Suburban, Yukon, Silverado V8s
1998-2002 Pontiac Firebird, WS6, Trans Am
2003-2004 Chevrolet SSR 5.3
2004-2006 Pontiac GTO
Our total street performance tuning package for $245.00 will include:
- Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
- Examine and change timing tables for additional horsepower & torque gain
- Optimize your vehicles Air and Fuel Ratio monitored by the LM-1 wideband unit
- Reduction of intake air temperature table (heat soak)
- Desired rev limiter adjustments
- Park, neutral, and in- gear idle adjustments with and without A/C active
- Adjust power enrichment delay to immediate (*Transmission Performance*)
- Engine torque management system reduced (*Transmission Performance*)
- Transmission torque management system reduced (*Transmission Performance*)
- Transmission shift points enhanced (*Transmission Performance*)
- Transmission shift times reduced (*Transmission Performance*)
- Transmission shift pressure firmness enhanced (*Transmission Performance*)
- Skip shift deleted (CAGs 1st to 4th shift) (*Transmission Performance*)
- Fuel injector rescaling for aftermarket injectors
- Cooling fan activation temperature recalculated
- Perform speedometer recalibration for rear gear ratio and tire size change
- Turn off check engine light and remove trouble codes
- Neutralize rear oxygen sensors
*Transmission performance package for $150.00
Tampa Tuning recognizes that the A4 and A6 automatic transmission owners just want their sloppy, slow shifting and sluggish transmissions tuned for a performance feel. For those owners, we designed a transmission only tuning package. We will reduce your vehicles engine and transmission torque management system and re-flash only transmission settings indicated above by *Transmission performance* notation. This will be a very noticeable change in your vehicles performance!
Torque management reduction tune for $75.00
For the drivers that just want a noticeable change in your vehicles performance, and are tired of the 1st to 4th CAGs skip shift, Tampa Tuning will reduce your vehicle’s engine and transmission torque management system and neutralize your CAGs. You will be surprised and pleased with the torque management tune. Many drivers who use their vehicle daily say just turning off the CAGs are worth the price and the extra seat of the pants torque is a bonus.
Email order tunes for $110.00
If you own or have access to HP Tuners software, you can Email your stock .BIN file to Tampa Tuning where it will be reviewed and properly enhanced for a “Email order” tune. Your tune will be enhanced by using HP Tuner tables from our library of modified configurations which have a very similar set up as your make and model vehicle.
Contact our tuning team at: Tuning@TampaTuning.com for your tuning needs questions.
Tampa Tuning is offline   Reply With Quote
camaro tuning, tampa, tuning
