Old 02-24-2011, 03:30 PM   #1
steeleshark2
steeleshark2's Avatar
Rear Trailing Arm Bushings
Is it worth changing the bushings when I get some BMR rear trailing arms put on?
Old 02-24-2011, 03:40 PM   #2
RAYSRT8
RAYSRT8's Avatar
Drives: 2011 Challenger SRT8 6.4L 392 Hemi
I think it's worth it, but they are a bear to get out... Make sure that you have a good C-Clamp 6" or larger and I used a 2" pipe fitting with a cap as a receiver to press the bushing into. Before you start pressing it be sure to cut away all excess on both sides of the bushings.
Hope this helps.
2011 Stock 6.4L 392 Hemi Challenger
Flowmaster American Thunder Series Cat Back
Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474
RAYSRT8 is offline   Reply With Quote
Old 02-24-2011, 04:22 PM   #3
steeleshark2
Hope this helps.
I was just gonna get my shop to do it. They are going to be doing a lot to my car before I get back to the states and was wondering if I should get them to do the bushings. Thanks for your input.
Old 02-24-2011, 04:34 PM   #4
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
If you don't do it, it will be the weak point in the trailing arms subframe to knuckle link. Is it totally necessary??? I would do it though.
http://camaromodz.com/trailingarms.htm
Jaysin is offline   Reply With Quote
Old 02-24-2011, 04:51 PM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
I always recommend replacing the outer bushings anytime you upgrade the trailing arms. They work together and should be replaced together if possible. The only reason we do not include them with our trailing arms is because there are other companies that sell these bushings as well.
Our outer trailing arm bushings are manufactured from the same durometer rating polyurethane that we use on our Trailing arm bushings.
BMR guy is offline   Reply With Quote
Old 02-24-2011, 04:56 PM   #6
orange-prince
QATAR 2022
orange-prince's Avatar
Drives: black cts-V coupe a6
is that bushings comes with the BMR level3 package ?
orange-prince is offline   Reply With Quote
Old 02-24-2011, 05:07 PM   #7
steeleshark2
Already ordered a BMR kit from Apex-Speed. Thanks everyone!!
Old 02-24-2011, 05:12 PM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Yes, these come in the Level 3 package.
Old 02-24-2011, 05:15 PM   #9
orange-prince
QATAR 2022
thanks cuz ill order the BMR level3 plus BMR rear trailing arms this week
Old 02-24-2011, 05:32 PM   #10
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
You won't be disappointed!
Old 02-24-2011, 06:09 PM   #11
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
+1
Thanks for your order! PM sent.
I look forward to hearing from you.
PFADT rear trailing arm install question bigsquirrel Suspension / Brakes / Chassis 5 12-25-2010 05:28 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Delrin Bushings LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 03:05 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Spherical Rod Ends LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:59 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Toe Links with Polyurethane Bushings. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:55 PM
