| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() Drives: 2011 Camaro 2SS/RS Join Date: Dec 2010
Brake upgrade help!
If anyone hasn't notice I am looking to upgrade my brakes. I know a lot of people on here are promoting the CTS-V upgrade but I am planning on road course racing in the future and need some vented rotors. I can't find any in the CTS-V size so I am basically asking which brake is the best for the 6 piston setup in the front with cross drilled rotors all around. I am leaning towards Brembo GT Big Brake upgrade but don't know. Anything would help!
#2 | |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
As a rule of thumb cross drilled rotors are not the road course rotor of choice. My preference is for a plain face with a dedicated track pad. Brake ducts are highly recommended. Btw, when you say racing do you mean roll cage full race car or running road courses HPDE style?
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
#3 | |
Needs Lowering
CTS-Vs should be more than adequate. Use a high quality dedicated track pad. I use Cobalt Friction XR1 front and XR2 rear pads. Depending on how hard you run, front brake ducts may be in order.
Excuse me if this is too basic, but just in case. 1. Always run at least on cool down lap 2. Never, ever use your hand brake / parking brake when you come off the track. Shut it down in gear. 3. Use a high wet boiling point brake fluid
As several have mentioned before, stay away from cross drilled rotors for track use! It's not so much a question "if" they will crack, but more a question "when" they will crack.
The CTS-V brakes are an awesome upgrade for the money. Another option worth mentioning which we install on almost all of our in-house packages is the Brembo 6-piston caliper upgrade where you can use your stock rotors, or any other aftermarket rotor that fits a stock 2010 SS. I have been using this for almost 15K miles now, including 15+ trackdays and 15+ auto-x events and with the right set of pads and a high quality fluid have experienced ZERO brake fade. Even after 30 min of hard driving at Sebring were they showing any fade! I am running the brembo slotted rotor, DTC-60 pads in the front and DTC-30's in the rear and couldn't be happier. Let me know if you have any other questions! /Erik@Torq
#6 | |
Drives: Several Join Date: Nov 2009
If you can wait until April on the fronts and May for the rears, you might just have the ultimate street-driven track day setup!
Chris Bernal
Brake Maven |
#7 |
I'll throw my two cents in the hat...
Erik at TORQ has an awesome set-up! I went a slightly different way and simply replaced my rotors with a set of GM Frozen Rotors (www.frozenrotors.com). DTC-30 pads in all 4 corners, stainless steel lines (of course), and Castrol SRF fluid... oh I also installed a set of titanium pad shims to help shield the caliper from some heat. I am running a stock engine, with a Vararam Air box and TORQ custom tune (385RWHP on TORQs Mustang Dyno). I did fabricate a set of cooling ducts for the front rotors (I melted a set of HP Plus pads in 3 hours). ![]() ![]() May I suggest a harness bar... when you are stuck to your seat, you can concentrate on driving. Speedware Motorsports - ask for Drew or Tony (www.speedwaremotorsports.com) did mine, along with 6-point schroth HANS belts. ![]() ![]()
Pfadt springs, bars, strut tower brace. CCW: SP16a 20x10 front 20x11 rear. Nitto: NT05 275/35 F 315/35 R. Hawk: DTC30 F/R. Stainless Steel Brake Lines. MBRP cat back. VARARAM air box. Custom front brake cooling system. Speedware Motorsports Harness Bar and Tank Plates. Schroth Hybrid-II 6-point HANS belts. TORQ Custom Dyno Tune. Frozen Rotors Discs. NOWEEDS 3" Diverters. AMSOIL Synthetic Racing Oil and Coolant. Scorpion 1.8 Rockers. Custom/Modified Exhaust and Side Pipes. E3 Spark Plugs. Arrington Customized Catch Can. MORE TO COME LATER...
