HeadlightArmor
Old 02-25-2011, 06:39 PM   #1
YouseeSS
YouseeSS's Avatar
Drives: 2010 Camaro 2SS RS M6 SIM
Pfadt lowering springs install, bumpstops cut?
Anyone install Pfadt lowering springs and not cut the bumpstops? Just curious because Ive read some guys think it's a bad idea to cut them and I just want to weigh it both ways and see how it rides uncut. Guys a pfadt insist it's fine, but just checkin.
Thanks.
Four Horsemen
YouseeSS is offline   Reply With Quote
Old 02-25-2011, 06:47 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Not cutting the bump stops won't hurt anything and will not effect the ride quality most of the time. The only time cutting or not cutting the bump stop comes into play is when you encounter something that causes you to bottom out and hit (or not if you do cut them) the bump stops. You can always go back and do it later if you find that you are bottoming out often but if the roads in your area are ok it shouldn't be an issue.
Old 02-25-2011, 09:32 PM   #3
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I have Hotchkis which dont require cutting the stops, but yes on most roads it is never a problem. Only time is when your on a really bad road with "mountain" size bumps.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 02-26-2011, 10:12 PM   #4
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
If you didn't cut them, then later wanted to it would suck to have to pull all the struts out
Inferno LSX is offline   Reply With Quote
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. Apex Motorsports Suspension / Chassis / Brakes 341 02-02-2014 12:52 PM
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Motorsports Suspension / Chassis / Brakes 75 12-13-2010 10:29 AM
Doug Thorley Cat Back and Pfadt Lowering Springs Arrived JustFresh Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 5 09-06-2010 11:56 AM
Phoenix shop to install lowering springs? justJJ USA - Southwest 6 06-10-2010 12:31 AM
Pic request: Camaros with PFADT Lowering Springs JeremyHolt Camaro Photos | Spyshots | Video | Media Gallery 0 02-10-2010 08:38 AM
