BeckyD @ James Martin Chevy
Old 08-01-2007, 10:53 AM   #1
Tran
Administrator
Tran's Avatar
Post Spotted: Camaro mule clad in VE Commodore shell
Originally Posted by Tran
Don’t be fooled by the decoy rear doors—this is likely a test car using the wheelbase of the Chevrolet Camaro.
No, it's not a Holden Monaro. Instead, this specially modified, two-door VE Commodore seen by a sharpeyed Drive reader in East Melbourne recently is most likely a test car using the wheelbase of the 2008 Chevrolet Camaro.
The car sits on a much shorter wheelbase than a standard Commodore, and the roof line is lower as a result. The rear doors are decoys in an attempt to pass off the coupe as a sedan, and the C-pillar is much narrower.
The rear overhang is modified as well, with a much steeper angle rising up from the wheel arch. Departing Holden general manager Denny Mooney admitted recently that Camaro mules were venturing onto Melbourne roads as part of the car’s development program.
The Camaro is the first confirmed global vehicle to be built on the Zeta rear-wheel-drive platform, developed in Australia for the VE Commodore. Its wheelbase is 109 mm shorter than the Commodore.
The Camaro will be built in Canada from late next year and is expected to use a V6 or V8 engine when it goes on sale early in 2009. The Holden Monaro two-door coupe is traditionally built on the same wheelbase as the Commodore sedan.
More information and discussion HERE.
Read the full blog entry.