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
I just happen to be at Momentum Autosports this weekend because they were hosting a dyno day. They had one of they 2010 race cars up on a rack. One of the things I noticed is that they were using the factory calipers but they were definately using an aftermarket rotor. It was mostly a solid rotor with slotted "S" marks in them. I've never seen one like that before (not that I'm a racer though). I was only able to talk to the owner for about 5 min because he was busy running the dyno stuff but I mentioned to him that I would like to track my car someday just to try it out. He said that the minimum I would have to do would be to replace the pads, add stainless lines, and change the fluid. He said they usually race with the Cobalt pads but since mine would be a driver he suggested going with Hawk because it was a good street/track pad. He also mentioned the name of the fluid they used but I can't remember it now. All that was long winded to say that it looks like they were using the factory calipers but with upgraded pads, lines, rotors, and fluid. www.MomentumAutosports.com
Build Journal ![]() |
#9 |
I use HAWK DTC-30 front and rear. They have a cold temp of 100 and a high temp of 1200. They are noisy and dirty on the street - but I don't really care. I will be doing a track change and installing HAWK HT-10 when I arrive at the track for my front. YES - stainless lines are a MUST. Fluid - CASTROL SRF!!! HAWK pads and CASTROL fluid you will find at www.raceshopper.com THEY HAVE THE BEST PRICING!!! Tell them track weekend sent you. Any other questions, shoot me a PM with your number.
#10 | |
Needs Lowering
With the CTS-V setup I use Cobalt Friction XR 1 Temperature Range 100-1600°F (38-871°C) front and XR2 Temperature Range 100-1600°F (38-871°C).
#11 |
I think once you get a Camaro out for a HPDE track day.... you are like.... "drag race?!?! BORING!!!!"
#12 |
Drives: 2010 Momentum Race Group Camaro GS. Join Date: Jan 2010
Caverman-
Sorry we didn't get to chat more. We are running an Alcon front caliper with two pieces rotors all the way around (stock rear calipers- we actually are going to be switching to V6 rear brake calipers for 2012). Good info here. Castrol SRF or Motul 600. Hawk pads are a good balance for street/track use. Brake cooling ducts are great for anybody that plans to continue with hitting the road course. We run a custom 2X 3" duct for each front wheel. You don't need fancy rotors for light track duty. We are going to be putting together a package that will be 'safe' for the average C5'er to get out on a track and learn to drive. We can then accommodate additional braking modifications as the driver improves, and if he/she decides it's something they want to continue doing. We also offer StopTech big brake front kits which will pretty much end any braking problems you will ever have.
-2006 Z06, Vortech, Stereo, +Goodies
-2006 BMW 325i, Stereo, +Goodies -Design.Engineering-Motorsport.Defense -http://www.Mussco.com -http://www.JordonMusser.com |
#13 | |
He is a video of me chasing down a new 458 Italia at Homestead Miami on 3/12. You will notice a MASSIVE vibration in the braking zones... That is my HAWK DTC-30 front pads ending their life. I will be swapping to DTC-10s in the front for the track next time.
As in the pictures above, each front rotor is fed by a 2 inch duct attached to a 4x8 duct behind the mesh lower grill.
#14 | ||
I would recommend the DTC-70 for the front IF you were also using the DTC-60 on the rear, but not without. And, great video! I can't wait to see the new McLaren MP4-12C chasing down and passing that 458 Italia!
Chris Bernal
Brake Maven |
#15 |
Evil Pedders Guy Since 06
![]() Drives: His Wife Crazy Phone:860-880-0486 Join Date: Jan 2008
If someone on here is looking for a very high end brake pad for the track let me know, i'd like to get some feedback from someone.
This would have to be someone with a fair amount of track time on their Camaro already though. |
#16 | |
Speaking of Mclaren, that is one sick car right there. I saw a test version at The Ring when I was there racing last summer and it sounded phenomenal. The 458 is no slouch though but numbers alone I don't see why that Mclaren should walk that Pizza racer in a flash ![]() /Erik |
#17 | |
Unofficially, I'm hearing a 'Ring time of 7:00! I don't know if that was on street tires or not, so it will be very interesting to see what times they officially release. Just think, this is the first of 5 cars. The next one is the F1 replacement (probably $1.2-1.5M), gunning right for the Veryon SS, Koenigsegg and the new Pagani. Then we get a 911 Turbo fighter for probably less than $150k. Maybe a sport sedan after that?
