Old 02-25-2011, 04:25 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
LS3 with 3.70 gears input?
I'm still gathering up the money for gears but I'm researching so that when I'm ready I'll know what I want.
I'm looking for some input for those that have and LS3 and added 3.70 gears. I'm still thinking that for a daily driver and only occassional track use the 3.70 might be a better choice than 4.11 gears.
I heard they are even putting 3.70 in the ZL1.
If you added 3.70 gears can you give any feedback about how they feel? Did you feel the difference going from the 3.45 to 3.70? Do you ever feel like you might want a little more gear? If you had it to do again would you have gone with 4.11 gears?
Build Journal
Old 02-26-2011, 02:26 AM   #2
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Caverman, PM Camaro21. He has the 3:70 in his car.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 02-26-2011, 02:29 AM   #3
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
I thought 3.73 was going in the ZL-uno ???
Bonemaro is offline   Reply With Quote
Old 02-26-2011, 06:16 AM   #4
BACH
Delving the Ordure ...
BACH's Avatar
Drives: '10 2SS/RS 6M CGM, '94 Z-71
I'm looking into this range of gears as well. Anyone with the LS3 and 3.73 gears that can comment on shift points, cruising/highway RPM, mileage, etc.? I know I'm not looking for the 4.11s cuz I'm not building a 1/4 mile car. but i do like to play around!!!
Me: Hey babe, do you mind if I spend a little money on my car?
Wifey: Your hobbies are expensive...(deep sigh). How much this time?
My journal: http://www.camaro5.com/forums/showthread.php?t=164741
BACH is offline   Reply With Quote
Old 02-26-2011, 07:36 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Lots of good info here:
http://thehorsepowerjunkies.com/vehi...swappin-gears/
Old 02-26-2011, 08:01 AM   #6
marticus24
Drives: 2012 ZL1
I'm also interested in anybody's experiences with this setup. Considering 4.11 or 3.73 right now.
marticus24 is offline   Reply With Quote
Old 02-26-2011, 08:15 AM   #7
flyby
Drives: 2010 Silver SS
I put 3:70's (9 inch) in mine back in August ish (long story) and finally got the car back in December (early). Put only a few hundred on it since then, but the difference is quite noticeable. Much faster from the start. A little tricky accelerating with PZeros that are cold but part of that is the horsepower increase. Cruising at 70 is about 1900 rpm. Overall I like the change, let you know more in March after first track visit.
flyby is offline   Reply With Quote
Old 02-26-2011, 09:01 AM   #8
Never Satisfied
220/221 whatever it takes
Never Satisfied's Avatar
Drives: See sig....
Well from my experience, the 3.70 is not enough. I started with the 4.33 (one of the first guys to run them) and I thought they were perfect. Due to circumstances beyond my control, I had to replace them with a set of the LPE 3.70's. They feel ok, but my combo and driving habits would like more gear down low with my cammed motor. Not a time goes by that I don't want the higher gear. I am now saving for a 9" setup and it will have 4.30's in it for sure.
Brent
2018 JL Wrangler Rubicon 2-door (on order)
2017 Scat Pack Shaker A8
2016 Challenger Hellcat A8
Never Satisfied is offline   Reply With Quote
Old 02-26-2011, 12:05 PM   #9
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
going from a 3.45 to a 3.70 is barely anything, and hardly justifies spending that kind of dough.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 02-26-2011, 01:08 PM   #10
steeleshark2
steeleshark2's Avatar
I have already ordered my 4.11s for my LS3. Still just under 2000rpm at 70mph from what I have heard.
Old 02-26-2011, 01:20 PM   #11
adc174
Drives: 2010
4.10s are the way to go, i love mine
adc174 is offline   Reply With Quote
Old 02-26-2011, 01:33 PM   #12
adc174
Drives: 2010
4.10s are very streetible gears they are highway friendly and my gas mialage didnt change at all, its a heavy car the 4.10s help a lot and at 70 its less lug to maintain speed, if i could do it again id go 4.33s , the 4.10s are a little tricky to launch hard but well worth it.
Old 02-26-2011, 02:02 PM   #13
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
The ZL-1 is supposed to come with 3:70 gears. The new Mustang 5.0 has them as well. Just to compare speeds on my 3.70 gears. Use these speeds to compare to your M6 factory 3:45 gears.
2,000 rpm 4th gear = 45 mph
2,000 rpm 5th gear = 55 mph
2,000 rpm 6th gear = 68 mph
Not a huge change but very nice on the street plus it makes 5th and 6th more practicle on the freeway. My car will not be on the drag strip.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 02-26-2011, 02:14 PM   #14
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
Care to share why you changed them?
4.33s are on the way for the m6
engine hits the limiter @ 62mph in 1st with stock gears
LC is offline   Reply With Quote
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
Specs on L99 vs LS3 .... Bowtie Junkman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 04-28-2010 01:26 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
LS3 + Manual = New Gears? ZZcamaro V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 03-16-2009 07:55 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
