Gen5DIY
Old 02-25-2011, 11:41 AM   #1
SStothebone
Drives: 2011 Camaro 2SS/RS
Carbon Ceramic Brakes
Anyone know of the ZR-1 brakes being put on the camaro? If so where do you get them?
SStothebone is offline   Reply With Quote
Old 02-25-2011, 08:46 PM   #2
MG
MG's Avatar
Drives: 2011 Camaro
I know at least one person has them, but I can't find the pics for the life of me!
MG is offline   Reply With Quote
Old 02-26-2011, 12:46 AM   #3
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Mark Stielow, a GM engineer, has done them. Rumor has it he even sorted out the ABS and Bias.
Old 02-26-2011, 11:39 AM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Is it any better or cheaper than CTSV brakes?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-26-2011, 11:44 AM   #5
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Old 02-26-2011, 11:46 AM   #6
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Originally Posted by GEEo View Post
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 02-26-2011, 04:04 PM   #7
Hess Motorsports
Drives: 2010 SS with WAY TOO MANY MODS
Obivously the CCMs will have WAY better heat dissapation. The down side is the cost. We have seen the parts for front and rear go from anywhere between $14,000 and $18,000 and that's WITHOUT brackets to adapt to the Camaro uprights.
The AP Racing system or the Brembo ZL1 system are both great options and can keep you around the $6,000 range for complete bolt on systems that do not require anything else and work with ABS and the stock master cylinder. PM us for additional details.
Hess Motorsports is offline   Reply With Quote
Old 02-27-2011, 06:04 PM   #8
JusticePete
Better, yes. Cheaper no.
The beauty of a CTS-V brake upgrade is that the front to rear brake bias and abs are good to go out of the box. Bolt them on, bleed them and everything works just like it should from the factory.
If you go watch the ProTouring Challenge cars you'll see many of them struggle on the road course at the end of the straights heading into turns. Because they are using unique brake applications the bias isn't always right, causing them to get sideways.
Aftermarket brake kits are supposed to be dialed in. Most of them are. Adding a Corvette carbon ceramic brake kit to the 5th Gen take more than fitting it to the car. The computer system has to be 'tuned' so the bias and ABS work with the new brakes. That is where having a factory experience, racing experience and being an engineer have given people like Mark the ability to successfully make the conversion. I don't know of anyone else that has the C6 carbon ceramic conversion 100% functional with the bias and ABS.
The CTS-V conversion is hands down to most cost effective and track friendly system available. Congratulations to GM for having developed it with Brembo.
Editorial Note: Pedders does not make any money promoting the CTS-V brake upgrade.
Old 02-28-2011, 11:59 AM   #9
Chris_B
Chris_B's Avatar
Drives: Several
And let's not forget that the Camaro is a bit heavier than the ZR-1, has proportionally more weight over the front axle and has more forward weight transfer under braking. In my estimation (based on direct experience with carbon-ceramic conversions), there will not be enough rotor mass in the ZR-1 CCM kit to handle the Camaro's weight properly. For street driving (if the balance and ABS issues were sorted out), they might be OK. But for any real high performance use or track duty, oxidation would be a killer. Front rotor replacement would be REAL expensive.
Chris Bernal
Brake Maven
Chris_B is offline   Reply With Quote
Old 03-17-2011, 12:13 PM   #10
JusticePete
I believe Mark Stielow has them functional in a 5th Gen and from the looks of his performance at the Optima Challenger has them working really well on his 69 Camaro. He is a GM engineer and i am assuming has an intimate familiarity with the system giving him the ability to make it work. We'll that and years of experience building great cars while honing his driving skills. I am beginning not to like him
brakes
Poll -- Camaro vs Mustang Supercar Shootout JusticePete Suspension / Brakes / Chassis 105 10-09-2013 03:18 PM
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
Carbon Fiber Engine Dress-up | Unique Auto Designs | Fuse Box & Engine Compartment AutoAgenda Interior Parts & Accessories 6 09-21-2010 08:04 PM
GM Reveals 2011 Corvette Z06 Carbon Edition FenwickHockey65 General Automotive + Other Cars Discussion 33 03-16-2010 07:22 AM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