Chris Bernal
Brake Maven |
#18 | |
If anybody can make a faster car to compete with Bugatti, Koenigsegg etc it would be Mclaren. |
#19 | |
I was mostly looking at the rear of the car since that was what was exposed. The front tires were still on so I didn't get to see much of it. I wish I would've had time to stick around but I had other plans I had to go to......plus not being an Lone Star Camaro member......well, lets just say it was time to go anyway. I was really impressed with your crew and your shop. I'm really glad I made it out there and I'm sure I'll be back. Wish I would've known of you sooner since I just had my car aligned and bushings tuned about 2 wks ago. I'm sure you could've pointed me in a good direction....not that I got a bad alignment, I just bet I could've got me an even better one. I really do want to track my car one day and if I can quit spending all my money on this car I might be able to get your private lessons. I hope to see you get more involved here on these forums. I think you can definatley bring some good race experience. I also like the way you're a straight shooter....you'll tell use if we really need something or not. It's not about making a sale with you...it seems truely like you want to help the customer get what they want out of the car.
#20 |
![]() ![]() Drives: GTO Join Date: Jun 2010
If you are looking for brake upgrades we've got DBA Rotors and Hawk Pads in stock and ready to go. We've got a sale going on as well.
#21 |
Mike
Drives: A 2010 CAMARO SS-LS3 Join Date: Sep 2009
Location: In the Land of the GenIV Camaros & Firebirds.
I think I'm in the right Thread,
Last weekend i've run the life my oem Pads after 18k miles, pretty good! But 2 hours of track time kill the last bit of them...? I'm wondering what pads to used with my oem setup and if I should consider changing my rotor as well even if they are new OEM that GM replaced last month...?
#22 |
Cajun Mariner
Drives: 10 Camaro SS/RS RJT 99 Silverado Join Date: Mar 2010
Same here, my pads are at the end of their life. Soon I'm going to be putting Pedders road/autocross track II package, stainless lines, and ATE Super Blue Fluid. I will be putting this car on the track especially since NOLA motorsports is open. IWAS considering Hawk HPS or HP+, but my ears are open.
'10 Camaro 2SS/RS Red Jewel L99/A6
#23 |
![]() Drives: 10 1SS/RS Join Date: Sep 2011
I am going to try EBC Yellowstuff pads,see of they do any good. I could not get any feedback from anyone one here about them so I figure it's worth a try. I also am installing stainless lines,cooling ducts and Motul fluid at the same time. In the future I definately plan on the CTS-V brake upgrade just can not afford it now.
2010 1SS/RS
GMPP exhaust,Vara Ram intake,Pedders XAs,1LE sway bars 20x10 gloss black XO Miami's,275/315 Nitto Invos CTS-V front brakes,Hotchkis STB ![]() |
#24 |
Has anyone ever used rotors from brake performance.com? If so, I would appreciate the feed back.
| Tags |
| brakes |
| Thread Tools | |
| Brembo GT Brake Upgrade | SStothebone | Suspension / Brakes / Chassis | 7 | 02-28-2011 08:40 AM |
| DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
| The most cost effective brake upgrade for the C5 SS? | nardox | Suspension / Brakes / Chassis | 7 | 10-26-2010 10:38 AM |
| Brembo Brake Upgrade by GMS | Granatelli | Suspension / Chassis / Brakes | 15 | 06-28-2010 01:18 PM |
| ***STILLEN Camaro SS Brake System Upgrade Package*** | Team STILLEN | Suspension / Brakes / Chassis | 14 | 03-16-2010 01:00 PM |
